05-30-2013, 21:06 | #1 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1422819 Status: Offline Thanks Meter: 45 | t-mobile beat (zte r3100) unable to unlock [ANSWERED - SOLVED] |
05-30-2013, 21:24 | #2 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
For boot this phone in usb mode , phone need to be off. In help explained how to do. When exe ask keep this key and insert usb cable. Must detect new mtk comport. If you have troubles with usb mode, use rj45 cable. Just try only with phone this. 1.Power off phone(reinsert battery to be sure), press and keep key, insert usb cable. 2.In device manager check if detected new port. If yes then repeat same procedure in exe. If not detected, see why(drivers, incorect connection mode, cable issue e.t.c.) Last edited by orbita; 05-30-2013 at 21:34. | |
The Following User Says Thank You to orbita For This Useful Post: |
05-31-2013, 10:00 | #3 (permalink) | |
Member: 1422819 Status: Offline Thanks Meter: 45 | Quote:
Problem Solved Thanks for the help , it was the driver issue , i did not realize it....phone detected in seconds after installing the usb driver...thanks again | |
The Following User Says Thank You to errorcode999 For This Useful Post: |
05-31-2013, 10:04 | #4 (permalink) |
Member: 1422819 Status: Offline Thanks Meter: 45 | one more question , i need to reset it but it is asking for code...i tried all combinations 0000 00000 1234 12345 88888888 12345678 all of them are unsuccessful , any idea how to do the hard reset or how to get the code ?? |
05-31-2013, 11:49 | #5 (permalink) | |
This must reset all usercodes to default values. | |
06-01-2013, 12:50 | #10 (permalink) | |
How to complete reset phone with this exe. 1.Make auto fat format(press format button). 2.Make restore imei and unlock if will need again. Or, start filemanager, dump from d:\NVRAM\NVD_DATA file what have name MP45_XXX zip it , and atash here link, will give you default code. In some phones default code can differ from standart. | |
01-02-2014, 10:09 | #11 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 373786 Status: Offline Sonork: 100.1601935 Thanks Meter: 130 | Selected phone : ZTE:ZTE-G R3100 Connect phone in boot mode ... Start detecting port.. Com port ok : COM41 Phone detected...Please wait Conected ok with target ... BaseBand CPU : MT6236, E02 SW Version : R3100_V1_Z1_FR_D18G109 HW Version : MB3601AMB_A Reopen comport(COM41) Meta mode conected ok, start reading phone.... Phone imei : 863796010652575 Block1(N) : Unlocked Block2(NS): Unlocked Block3(SP): Unlocked Block4(C) : Unlocked META END OK. All done. |
