GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
07-20-2011, 10:18 | #1 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Australia/Melbourne
Member: 1610809 Status: Offline Sonork: 100.1616347 Thanks Meter: 23 | coment Bat File insert to memo.. Help any can help me? how BAT file from the command inserted to the memo and then call the cmd to run it |
07-20-2011, 10:35 | #2 (permalink) |
Product Manager Join Date: Apr 2002 Location: nckDongle
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | you must use pipes for this, and load console application in stream. See microsoft API, all is good documented. |
The Following User Says Thank You to orbita For This Useful Post: |
07-20-2011, 14:43 | #3 (permalink) |
Insane Poster Join Date: May 2008 Location: Poland ;) Age: 38
Member: 776944 Status: Offline Thanks Meter: 26 | Using pipes to catch console output. Here's an example: How to catch console output - Delphi Pages Forums |
The Following User Says Thank You to McManiek For This Useful Post: |
07-29-2011, 07:39 | #5 (permalink) |
Member: 1610809 Status: Offline Sonork: 100.1616347 Thanks Meter: 23 | function RunProg(Cmd, WorkDir: String): string; Form1.Memo1.Tex:=('Javaloader -u load OS\Bla_Bla.cod'+ 'Bla_bla!.Cod','C:\'); what this true ?? what CMD runprog to one line ? |
07-30-2011, 11:13 | #6 (permalink) |
Member: 11170 Status: Offline Sonork: 1603694 Thanks Meter: 6,944 | Code: procedure TForm1.RunDosInMemo(DosApp:String;AMemo:TMemo) ; const ReadBuffer = 1048576; var Security : TSecurityAttributes; ReadPipe,WritePipe : THandle; start : TStartUpInfo; ProcessInfo : TProcessInformation; Buffer : Pchar; BytesRead : DWord; Apprunning : DWord; begin With Security do begin nlength := SizeOf(TSecurityAttributes) ; binherithandle := true; lpsecuritydescriptor := nil; end; if Createpipe (ReadPipe, WritePipe, @Security, 0) then begin Buffer := AllocMem(ReadBuffer + 1) ; FillChar(Start,Sizeof(Start),#0) ; start.cb := SizeOf(start) ; start.hStdOutput := WritePipe; start.hStdInput := ReadPipe; start.dwFlags := STARTF_USESTDHANDLES + STARTF_USESHOWWINDOW; start.wShowWindow := SW_HIDE; if CreateProcess(nil, PChar(DosApp), @Security, @Security, true, NORMAL_PRIORITY_CLASS, nil, nil, start, ProcessInfo) then begin repeat Apprunning := WaitForSingleObject (ProcessInfo.hProcess,100) ; Application.ProcessMessages; until (Apprunning <> WAIT_TIMEOUT) ; Repeat BytesRead := 0; ReadFile(ReadPipe,Buffer[0], ReadBuffer,BytesRead,nil) ; Buffer[BytesRead]:= #0; OemToAnsi(Buffer,Buffer) ; AMemo.Text := AMemo.text + String(Buffer) ; until (BytesRead < ReadBuffer) ; end; FreeMem(Buffer) ; CloseHandle(ProcessInfo.hProcess) ; CloseHandle(ProcessInfo.hThread) ; CloseHandle(ReadPipe) ; CloseHandle(WritePipe) ; end; end; function TForm1.RunCaptured(const _dirName, _exeName, _cmdLine: string): Boolean; var start: TStartupInfo; procInfo: TProcessInformation; tmpName: string; tmp: Windows.THandle; tmpSec: TSecurityAttributes; res: TStringList; return: Cardinal; i:integer; begin Result := False; try { Setze ein Temporäres File } { Set a temporary file } tmpName := 'Test.tmp'; FillChar(tmpSec, SizeOf(tmpSec), #0); tmpSec.nLength := SizeOf(tmpSec); tmpSec.bInheritHandle := True; tmp := Windows.CreateFile(PChar(tmpName), Generic_Write, File_Share_Write, @tmpSec, Create_Always, File_Attribute_Normal, 0); try FillChar(start, SizeOf(start), #0); start.cb := SizeOf(start); start.hStdOutput := tmp; start.dwFlags := StartF_UseStdHandles or StartF_UseShowWindow; start.wShowWindow := SW_HIDE;///SW_Minimize; { Starte das Programm } { Start the program } if CreateProcess(nil, PChar(_exeName + ' ' + _cmdLine), nil, nil, True, 0, nil, PChar(_dirName), start, procInfo) then begin SetPriorityClass(procInfo.hProcess, Idle_Priority_Class); WaitForSingleObject(procInfo.hProcess, Infinite); GetExitCodeProcess(procInfo.hProcess, return); Result := (return = 0); CloseHandle(procInfo.hThread); CloseHandle(procInfo.hProcess); Windows.CloseHandle(tmp); { Die Ausgaben hinzufügen } { Add the output } res := TStringList.Create; try res.LoadFromFile(tmpName); for i:=0 to res.Count-1 do If pos('Uploading RAM Image',res[i])=0 then Memo1.Lines.Add(res[i]); finally res.Free; end; Windows.DeleteFile(PChar(tmpName)); end else begin Application.MessageBox(PChar(SysErrorMessage(GetLastError())), 'RunCaptured Error', MB_OK); end; except Windows.CloseHandle(tmp); Windows.DeleteFile(PChar(tmpName)); raise; end; finally end; CloseThread(hThread); end; here is 2 function for your needs , chose one best for you. |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
