GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
01-28-2018, 10:23 | #1 (permalink) |
Banned Join Date: Oct 2016 Location: South Africa
Member: 2635974 Status: Offline Thanks Meter: 45 | Help MTK Format Example: input start address and end address to format. If someone have solution INBOX! |
01-29-2018, 00:51 | #2 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | And what part needs help ? Partition definitions (start addresses and length) are written in each scatter file, for that particular model that you will format. Open scatter file with notepad++ and check/search for desired partition (ie: frp), then input address and length into manual format field, press start and connect device. Of course, you will need scatter file for that device you are working with. (contained either in factory rom package, or made by box etc.) that's it. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
01-29-2018, 09:22 | #3 (permalink) | |
Freak Poster Join Date: Dec 2005 Location: TUNISIA
Member: 208914 Status: Offline Thanks Meter: 396 | Quote:
