12-11-2017, 20:04 | #1186 (permalink) | ||
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | Quote:
12-12-2017, 20:47 | #1189 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
But phone not have only cpu inside, it have many other things including firmware. Even if cpu is supported, phone can be unsupported and need to add separate. | |
12-13-2017, 14:18 | #1191 (permalink) | |
This phone not exists in my country and will be little problematic to get and test firmware and loader. In this way we can make some special in new update. | |
The Following User Says Thank You to orbita For This Useful Post: |
12-14-2017, 02:04 | #1192 (permalink) |
Major Poster Join Date: Jan 2013
Member: 1867935 Status: Offline Thanks Meter: 9 | Alcatel 5044r Fails mid way through the process of dumping the phone: Operation: Dump Firmware Searching for phone..... FlashMode Detected. Hello received. HW ID: 32004200E1009600 MSM8909 PK HASH: DF561473BCA15451CC489052D4E5FB2FA8FA3B4BB3A9FD9E0E 97140FF20DBC58 Checking database for suitable loader..... Arhitecture:32 bits Storage:EMMC Sending loader, please wait.. Waiting for loader to start... Reading partition info, wait. Volume[0] Size: 14.68 GB Partitions count: 40 Userdata Size: 11.28 GB IMEI: 015026001633138 Model: 5044R-2BAQUS1-R1 Secro: XAYAUAG0CL10 Manufacturer: AlcatelOneTouch Cpu: armeabi-v7a Build Id: NRD90M Model: Alcatel_5044R Android Release: 7.0 Android Version: Android N Config: diag,serial_smd,rmnet_qti_bam,adb Security patch: 2017-09-01 Reading: modem Reading: sbl1 Reading: aboot Reading: rpm Reading: tz Reading: boot Reading: fsg Reading: sec Reading: traceability Reading: reservedRaw [exception]Error untill reading info!! ************************************* |
12-30-2017, 01:07 | #1193 (permalink) |
No Life Poster Join Date: Mar 2016 Location: IN THE KERNEL
Member: 2545468 Status: Offline Thanks Meter: 234 | nck dongle presenting faults in the reading of the processors throwing failure in reading of simple processor mt6575 says error of boot and if it is placed exact model of mobile also presents the same fault |
01-01-2018, 14:04 | #1194 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Upload somewehere security backup from phone what give wrong codes. Will check what wrong. And i'am already answered, usa cable direct unlock, if calculator give wrong codes. |
01-03-2018, 19:12 | #1195 (permalink) |
No Life Poster Join Date: Oct 2013 Location: Cote Ivoire ABJ,tvlle, LBJ.23 Age: 39
Member: 2041210 Status: Offline Thanks Meter: 541 | samsung E2200 spd 6500 unlock done in rapport but no done ask alway network code Code: EXE: NckDongle Spreadtrum Module 0.5 SELECTED : SC6530 ACTION: Unlock. SCENARIO: SC6530. Start Detect phone. Remove the battery and connect handset to PC via USB cable. After long press boot key while inserting the battery. Keep key untill boot complete. Detected: SPRD U2S Diag (COM14) Sending loader, keep boot key untill loader start. Loader OK: nckTeam(2016) Beta 0.3 CPU: 6530 [1]FlashId: WINBOND: [0x1000000]W25Q128FW [2]FlashId: WINBOND: [0x1000000]W25Q128FW Reading Flash Info, wait... Flash Size: $2000000 Sector Size: $10000 NVRAM Status: NV_MINVALID_SOK Checking nvram, wait.... IMEI 1: 358414050246942 Using mode 2 Writing simlock, wait... Write Done. Backup saved: backup\spd_nvram_backup\SC6530_358414050246942_saved_nv_1.bin Total Time: 00:00:21 Done. |
01-04-2018, 09:05 | #1196 (permalink) | |
Samsung simlock differ from generic simlock and this exe is not designed for this. You can make full backup for safety and after make reset efs. This must reset simlock to "unlocked" state. | |
01-04-2018, 17:29 | #1197 (permalink) | ||
Member: 44659 Status: Offline Thanks Meter: 363 | GOmobile GO963 (tried several times) Quote:
01-04-2018, 19:33 | #1198 (permalink) | ||
Member: 44659 Status: Offline Thanks Meter: 363 | Sky Fuego 4.0T (0.4 and 0.5 failed), "Flash Mode Utils" worked but had to choose "SC7720EA_EMMC 5.x" otherwise the process freezes... Quote:
01-05-2018, 13:39 | #1199 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | GOmobile GO963 and Sky Fuego 4.0T posible is not supported by exe. If some phone is not supported by exe, this is not exe bug. Please report in this thread only exe bugs. Not need to post not working reports from unsupported phones. |
01-06-2018, 01:26 | #1200 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2554174 Status: Offline Thanks Meter: 3 | Action : Boot Info. Selected 0-By CPU:MT6582 Exe version: NCKDongle AndroidMTK 2.5.8.3 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek USB Port (COM25) Boot mode: Brom Phone detected...Please wait Sending DA agent, please wait... Connect error[0xfa1]: S_FT_DA_NO_RESPONSE Boot Fail.!!!. All done. But It reads info perfect on miracle Box CPU: MT6592 SW:0000 Ver: CA00 Downloading Boot8 ... EMMC Size: 0x01D2000000 Flash Type: EMMC INT/EXT RAM Size: 0x0+0x0 Reading infr(EMMC)... PRELOADER BaseAddr:0x0 Size:0x40000 MBR BaseAddr:0x0 Size:0x80000 EBR1 BaseAddr:0x80000 Size:0x80000 PRO_INFO BaseAddr:0x100000 Size:0x300000 NVRAM BaseAddr:0x400000 Size:0x500000 PROTECT_F BaseAddr:0x900000 Size:0xA00000 PROTECT_S BaseAddr:0x1300000 Size:0xA00000 SECCFG BaseAddr:0x1D00000 Size:0x40000 UBOOT BaseAddr:0x1D40000 Size:0x60000 BOOTIMG BaseAddr:0x1DA0000 Size:0xA00000 RECOVERY BaseAddr:0x27A0000 Size:0xA00000 SEC_RO BaseAddr:0x31A0000 Size:0x600000 MISC BaseAddr:0x37A0000 Size:0x80000 LOGO BaseAddr:0x3820000 Size:0x800000 EBR2 BaseAddr:0x4020000 Size:0x80000 RESV BaseAddr:0x40A0000 Size:0x80000 COTA BaseAddr:0x4120000 Size:0x3200000 EXPDB BaseAddr:0x7320000 Size:0xCE0000 ANDROID BaseAddr:0x8000000 Size:0x5E000000 CACHE BaseAddr:0x66000000 Size:0xC800000 USRDATA BaseAddr:0x72800000 Size:0x15E300000 BMTPOOL BaseAddr:0xFFFF0000 Size:0x1500000 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
