GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
11-09-2005, 22:51 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | u must have correct interface and software for the uController in hand. then pray for no code protection, or u must go learn some indepth stuffs.... |
11-10-2005, 11:02 | #4 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | there is a few ways i have read on the internet. for some controller, you must scrape off the outer plastic of the IC very carefull then use some UV light to get the code. you can also use a pulsed voltage on some pin while trying to read and this will work. each controller is different tho. i think these days u will not find such things online, everyone will make you pay... |
11-10-2005, 11:05 | #5 (permalink) |
Member: 7653 Status: Offline Thanks Meter: 823 | i also read about one method, very expensive. scrape off the housing of IC and connect probes (must be pico probes for the size hehe). then you can "catch" the code as it passes along the busses. thats how the big security companies will break a PIC for you, im sure. but only when you pay them £££££££££££££££££££ |
Simple Questions From a Simple Person | Jekmyster | Sony Ericsson | 0 | 09-18-2007 06:48 |
simple question needs simple answer!!! | hairyeyeball | Nokia Base Band 5 ( BB-5 ) | 1 | 09-07-2006 15:44 |
Simple question, please simple answer regarding A920 | peshta | Motorola P2k | 0 | 05-03-2005 23:26 |
Simple question about algorithm used to generate unlocking codes | drzonca | x1x to x45/x50 | 1 | 02-16-2002 16:17 |
Simple question about 3210 | jivkobg | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-04-2001 23:06 |
