how to add more profiles inside the dashboard EXE ( huawei connects ) ? hello there i wanted to add more profiles to the huawei dashboard , i had the ISO that extracted by ( H D T ) and i tried this method ( i created profiles in the mobile partner then copied the user data folder to the common folder then created the final EXE ) but when i installed the new dashboard i couldn't find the profiles i created !. i've tried installing the DB in other PC but no success , i reversed the whole operation ( by resource hacker ) to be sure that the file added successfuly , and it was , by the way from which folder the dashboard reads the profiles ? coz i unistalled the dashboard and installed a new one but still using the old profile list ! ( i already deleted the D B folder from program files also the user data file ) here is the ISO file http://dl.dropbox.com/u/9514941/Suda...hasanmh%20.rar and here is the user data folder http://dl.dropbox.com/u/9514941/userdata.rar tell me what mitake i made ? best regards bro hasanmh |
Hey hasan How r u doing?? What i remember that progiles of mobile partner are saved in the mobile partner folder in program files. Hope that this helps Will give u the exact dir when i go to PC |
yes they saved there in ( user data ) folder ( before installing the dashboard there is no user data folder inside the EXE ) my friend ( BJFROG ) said : Quote:
I'll try it tomorrow :D and will reply with results |
Hi! Bro if u want to make another profile... Its very simple... Go to tools... Options... Profile management... New now write profile name... Click on static Write apn name like internet etc... press save... Thats it... BR |
every body knows how to create a new profiles at the dashboard , i need to inject them inside the dashboard setup file , so that when i install it again in any other PC just use the profiles directly without adding new profiles . |
I did it !! :D Please give me a link of the dashboard you want to edit and the APNs,i'll test it first and i will tell you how did I do it :) |
^ here http://dl.dropbox.com/u/9514941/Suda...hasanmh%20.rar APNs Code: ZAIN sudan |
Must it be on the sudani one ???? if you do it to mobile partner it will work :D |
i just want to use our dashboards . any way thank you for trying to help me , waiting for other members maybe the have defferent methodes . |
I promise i will retry again :D and hope i can do it |
UP help me friends .... |
i knew how it works but the problem is either to work on vista/7 or on xp i can't do it for both :S |
UTPS21.005.11.00.356_MAC21.005.11.00.356_LNX21.005 .11.01.356.7z with zain n mtn profile |
The problem is sidani one is make a secutity that it doen't use the userprofile.prof from program files folder but from the programdata folder which it has a differnt directory in xp and vista/7 |
