Blackberry php source because some guys are trying to sell free thing here is it Note: it's my first "web application" on php , i code on asp.net , so code is ugly but seems to work fine http://pastebin.com/9XzNa01i |
if is delphi you ask for php , if php you ask for vb...come on take a book or use google and do yourself! i never write any single line on php and i spend 30 minutes of my time for do it! ps. on source replace for ($i = 1; $i <= 4; $i++) echo "<pre>Mep".$i.": ".myhash2code (my_sha1 ($Imei,$pass,$i),$mep)."\n"; with for ($i = 1; $i <= 4; $i++) echo "<pre>Mep".strval($i+1).": ".myhash2code (my_sha1 ($Imei,$pass,$i),$mep)."\n"; or with for ($i = 0; $i <= 4; $i++) echo "<pre>Mep".strval($i+1).": ".myhash2code (my_sha1 ($Imei,$pass,$i),$mep)."\n"; |
you Mep1: 73531xxxxx150386 = real MEP2 Mep2: 28663xxxx0113403 = real MEP3 Mep3: 48397xxxx3576620 = real MEP4 Mep4: 22765xxxx6201736 = real MEP5 and y3kt v1.4 MEP1: 0170xxxx47342198 => where is it ? MEP2(NCK): 73xxxx7603150386 => you MEP1 MEP3: 28663xxxxx113403 MEP4: 48397xxxx3576620 MEP5: 2276xxxx6201736 I replace }else{ $size=15; by }else{ $size=16; thanks for the job ;) |
solution is on my last post or just not do copy/paste without try to understand code about 15 or 16 , if the for starts from 0 need to be 15 |
I posted that I was selling php source in sales section, but only to try stopping fingusio from ripping people off for $200, I had no intention of selling the one I coded, even though it is much better than yours or the one fingusio is selling :D:D:D:D BR Des |
PHP BB source is coded by my coder. Till now i never saw any free BB PHP. So if will be free somewhere i also give it all source in PHP (two files, one main code, second file with meps). I never advocated anyone to buy it. If have many customers and need buy so buy. If have 2per month dont buy - its easy. I try contact with people who buy from Us and can paste here opinion. |
So.... Post it!!!;) dont you?.... |
Just a sugestion, put mep in array and use array_search function from php :) code will be 50% short and more faster . |
16 digit works perfectly... 8 digit - last number missing Example IMEI : 012345678901234 MEP : MEP-30218-002 Mep2(NCK): 6927171x Mep4: 1550136x Actual value MEP2: 69271717 MEP4: 15501362 |
fix if ($pos>0){ $size=7; to if ($pos>0){ $size=8; |
6+1 Mep2(NCK):69271717 first digit + 5th digit = 7 Mep4:15501362 first digit + 5th digit = 2 |
Subtract the second and the third number also ;) |
on source is if ($pos>0){ $size=7; }else{ $size=15; } for ($i = 0; $i < $size; $i++) { instead must be if ($pos>0){ $size=7; }else{ $size=15; } for ($i = 0; $i <= $size; $i++) { if you want have 7 or 15 like size values |
