Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 04-17-2020, 08:35   #1 (permalink)
Member: 2160706
Thanks Meter: 48
APK Easy*Tool*v1.56 is out
Apk Easy*Tool*is a lightweight*application*that enables you to manage, sign, compile and decompile the APK*files*for the*apps*you are working on.
Allows you to manage the updates and fixes from one place
The program comes with a clean and user-friendly interface that is unlikely to give you troubles. You can get started by selecting the desired*file*via the browsing function of the*tool*or drag and drop.
The interface displays various information about the APK*files, including package name, version, minimum SDK version and version*code. From the main window, you can make the desired modifications as the main functions and additional options are all available in this*tab.
Speaking of functionality, some of the main operations you can perform via this*tool, you can count compiling, decompiling, signing, extracting and installing the APK. In*case*you are working with*ROMs*only, then you can make further changes from the Framework*tab. Moreover, if you feel you missed something, you can check all operations performed from the Log output*tab.
A straightforward*app*for managing APK*filesefficiently
A noteworthy feature of the*tool*is that you can create the*new*code*separately and overwrite the current APK with a simple drag and drop. It goes without saying that this operation can save you a lot of time and effort.
In the eventuality that you provide frequent fixes and updates for your*Android*games*or*tools*and want to be able to manage this processes smoother, then perhaps Apk Easy*Tool*could come in handy.
- Softpedia
Same as apktool, APK Easy*Tool*is neither intended for piracy and other non-legal uses. It could be used for localizing, adding some features or support for custom*platforms, analyzing*applications*and much more.
APK Easy*Tool*is absolute free for commercial and non-commercial use.*
Requirements:
-*Windows*7 or above
- .NET Framework 4.6.2 or above
-*Java*SE/JDK for decompile, compile, and sign APK. If you don't have*Java*installed, you can only use Zipalign or*Install*APK.*Download and install Java SE/JDK now
[SIZE="7"]Features:[/SIZE]
Decompile/Compile
Decomile and compile APK, DEX and JAR*files, with SPACE, symbols and germany, danish, swedish etc... characters support. Can cancel during operation
Sign/Zipalign
Signing and ZipAligning of APK/JAR*files. Can cancel during operation
Extract/Zip APK
Extract and*zip*APK with 7z Compression-level 0-9. Can cancel during operation
APK Infomation
Show APK infomation with icon using aapt dump badging and link to Play Store
Framework
Install*your framework and manage framework paths
Log output
View your logs to find errors. Set date to view your previous logs
Sided log output is only available for higher resolution with 1250 width and above.
Options
Change options of*tool, decompile, compile, sign and zipalign. Options:*Java*heap, Apktool version, apksigner version, directories,*java*path,*Windows*explorer integration, remeber*window position*and more
All options and textboxes are saved as config.xml and will load on launch
Quick options on main.
Drag and drop
Drop APK, DEX, JAR*files*and Decompiled folder on*buttons*to perform actions. Drop outside*buttons*to select/open as file/folder
Apktool.jar version selection
Can switch to other versions of apktool.kar on options
Add other apktool.jar in "Apktool" folder*
Shortcuts
4*buttons*to open work directories of decompiled APK, compiled APK, extracted APK and zipped APK*
Jumplist shortcuts
Do actions by just right-clicking on APK*file*and choose the following options, decomile or compile APK, DEX, and JAR*files, Zipalign APK, Check align, Sign APK and*Install*APK.
[B][SIZE="7"]
Download : (LINK REMOVED - SECURITY REASONS)
Old 04-17-2020, 12:27   #2 (permalink)
Moderator
Member: 73
Thanks Meter: 537
Red face
Tell me one.
What from this YOU NOT UNDERSTAND?
GSM Programming & Reverse Engineering forum is for discussing programming and reverse engineering only.
In here you can share tools related to these tasks and links for source code.
This is not the place for show casing your own software
Unless you include full source codes of your own software, this is not the correct place for you.
Own software should be posted in GSM Mobile Links forum.
Links to software with no source code will be moved with no notice, from now on.
HERE IS NO PLACE TO ADVERTISE YOUR OWN SOFTWARE.
__________________
You'll die as you lived in a flash of the blade,
in a corner forgotten by no one
You lived for the touch for the feel of the steel
One man, and his honor.
Old 04-19-2020, 20:43   #3 (permalink)
Member: 2160706
Thanks Meter: 48
Ok no problem
Will post on the right forum.
Page generated in 0.13091 seconds with 8 queries
