GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
08-27-2016, 21:06 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2614908 Status: Offline Thanks Meter: 0 | How to change 4G only mode to 4G,3G,HSPA All network accept mode My router is huawei b310s-925. Currently it Unlocked firmware and NCK. But still not accept other bands instead 4g. I was put as auto select from following commands but it change to "4g only" mode to "auto" but not accept other bands AT ^ SYSCFGEX = "00", 3FFFFFFF, 1,2,800C5 ,, all so try out AT^SYSCFG=14,2,3FFFFFFF,2,4 My current firware and web UI version as follows flash 21.313.05.00.00 webUI 17.100.09.00.03 Im looking a solution in following criteria 1. Sometime this will work with some firmware version developed to both 3g and 4g version (from some operator base branded firmware) 2. Sometime AT command may be available instead above. 3. Sometime this b310s-925 version restrict 3G and HSPA from chip level GUYS GIVE ME SOLUTION FOR THIS |
02-12-2017, 01:30 | #3 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2633711 Status: Offline Thanks Meter: 2 | I think that first u need to check: AT^SYSCFGEX=? - u will get full info. On huawei b593s-22 it will be: AT^SYSCFGEX="030201",3FFFFFFF,2,4,7FFFFFFFFFFFFFFF ,, And for huawei e3372s-153: AT^SYSCFGEX="00",3FFFFFFF,1,2,800C5,, so it depends of the model. U can also try program ltewatch for huawei or e5186 toolbox, both has ability to set 4g or 3g or auto in easy way. |
The Following User Says Thank You to franek_dolas For This Useful Post: |
05-21-2019, 10:06 | #4 (permalink) |
Junior Member Join Date: May 2009
Member: 1029722 Status: Offline Sonork: raj Thanks Meter: 0 | huawei b310s-925.g only Hello, My router is huawei b310s-925. Currently it Unlocked firmware and NCK. But still not accept other bands instead 4g. I was put as auto select from following commands but it change to "4g only" mode to "auto" but not accept other bands |
