Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 10-05-2012, 08:28   #1 (permalink)
s.r.yadav's Avatar
Member: 856686
Thanks Meter: 27
can possible zip file password unlock
can possible zip file password unlock if possible .please provide me good sofware
Old 10-05-2012, 09:32   #2 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
It depends on how that zip is protected.
You may search google for such tools.
Br,
Shadab Ahmad
Old 10-05-2012, 11:41   #3 (permalink)
s.r.yadav's Avatar
Member: 856686
Thanks Meter: 27
thank for reply... how to find that how to that protected
Old 10-05-2012, 15:33   #4 (permalink)
josedavido's Avatar
Member: 140822
Sonork: 100.1594493
Thanks Meter: 1,010
all the tools works in the same way.
it just try one by one each code till find the right one (bruteforce)
if the file is just protected with letters (abcdefg) or just protected with numbers (0123456) it will find very easy, but if the password has letters, numbers and special characters (01kksajAA$$%) it will be almost impossible to find it, cause it may take 2 or 3 years searching the right code.
Br,
Josedavido
The Following 2 Users Say Thank You to josedavido For This Useful Post:
Old 10-05-2012, 21:40   #5 (permalink)
MOHIT_THAREJA's Avatar
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
if the file is just protected with letters (abcdefg) or just protected with numbers (0123456) it will find very easy, but if the password has letters, numbers and special characters (0 will be almost impossible to find it, cause it may take 2 or 3 years searching the right code.
Br,
Josedavido
1kksajAA$$%
if pass like this then we can find pass or not in LBF method?
Old 10-06-2012, 08:00   #6 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 526
yes you can find any type of pass with lbf .. it's depend on your keymask what did you set for lbf database ..... set key a..z. A..Z, 0..9, spcl cerector....
but it take much time ... bcoz it's mix all keymask and try to possibility........
The Following User Says Thank You to ..:: Devil_king ::.. For This Useful Post:
Old 10-08-2012, 11:43   #7 (permalink)
Member: 1810861
Thanks Meter: 6
I use Passware to crack zip files, it can bruteforce the password pretty fast with a decent GPU. They also have a paid service to crack zip files online with their own supercomputers, much like the SL3 services here.
Old 10-08-2012, 19:59   #8 (permalink)
Moderator
Member: 73
Thanks Meter: 537
Thw world is not only BRUTE FORCE...
ARCHPR Help
Regards: Victor
The Following User Says Thank You to Victor For This Useful Post:
Old 10-09-2012, 02:04   #9 (permalink)
Member: 1822272
The onlyway is bruteforce, not possible to have the code in one second !
Old 10-09-2012, 02:53   #10 (permalink)
Moderator
Member: 73
Thanks Meter: 537
Are you sure? .... or You not read exact what is KNOWN PLAINTEXT ATTACK in zip files.
Old 10-09-2012, 03:00   #11 (permalink)
Member: 1822272
@Victor
the message is for me?
Old 10-09-2012, 04:35   #12 (permalink)
Member: 1638066
Thanks Meter: 170
use passware kit u can unlock many files
Old 11-29-2015, 15:11   #13 (permalink)
Member: 1315616
Thanks Meter: 5
plz..help me...zip file unlock tool download link.....plz......?
Old 11-29-2015, 19:11   #14 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
Originally Posted by informastore View Post
@Victor
Do not challenge him.. he is old one in this field..
Old 11-29-2015, 19:21   #15 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 713
Victor , Sir i need your help.. in this section i have created a thread named as qcn issues .. No body is ready to help me..
Page generated in 0.19381 seconds with 8 queries
