GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
07-15-2011, 10:28 | #1 (permalink) |
Junior Member Join Date: Dec 2009
Member: 1190239 Status: Offline Thanks Meter: 0 | has been running main P8P67 pro 4 HD 6970 card or not? has been running main P8P67 4 HD 6970 card or not? i'm try not run with win7 64bit Last edited by aloxing; 07-15-2011 at 10:36. |
07-16-2011, 19:57 | #5 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | 6970 is single gpu card so it should work If any problems with the crossfire just use dummy plugs to make them working all. Be carefull as tthe power usage of these cards is high.. can go up to 250w each card with just a minimum oc. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
07-17-2011, 16:19 | #7 (permalink) |
Member: 1190239 Status: Offline Thanks Meter: 0 | Code: 6970 is single gpu card so it should work If any problems with the crossfire just use dummy plugs to make them working all. Be carefull as tthe power usage of these cards is high.. can go up to 250w each card with just a minimum oc. thank!!!! |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
