Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 03-29-2010, 19:31   #16 (permalink)
angel25dz's Avatar
Member: 315181
Sonork: 100.1593455
Thanks Meter: 301
Originally Posted by y3kt View Post
You need to have rimradiocomm.dll registered in your system in order to get functionality, luck
there is any similar DLL for .net languages (C#) ??
Old 05-12-2010, 15:26   #17 (permalink)
Member: 1058096
Thanks Meter: 3
can not use on blackberry 9520
Old 05-12-2010, 16:00   #18 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
The same dll should work with c#, luck
if you have all dll together then it should work, luck
The Following User Says Thank You to y3kt For This Useful Post:
Old 05-12-2010, 16:04   #19 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,911
can u post complete source for this ?
Old 05-12-2010, 19:37   #20 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
Hi, complete source is HERE, it is all you need, luck
The Following 3 Users Say Thank You to y3kt For This Useful Post:
Old 05-13-2010, 01:24   #21 (permalink)
TestBox2's Avatar
Member: 772096
Sonork: 100.69222
Thanks Meter: 8,277
some on c++
long CommReadWrite1(HANDLE hDevice, LPOVERLAPPED pOverlapped)
unsigned char pReadData[0x4000];
unsigned char pWriteSequence12[] = {0x00, 0x00, 0x0C, 0x00, 0x05, 0xFF, 0x00, 0x00, 0x08, 0x00, 0x04, 0x00};
unsigned char pWriteSequence24[] = {0x00, 0x00, 0x18, 0x00, 0x07, 0xFF, 0x00, 0x01, 0x52, 0x49, 0x4D, 0x20, 0x43, 0x61, 0x6C, 0x20, 0x74, 0x61, 0x73, 0x6B, 0x00, 0x00, 0x00, 0x00}; // RIMCalTask
unsigned char pWriteSequence8[] = {0x00, 0x00, 0x08, 0x00, 0x0A, 0x01, 0x00, 0x02};
DWORD dwNumberBytesRead, dwNumberBytesWritten;
// VERIFIED
CommWriteToPhone(hDevice, pWriteSequence12, sizeof(pWriteSequence12), &dwNumberBytesWritten, pOverlapped);
CommReadFromPhone(hDevice, pReadData, 0x4000, &dwNumberBytesRead, pOverlapped);
if(dwNumberBytesRead != 0x14)
return 0; // cannot read BPIN
// VERIFIED
CommWriteToPhone(hDevice, pWriteSequence24, sizeof(pWriteSequence24), &dwNumberBytesWritten, pOverlapped);
if(dwNumberBytesRead == 0)
return 0; // no reply from device
The Following 3 Users Say Thank You to TestBox2 For This Useful Post:
Old 05-13-2010, 09:24   #22 (permalink)
angel25dz's Avatar
Member: 315181
Sonork: 100.1593455
Thanks Meter: 301
Originally Posted by TestBox2 View Post
some on c++
// VERIFIED
// VERIFIED
this code use winapi.....what about RIMRadioDriver.dll?? there is a managed version of this dll?? I can't find it !!
Old 05-14-2010, 17:46   #23 (permalink)
Member: 209767
Thanks Meter: 112
why not work delphi 7 sir?? any wrong in code...
Old 05-15-2010, 02:58   #24 (permalink)
Member: 128122
Thanks Meter: 256
Originally Posted by smartmod.de View Post
That's exactly how I tried but I just got empty IMEI and MEP 0000000... I will try again later.
I wrote you a PM. Any chance you could provide me with the source?
Thanks!
If your BB got password enabled or put password and IT policy enabled, that would not work for you, just remove IT policy and wipe your BB to remove password. And that will work
Old 05-15-2010, 03:21   #25 (permalink)
Member: 422015
Thanks Meter: 64
can someody upload BBDEVMGRLib & RIMRadioCOM 1.3 Type Library
coz i dont want to download MFI Multiloader its too bigger file for download
thanks
Old 05-15-2010, 10:49   #26 (permalink)
Member: 3179
Thanks Meter: 142
can somebody help me source code for blackberry in visualbasic 2008
regards
Old 05-15-2010, 21:55   #27 (permalink)
balu_dark's Avatar
Member: 16251
Thanks Meter: 38
regards
can somebody help you with money?
Old 05-15-2010, 23:42   #28 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
Hi to all, even though after all that i have explained here i see very easy to build an application to read MEP code from a BlackBerry i know that at the beginning most thing looks pretty difficult (i'm not a pro), that's why i am posting here my Delphi project which should work for everybody. RIMRADIOCOMLib_TLB is also included, so enjoy.
If anyone has an idea of how unlock codes are calculated and would like to share it for research purposes then it is welcome, i've been planning to find out how it is done but i don't think i have the time to start from scratch.
Luck!
The Following 7 Users Say Thank You to y3kt For This Useful Post:
Old 05-16-2010, 13:48   #29 (permalink)
Member: 209767
Thanks Meter: 112
Luck!
any wrong bro?? bcozz can not open in my delphi 7
Old 05-16-2010, 14:03   #30 (permalink)
y3kt's Avatar
Member: 238127
Sonork: 100.1574867
Thanks Meter: 3,526
I haven't try it in delphi 7 as i was using delphi 2005, but make a new project an open Unit1.pas in notepad and reproduce the code in oyur delphi 7 project, just add 2 edit text fields and name them as in the code, you should be good to go, i can't help more than that, luck
MEPSERVER - 1ST IN WORLD - BLACKBERRY MEP READER built for MAC users FuriouS TeaM FuriousGold 35 06-09-2010 09:56
ALL BlackBerry Meps Level & HTC qualcomm/Omap code reader ! Professional Services !! MB code Main Sales Section 0 03-03-2010 02:33
Page generated in 0.22080 seconds with 11 queries
