Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 01-28-2018, 09:23   #1 (permalink)
Member: 2635974
Thanks Meter: 19
Help MTK Format
Anyone can help me to format any partition via cmd SP FLASHER or other tool?
Example: input start address and end address to format.
If someone have solution INBOX!
Old 01-28-2018, 23:51   #2 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 5,185
And what part needs help ?
Partition definitions (start addresses and length) are written in each scatter file,
for that particular model that you will format.
Open scatter file with notepad++ and check/search for desired partition (ie: frp),
then input address and length into manual format field,
press start and connect device.
Of course, you will need scatter file for that device you are working with.
(contained either in factory rom package, or made by box etc.)
that's it.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 01-29-2018, 08:22   #3 (permalink)
mouradsamsung's Avatar
Member: 208914
Thanks Meter: 391
if i'm anderstind good he need format partitions with sp flash tool by console mode
that's it.
b.r.
Alex
if im anderstind good he need format partition with spflashtool by console mode
Old 02-14-2018, 09:42   #4 (permalink)
Member: 2635974
Thanks Meter: 19
exactly!
Page generated in 0.20480 seconds with 7 queries
