sir i try firs with calculation but wrong code IMEI checksum seems ok Connecting to server please wait... Brand: Alcatel android Model: OT-4030X Imei: 869229010567308 PID TBMK1 SET (1) NCK: 33276497 NSCK: 31065844 SPCK: 32185552 CPCK: 31593443 CCK: 34357170 New firmware version can generate wrong code, use cable unlock!!!! -------------------------- Log saved to: logs\869229010567308_OT-4030X24.txt All done |
NSCK: 28726982 SPCK: 41790723 CCK: 21440741 CPCK: 18366816 PCK: 36621945 will fix this pid in next update, thanks for report |
thank you sir but customer was playing with some codes and i have enable to enter just one time code and it was wrong how can i now enter your because the counter is locked thanks |
Press together Volume Up and Volume Down+power button or Volume Down+power and after pressing shows pop android logo.. scroll with volume key to change options If not work then you must wait for cable unlock update fix |
not work cant reset counter with hard reset i will wait thank you |
Soon will be cable solution for this phones what allow full servicing. This must solve problems. |
i have other phone same model 4030x can you calculate code for it IMEI checksum seems ok Connecting to server please wait... Brand: Alcatel android Model: OT-4030X Imei: 869229010567837 PID TBMK1 SET (1) NCK: 40658444 NSCK: 23683759 SPCK: 23461546 CPCK: 22869441 CCK: 41739127 New firmware version can generate wrong code, use cable unlock!!!! -------------------------- Log saved to: logs\869229010567837_OT-4030X1.txt All done |
Later tonight it will be fixed in server Br |
Solved , must be ok now with this operator. |
ok I will try and post results thank you |
COM : 250 Selected Model Selected : GT-S5660 Start Reading Info.. Model : GT-S5660 Product code : S5660XXKPO Version : S5660XXKTL/S5660OXFKT5/S5660XXKT7 Imei : Bypass MSL Need... Scaning Security Area... Sorry Security data not found... Fail to Unlock Phone Error Bypass Security... Firmware date : (Apr 19 2012) Please send this log to : [email protected] -------------------------- Log saved to: logs\GT-S5660_unlock.doc imei was deleted by me.. phone is flashed when push button open firmware, exe block ind just go from 0 to 100 random |
What you meen block, give exactly details. Give me link for this firmware, will update exe right now. |
or wait next update and it will be added. BR |
Hotfile.com: One click file hosting: S5660XXKTL_OXFKT5_SMO_Serbia_Android_2.3.6.zip ok tnx for fast answer |
Hello, i have a problem. After update i have : Quote:
