Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-12-2017, 09:05   #1 (permalink)
COVVA's Avatar
Member: 142645
Sonork: 100.1604204
Thanks Meter: 207
Azus z00t(intel processor) How enable virtual com
Hi to alls i need your help .. i need enable intel virtual com asus z00t to fix imei i test several commands but no results
#/system/bin/sh
# sets DIAG mode
echo 0 > /sys/class/android_usb/android0/enable
echo 04E8 > /sys/class/android_usb/android0/idVendor
echo 6860 > /sys/class/android_usb/android0/idProduct
echo diag > /sys/class/android_usb/android0/f_diag/clients
echo 1 > /sys/class/android_usb/android0/f_acm/instances
echo diag,acm,adb > /sys/class/android_usb/android0/functions
echo 1 > /sys/class/android_usb/android0/enable
start adbd
setprop sys.usb.state sys.usb.config
Not resutls
su -c setprop persist.system.at-proxy.mode 2
Not results
I need command way fastboot adb commands to generate virtual android intel com..
scripts no function..
Thanks for you help
Old 05-19-2017, 03:18   #2 (permalink)
Master-Key's Avatar
Member: 2390703
Thanks Meter: 177
#/system/bin/sh
# sets DIAG mode
start adbd
Not resutls
Not results
Thanks for you help
adb shell
su
insmod /system/lib/modules/diagchar.ko
setprop sys.usb.config diag,adb
The Following User Says Thank You to Master-Key For This Useful Post:
Page generated in 0.19618 seconds with 7 queries
