bm622i how to change mac address hello guys , is there anybody know how to change mac address of bm622i here i tried to change it on telnet but nothings happening here's the commands i have use: commands are different from bm622 login:wimax password:wimax820 atp>cmd setusermode super atp>cmd shell # /cd bin # bin/ equipcmd setmacaddr 40:4d:56:88:12:00 when you hit enter it will change the mac address but even how many times i tried it nothings happening.. it just go back on # bin/ i don't know if the equipcmd setmacaddr command is disabled but when you type equipcmd help you will see a command setmacaddr on the command options telling that it is the command to change the mac address but when you tried it ,, nothings happen.. anybody have an idea? i will be so thankfull if someone will share there opinions and idea's even theory will make me happy either thanks everybody |
just updating,, please , everybody has the right to share ,, thanks |
just want to update ,, pretending that there is someone who knows how to change the mac address of this modem bm622i or firmware to flash the modem.. thanks guys |
Hi jinjean14, I have a similar Huawei device. After changing your MAC address, you may have to issue the command /bin/equipcmd restoredefault (note that there is no space between the two words). That command apparently stores the new MAC address to the flash. You can check whether it has been stored with /bin/equipcmd macaddr display If your Huawei device is like the ones that I have used then the equipcmd tool invokes a library function in /lib/libhuawei.so. That function issues various ioctl system calls to the /dev/bhal character device. If you are very keen on hacking this device and can't get equipcmd to play ball with you, then you could use the 'strace' tool when you run equipcmd. That will reveal the system calls that equipcmd is issuing (whether directly or indirectly via the libhuawei library.) I have built strace for mips32 linux, so if you can get the strace binary onto the device, with tftp, ftp, over serial with xmodem, or some such, then you could try it out. https://docs.google.com/leaf?id=0B6w...2MmYz&hl=en_US |
Do this PROCEDURE for hacking wimax bm662i using with ATP client: Login : wimax Password br]AT P>cmd SetUserMode super ATP>shell / # cd bin /bin # /bin # telnetd /bin # /bin # equipcmd setAssemblyenable Enable assembly success/bin # /bin # /bin # equipcmd setserialnum 500810118xxx Set sn success/bin # /bin # /bin # equipcmd setmacaddr 78:1D:BA:XXX Set HWaddr success/bin # /bin # /bin # equipcmd swversion display software version: V100R001PHLC08B025 pcb version: 16843009 cfe version: BM622i display version success/bin # /bin # exit ATP>logout\r logout from configuration console. Disconnect from server Connection to host lost. Press any key to continue... Welcome to Microsoft Telnet Client Escape Character is \\\'CTRL+]\\ \' Microsof t Telnet> o ( to ) 192.168.254.1 Connecting To 192.168.254.1... Microsoft Telnet>q Z:\\\Documen ts and Settings\\ \animaltyco mplex>exit then login to web then reboot for refreshing,,, freely recieved freely to give! Ang mga hindi makapagpalit ng MAC FROM THINKBIG07 1.) Try ALL the user accounts from the CONFIG FILE, then try if CMD DISPLAY_B would show up some infos .. thus, MAC address editing is enabled on that account. 2.) Try the CMD Mirror and SET Command Parameter, use HELP from the ATP CLi.. 3.) Open up the CONFIG FILE using WORDPAD, press CTRL+H, Find ( Enable=\\"0\\" ) then Replace to (Enable=\\"1\\") ... Hit REPLACE ALL.. then SAVE and upload it to your BM622i unit ... do the same with MACAddressOverride=\\ "0\\" to MACAddressOverride=\\ "1\ \" ... then try Telnet 4.) Check the config file, what is |
Login: wimax Password:wimax820 ATP> ATP>cmd : <enter> ATP>cmd setuser super <enter> ATP>cmd : <enter> ATP>shell <enter> /# cd bin <enter> /bin # /bin # hwvconfig <enter> KAYO NA BAHALA DITO equipcmd swversion display == equipcmd 1 equipcmd adsl info == equipcmd 2 equipcmd chiptest adsl == equipcmd 3 equipcmd chiptest lanswitch == equipcmd 4 equipcmd usbtest == equipcmd 5 equipcmd wlanled on == equipcmd 6 equipcmd wlanled off == equipcmd 7 equipcmd wpsled on == equipcmd 8 equipcmd wpsled off == equipcmd 9 equipcmd setboardnum == equipcmd 10 equipcmd setmacaddr == equipcmd 11 equipcmd setserialnum == equipcmd 12 equipcmd setouinum == equipcmd 13 equipcmd boardnum display == equipcmd 14 equipcmd macaddr display == equipcmd 15 equipcmd serialnum display == equipcmd 16 equipcmd ouinum display == equipcmd 17 equipcmd setuserpwd == equipcmd 18 equipcmd setssid == equipcmd 19 equipcmd setwlpwd == equipcmd 20 equipcmd userpwd display == equipcmd 21 equipcmd ssid display == equipcmd 22 equipcmd wlpwd display == equipcmd 23 equipcmd setAssemblydisable == equipcmd 24 equipcmd setAssemblyenable == equipcmd 25 equipcmd settr064pwd == equipcmd 26 equipcmd tr064pwd display == equipcmd 27 equipcmd elabel display == equipcmd 28 equipcmd loadelabel == equipcmd 29 equipcmd backupelabel == equipcmd 30 equipcmd restoredefault == equipcmd 31 |
wow thanks TS, may naka pag unlock naba nito, natry ko kasi pero ayaw parin sa akin sa mga xpert & masters willing po ako mag bayad ma unlock lang modem ko. BM622i |
bro, not tested.. wasting time. bm622i not proven for hacking... |
tested changing mac for this model...some members from our local forum in ph. |
Freak team! no good ... wasting time, |
bm 622i can be activated using cmd.... 2010 version only |
yes pwede ma hack bm622i 2010 model using cmd wimax wimax 820 atp diag setallmacaddr xxxxxx tapos nakalagay dun succesfull then atp diag restoredefult yan ok na 22i nyo |
------------------------------- -----Welcome to ATP Cli------ ------------------------------- Login: wimax Password: ATP>cmd setuser super ATP>diag display macaddr Current WAN mac: 20:2B:C1:69:4B:50 Current LAN mac: 20:2B:C1:69:4B:51 ATP>diag set macaddr 00:25:68:AC:0A:9F Set LAN mac address success. LAN Mac address updated: 00:25:68:AC:0A:A0 Set WAN mac address success. WAN Mac address updated: 00:25:68:AC:0A:9F ATP>diag restore default Connection to host lost. |
for 2010 package heres a simple script to change mac address 1.Copy the script below on a Notepad 2.Change the MAC you want to use ( live / working mac) 3.Save as BM622i CHANGEMAC.vbs Set cloner = CreateObject("WScript.Shell") cloner.run"cmd" WScript.Sleep 500 cloner.SendKeys"telnet 192.168.254.1" cloner.SendKeys("{Enter}") WScript.Sleep 500 cloner.SendKeys"wimax" cloner.SendKeys("{Enter}") WScript.Sleep 500 cloner.SendKeys"wimax820" cloner.SendKeys("{Enter}") WScript.Sleep 500 cloner.SendKeys"diag set macaddr XX:XX:XX:XX:XX:XX" cloner.SendKeys("{Enter}") WScript.Sleep 500 cloner.SendKeys"diag restore default" cloner.SendKeys("{Enter}") WScript.Sleep 500 cloner.SendKeys("{Enter}") WScript.Sleep 30000 cloner.SendKeys"exit" cloner.SendKeys("{Enter}") WScript.Sleep 45000 |
http://forum.gsmhosting.com/vbb/f83/...ed-na-1622729/ All commands of wimax is here, just follow the command, for BM622m 09276055405 |
