Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 01-04-2018, 11:21   #1 (permalink)
Member: 2184561
alcatel kernel imei repair help
I have noticed that the imei fields of the alcatel devices are in the boot.img file. how is a calculation used ? it changes in these areas when every ime changes...
Old 01-05-2018, 07:54   #2 (permalink)
Member: 2618995
Thanks Meter: 5
Dear Friend,
What model is this?
Old 01-06-2018, 08:41   #3 (permalink)
Member: 2184561
Originally Posted by sjames11501 View Post
What model is this?
The message you have entered is too short. Please lengthen your message to at least 20 characters.
modeli vf-895n. what do you mean from the message ?
Old 01-08-2018, 08:15   #4 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 536
Since when Qualcomm chips started to hide that data in the kernel? I'm not expert but being a power user I can say it is always in nv and qcn.
look at this thread
Successfully repaired imei on VF-895n
Old 01-10-2018, 19:37   #5 (permalink)
Member: 2184561
look at this thread
I know he's doing sigmakey, I want to know how it's calculated
Old 01-13-2018, 17:18   #6 (permalink)
Member: 2184561
no solution found....
Old 01-17-2018, 12:20   #7 (permalink)
SeharH's Avatar
Member: 2753718
Sonork: QQ 2045657399
Thanks Meter: 259
HI
Hint :
For qualcomm based devices work around EFS AND QCN ....
BR.
SeharH
Old 01-17-2018, 13:01   #8 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 536
Originally Posted by SeharH View Post
HI
Hint :
BR.
SeharH
Here you go, that's called an expert opinion from an expert user.
Old 01-17-2018, 13:01   #9 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 536
Let me say,I'm a fan of your work.
Old 01-17-2018, 13:21   #10 (permalink)
SeharH's Avatar
Member: 2753718
Thanks Meter: 259
@seci20
Upload QCN for me i can calculate for you the IMEI String
BR.
SeharH
Old 01-19-2018, 06:17   #11 (permalink)
Member: 2184561
@seci20
BR.
SeharH
Hello bro.
File link :
https://mega.nz/#!Cx0AzDyC!YN6ZuVgcQ...-Tz7TEgFdbrZHA
İmei : 222222222222228
Old 01-19-2018, 08:08   #12 (permalink)
SeharH's Avatar
Member: 2753718
Thanks Meter: 259
Originally Posted by seci20 View Post
Hello bro.
File link :
HI
By provided QCN Imei string at 0x19270
EXTRA NOTE : If you want to edit IMEI string at any value i can do for you
Note : Please don't ask me how to calculate because may be than iam speechless
BR.
SeharH
Old 01-19-2018, 08:45   #13 (permalink)
Member: 2184561
HI
BR.
SeharH
hello bro. thank you for answering !
imei qcn does not change on the phone when we change it...
sigmakey and other programs are modifying the boot field...
when I uploaded the stock rom to the device, the original ime numbers are coming back...
Old 01-19-2018, 23:07   #14 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 4,732
@seci20
BR.
SeharH
There is one more "security touch" after simple imei editing
on alcatel QUALCOMM devices, for IMEI to stay the same,
after flashing stock rom / factory reset.
Mentioned box reversed factory tools, and that's how it works.
No any miracle in that.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
Old 01-20-2018, 05:37   #15 (permalink)
SeharH's Avatar
Member: 2753718
Thanks Meter: 259
This is second part of Qualcomm for repair imei which i mention on my first post that is EFS..Nothing related to "boot" which can restore the original IMEI..Skip MODEMST1 and MODEMST2 during write the stock rom,Your MODIFIED data will be stay the same
BR.
SeharH
Page generated in 0.51338 seconds with 7 queries
