Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > NCK Team products > NCK Box Premium v2
Old 07-16-2018, 02:04   #1 (permalink)
Member: 185279
Thanks Meter: 43
Unhappy Samsung Clone - Dead after wrong flash
Hi there, I have a Samsung Clone J5 Prime.
I did Backup Security & Dump Firmware, after I do Full Format + Full Flash with an wrong firmware, now the phone is dead, and I can not restore the backup firmware.
Original state:
BaseBand CPU :MT6580
BaseBand CPU Secure Version : FF
BaseBand CPU Bootloader Version : 01
INT RAM: 128 KB SDRAM
EXT RAM: 1 GB DRAM
EMMC: (29Gb+8192Mb) SAMSUNG 0x4b3558564d42
EMMC FW VERSION: 01:00:00:00:00:00:00:00
EMMC CID: 1501004B3558564D42 : 00000000000000
EMMC UA SIZE: 0xe9000000
BOOT STYLE: EMMC BOOT
FULL LENGTH: 0xe9880000 [3.649 GB]
Status: USB_HIGH_SPEED
Detecting high speed port, wait......
If driver not installed, install high speed port driver.
If not need high speed port, disable it.
After repeat opperation.
Detected : MTK - DA Port (COM28)
-Reading GPT Drive OK
This phone have FRP partition.
Build ID: LMY47I
Display ID: KTU84P.A5000ZCU1AOE2
Version: 5.1
Build Date: Thu Jun 15 10:37:14 CST 2017
Model: gxq6580_weg_l
Brand: alps
Device: gxq6580_weg_l
Region: US
Mediatek Version Release: ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69
Now:
Exe version: NCKDongle AndroidMTK 2.5.9.0
Selected phone: ELBRUS
Action: Restore security items
Reinsert phone battery.
Battery must be charged.
Phone must be off with battery inside.
Please insert USB cable now...
Detected : MTK - USB Port (COM12)
Boot mode: Brom
Using Algo 1.
Scatter file loaded, not need emmi.
Phone detected...Please wait
Sending DA agent, please wait...
Second stage DA fail, aborting
BBCHIP MT6580
flash id: 4B0001154D5658352A
[S_FT_ENABLE_DRAM_FAIL]Exe not support this emmi settings
Please load scatter and preloader from phone fimware
Boot Fail.!!!.
All done.
What can I do?
Thank you.
Old 07-16-2018, 07:27   #2 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
First of all you must flash preloader, phone stuck on mtk port.
Or just load scatter with preloader and after restore security items.
Exe will use id from preloader in this case.
Old 07-16-2018, 13:33   #3 (permalink)
Member: 1765030
Thanks Meter: 4
friend installs another rom that the failure should be that it is not compatible with that model ... as advice if you get equipment with this failure hasle a reading first and even a backup (bin) to avoid these failures
Old 07-16-2018, 13:34   #4 (permalink)
Member: 1765030
Thanks Meter: 4
consejo
Old 07-16-2018, 14:10   #5 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
olivaresc2011, you readed topic starter post?
Old 07-16-2018, 14:46   #6 (permalink)
Member: 185279
Thanks Meter: 43
Unhappy
But how do I do it?
My Phone now is detected only in MTK Port
When I try restore secure items:
Boot mode: Brom
Using Algo 1.
[emmi]EMMC CID: 4b0001154d5658352a
Error Load Custom EMMI.
BBCHIP MT6580
Boot Fail.!!!.
All done.
When I try restore my flash backup only with preloader:
Flash files count is :1
Action : Firmware update.
Selected Model: 0-By CPU: ELBRUS
Scenario: [1]Full Flash
Boot mode: Brom
Using Algo 1.
BBCHIP MT6580
Boot Fail.!!!.
All done.
My original preloader:
Preloader: preloader_gxq6580_weg_l.bin
Flash definitions in preloader: 19
[1]Type: MCP(eMMC+DDR3) CID: 150100513732534D42
[2]Type: MCP(eMMC+DDR3) CID: 8801034E4361726420
[3]Type: MCP(eMMC+DDR3) CID: 150100463732324D42
[4]Type: MCP(eMMC+DDR3) CID: 700100454838434538
[5]Type: MCP(eMMC+DDR3) CID: 880103455042313030
[6]Type: MCP(eMMC+DDR3) CID: 90014A483847316505
[7]Type: MCP(eMMC+DDR3) CID: 150100463558354342
[8]Type: MCP(eMMC+DDR3) CID: FE014E50314A39344D
[9]Type: MCP(eMMC+DDR3) CID: 90014A483847346192
[10]Type: MCP(eMMC+DDR3) CID: 880103455041313030
[11]Type: MCP(eMMC+DDR2) CID: 110100303034474530
[12]Type: MCP(eMMC+DDR2) CID: 1501004B3758564D42
[13]Type: MCP(eMMC+DDR3) CID: 700100563130303038
[14]Type: Discrete DDR1 CID: 9EC64549E27FF8CF53
[15]Type: Invalid CID: 533E324145BEDA81D3
[16]Type: Invalid CID: 533E324145BEDA81D3
[17]Type: Invalid CID: 533E324145BEDA81D3
[18]Type: Invalid CID: 533E324145BEDA81D3
[19]Type: Invalid CID: 533E324145BEDA81D3
How can I restore my Preloader?
Old 07-16-2018, 16:58   #7 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
What problem haved phone before?
It's like you have bad emmc flash ic[strange id]
And this is hardware problem.
Old 07-16-2018, 17:32   #8 (permalink)
Member: 185279
Thanks Meter: 43
Unhappy
Stuck in logo, I was testing with several firmwares, but the last one I leave it like this.
Old 07-16-2018, 17:50   #9 (permalink)
orbita's Avatar
Member: 11170
Sonork: 1603694
Thanks Meter: 6,944
Then most probably, phone have damaged hardware(desoldered or bad flash ic)
The Following User Says Thank You to orbita For This Useful Post:
Page generated in 0.21723 seconds with 9 queries
