Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 01-18-2006, 11:06   #1 (permalink)
Member: 222290
Smile Help ! AT Command Expert advice needed...
Hi everyone !
I am writing an application for my Samsung that would be able to use some very long numbers as I need to automate the sending of DTMF's to the other side of the line, (codes, passwords etc.)
so for example I need to call number 0453652, send it the code of 123456 with the password of 1111.
so I might use
>AT+CPBS=SM
>AT+CPBW=1,"0453652" // These two lines store the number 0453652 in memory #1
Now we dial:
>ATD>1;
this will issue a voice call to the number we stored. What I need now, is to make the mobile also automate the sending of dtmf's right after that.
If you check out the ATD command, you see that Samsung gives you this:
>ATD
1 2 3 4 5 6 7 8 9 0 * # + A B C D P T W , !
I know P is a pause, W is Wait. , is pause also, ! is hangup for half a sec.
What I tried to do was that:
ATD>1P123456P1111;
Thinking the phone would call stored number #1, pause for a while and then continue dialing 123456 (code), and then 1111 (password), in voice mode.
What happens is that it calls #1 but in Data mode .
And I can't make out how to do this in voice mode.
I need atd>1 instead of atd0453652 because it saves a lot of space (6 characters in this example) as the length of the command is limited to 40 characters long.
Please help !
thanks !!
Old 01-18-2006, 14:04   #2 (permalink)
Member: 222290
Am I correct about the forum btw ? I mean, is the post in the right place ?
thanx
Old 01-18-2006, 16:42   #3 (permalink)
Member: 1528
Thanks Meter: 10
Check if you hav in phone selected data call.
Old 01-18-2006, 16:47   #4 (permalink)
Member: 222290
Check if I have a data call ?
I mean, when I dial ATD923874 (without ';') I get a data call. If I dial ATD>1 (without ';') I get a data call.
I am not sure I completely understood...
Did you mean if I can select data/voice call ?
Old 01-18-2006, 19:06   #5 (permalink)
Member: 1528
Thanks Meter: 10
yes in phone if you have enabled voice call or data call
Old 01-18-2006, 22:04   #6 (permalink)
Member: 222290
Well I guess I have both. But what should I do with it ?
Experts Need Help - Do I need these resistors ? Seedy Nokia Hardware & Hardware Repair 4 12-11-2007 10:11
Experts Need Help - Do I need these resistors ? Seedy Nokia Hardware & Hardware Repair 1 04-12-2007 10:41
Need "Dev_list.fps" Updated File !! help from Any Expert needed !!! Aamir_Zia Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-19-2004 16:01
AT command +CMGS NEED HELP !!! simonloo Old Ericsson Phones & Sony Phones 0 03-08-2004 12:33
To Maxon experts-Need Litle help dominik Various 0 11-18-2003 11:02
Page generated in 0.19291 seconds with 9 queries
