Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 09-09-2017, 23:35   #1 (permalink)
Member: 2674769
Thanks Meter: 17
ESN from MEID HASH SHA` proplem!
need to calculate hash for meid to get esn hex Delphi code
put thare is proplem
I test the unit with abc it worked ok like this
Password := 'abc';
Digest := CalcSHA1 (Password [1], Length (Password));
Str := SHA1DigestToHex (Digest);
msg(str,clred);
the hash is
a9993e364706816aba3e25717850c26c9cd0d89d ok no proplem
but for example I put this meid = A10000009296F2
Password := 'A10000009296F2';
msg(str,clred);
the hash calculated is
4cf522d69e6334472377eed5959dbfaa422005dc it is wrong
need good calculator for Delphi please
Old 09-10-2017, 11:45   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@doctorsu
In programming before running start walking first.
Basic thing is first to learn is what data is .. ascii or binary.
ascii A10000009296F2 = 4131303030303030393239364632
binary A10000009296F2 = A10000009296F2
sha1 of binary is 2D0E6EFEA8F8082C9703CF6636C4A2195C75B7ED
8075B7ED is your esn.
The Following 2 Users Say Thank You to stanner_austin For This Useful Post:
Old 09-11-2017, 00:20   #3 (permalink)
Member: 2674769
Thanks Meter: 17
can you explain more how did you get the sha1 of binary
I have exe console for this but I wont to write in Delphi
Old 09-11-2017, 18:25   #4 (permalink)
Nishith's Avatar
Member: 1766148
Sonork: 100.1614494
Thanks Meter: 490
This might be helpful: SHA-1 Calculator
The Following User Says Thank You to Nishith For This Useful Post:
Old 09-22-2017, 22:17   #5 (permalink)
Member: 2674769
Thanks Meter: 17
hiiiiiiiiiiiiiiiii
solved python
import hashlib
meid = raw_input("").upper()
s = hashlib.sha1(meid.decode('hex'))
    #decode the hex MEID (convert it to binary!)
pesn = "80" + s.hexdigest()[-6:].upper()
    #put the last 6 digits of the hash after 80
print " " + pesn
Old 10-02-2017, 22:55   #6 (permalink)
Member: 2674769
Thanks Meter: 17
this good and working but what type of calculator is this
is thare similer for Delphi
Old 10-03-2017, 01:20   #7 (permalink)
Member: 2674769
Thanks Meter: 17
done in Delphi finally
HexStr := 'A10000009296F2';
BinaryStream := TMemoryStream.Create;
try
BinaryStream.Size := Length(HexStr) div 2;
if BinaryStream.Size > 0 then
begin
HexToBin(PAnsiChar(HexStr), BinaryStream.Memory, BinaryStream.Size);
// read into the buffer
j2 := BinaryStream.Read(buffer,Sizeof(buffer));
x := TDCP_sha1.Create(nil);
x.Init;
x.Update(buffer,j2);
SetLength(HashDigest, x.GetHashSize div 8);
x.Final(HashDigest[0]);
for j := 0 to Length(HashDigest) - 1 do // convert it into a hex string
s := s + IntToHex(HashDigest[j],2);
end;
finally
x.Free;
BinaryStream.Free;
end;
trim(s);
msg(s,clyellow);
this is outut tmemo1
thanks
stanner_austin
Ni****h
The Following User Says Thank You to doctorsu For This Useful Post:
Page generated in 0.24428 seconds with 8 queries
