GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
11-04-2016, 12:39 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: united kingdom
Member: 2549105 Status: Offline Thanks Meter: 4 | check phone rooting from PC I need a way what will run from a computer so all I have to plug the phone in and then use a program check the phone. I know about root checker that will run from an SD. So I looking for something like that, that will run on a PC |
11-04-2016, 16:55 | #2 (permalink) |
No Life Poster Join Date: Jul 2007 Location: tr
Member: 539148 Status: Offline Thanks Meter: 2,174 | Hi, Type at shell console line this command, adb shell id, if you receive uid=2000 answer then device not rooted, if you receive uid=0 answer then device rooted. BR, Dicle_Gsm |
The Following 2 Users Say Thank You to dicle_gsm For This Useful Post: |
11-12-2016, 14:17 | #5 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1501506 Status: Offline Thanks Meter: 47 | That's because it depends on if phone is rooted via ENGINEERING kernel or not. Dicle_Gsm command will work if it's ENGINEERING rooted. If you rooted by cf auto root you should be able to use the "adb shell su -c id" I believe. Then if the phone hasn't had root prompt accepted, you should see it pop up asking for permissions. Sent from my SM-G935T using Tapatalk |
