02-19-2019, 10:52 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Zimbabwe
Member: 2100642 Status: Offline Thanks Meter: 46 | Ocean T2(Samsung Clone) Stuck on logo 1.Tried wipe user data after disabling high speed port Action : Format UserData. Selected 0-By CPU:ELBRUS Exe version: NCKBox AndroidMTK 1.8.9.8 Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM85) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 256 MB DRAM ---------------------------------------------------- NAND: (4Gb+2048Mb) [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V BOOT STYLE : NAND BOOT Size: 0x20000000 [0.500 GB] BlockSize: 0x40000 PageSize: 0x1000 SpareSize: 0x80 Searching partiton table, wait.. Offset: 0x1ebc0000 High speed disabled by user, continue with this settings. Detecting format adress....wait! Starting generic userdata format...! [1]FORMAT - BEGIN: 0x18dc0000 - LEN: 0x700000 [1]FORMAT - BEGIN: 0x194c0000 - LEN: 0x56c0000 Format adress not detected, aborting! Wait untill phone will start charging. All done. 2.Tried resetting privacy Exe version: NCKBox AndroidMTK 1.8.9.8 Selected model: 0-By CPU ELBRUS Action: Reset Privacy Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM85) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 256 MB DRAM ---------------------------------------------------- NAND: (4Gb+2048Mb) [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V BOOT STYLE : NAND BOOT Size: 0x20000000 [0.500 GB] BlockSize: 0x40000 PageSize: 0x1000 SpareSize: 0x80 Searching partiton table, wait.. Offset: 0x1ebc0000 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM145) Dumping data, wait. Data not found, resetting filesystem. [1]FORMAT - BEGIN: 0x18dc0000 - LEN: 0x700000 [1]FORMAT - BEGIN: 0x194c0000 - LEN: 0x56c0000 3.Pattern unlock Exe version: NCKBox AndroidMTK 1.8.9.8 Selected model: 0-By CPU ELBRUS Action: Reset Pattern Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM85) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 256 MB DRAM ---------------------------------------------------- NAND: (4Gb+2048Mb) [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V BOOT STYLE : NAND BOOT Size: 0x20000000 [0.500 GB] BlockSize: 0x40000 PageSize: 0x1000 SpareSize: 0x80 Searching partiton table, wait.. Offset: 0x1ebc0000 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM145) Partition is damaged or encripted. Error, lock settings not found. Wait untill phone will start charging. All done. Tried Factor default/clear emmc but no response,I can read boot info easily,started giving me this message for performing format and full flash Flash files count is :9 Action : Firmware update. Selected Model: 0-By CPU: ELBRUS Exe version: NCKBox AndroidMTK 1.8.9.8 Scenario: [5]Full format + Full Flash Reinsert phone battery. Battery must be charged. Phone must be off with battery inside. Please insert USB cable now... Detected : MediaTek PreLoader USB VCOM (Android) (COM85) Boot mode: Preloader BBCHIP: 6572 0 ca00 Using Algo 1. Scatter file loaded, not need emmi. Phone detected...Please wait Sending DA agent, please wait... ---------------------------------------------------- BaseBand CPU :MT6572 BaseBand CPU Secure Version : FF BaseBand CPU Bootloader Version : 01 ---------------------------------------------------- INT RAM: 128 KB SDRAM EXT RAM: 256 MB DRAM ---------------------------------------------------- NAND: (4Gb+2048Mb) [SAMSUNG] KA100O015E_BJTT/KF94G16Q4V BOOT STYLE : NAND BOOT Size: 0x20000000 [0.500 GB] BlockSize: 0x40000 PageSize: 0x1000 SpareSize: 0x80 Status: USB_HIGH_SPEED Detecting high speed port, wait...... If driver not installed, install high speed port driver. If not need high speed port, disable it. After repeat opperation. Detected : MediaTek DA USB VCOM (Android) (COM145) Flash NAND Algo Start. Starting flash. [1]FORMAT - BEGIN: 0x0 - LEN: 0x20000000 Error FlashTool: Invalid begging and end addresses are given for read operation on Flash. Please check your start address and length again. [3040]Warning : S_DA_INVALID_RANGE [3045]Error: S_DA_NAND_BAD_BLOCK All done. What does this mean team and can phone be saved? BR |
