05-23-2013, 21:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2010
Member: 1422878 Status: Offline Thanks Meter: 164 | What unibox can be used with nck dongle? [ANSWERED] Ex: For GT-E2120, the help show 1. Phone must be off 2. Must be used UART cable 3. Take any UniBox, insert UART cable into phone and box and select box port 4. Press Unlock button. i try with SELG Tool, Cruiser Pro Box and Z3X, but the nck samsung module show this error "integer overflow", and no read codes, no read info, show wrong imei. BR |
05-24-2013, 09:26 | #2 (permalink) | |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Quote:
You must use cable what have same pinout as box. For example. Z3X have unibox pinout.Cruiser Pro Box as i'am remember have UFS pinout. SELG Tool , i'am not have but setool box have UFS pinout, so check your box pinout. | |
05-24-2013, 10:40 | #3 (permalink) | |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Quote:
05-24-2013, 11:18 | #4 (permalink) |
No Life Poster Join Date: May 2010 Location: FLAT EARTH
Member: 1295624 Status: Offline Thanks Meter: 152 | use pl2303 serial cable and no problem ,i use home built cable from pl2303 with rj45 connect........ ufs with direct com can work too |
The Following User Says Thank You to bhiret For This Useful Post: |
05-28-2013, 14:20 | #5 (permalink) | |
Member: 1422878 Status: Offline Thanks Meter: 164 | Quote:
Using Z3X as interface when try to read info it show a wrong imei. when try to read codes the application show the integer overflow error | |
