Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 03-21-2019, 06:54   #1 (permalink)
Member: 2773088
Thanks Meter: 24
what keyword to search for
dear friends so I found out a lot of stuff and I pretty much 99% there to be able to read the cert from any qcom phone I just have one problem and that is what keyword should I search for to locate the imeisign and pubkey and pubkeysign also do I need to be rooted or no to look at them?
Old 03-21-2019, 19:50   #2 (permalink)
Member: 2773088
Thanks Meter: 24
SurfaceFlinger: FLAG check for SEC_FEATURE_INTERNAL_ONLY … how can I know what is written over here what step am I missing??
Old 03-21-2019, 22:38   #3 (permalink)
Member: 2773088
Thanks Meter: 24
33 35 39 32 35 39 30 37 37 34 38 36 37 31 10 08 00 38 30 32 43 34 39 39 44 11 0f 00 33 35 39 32 35 39 30 37 37 34 38 36 37 31 39 00 00 b6 6b 5a a5 13 00 eb 1f 3f 23 d8 38 02 88 84 69 c0 a8 cd 00 0e 00 00 00 b6 6b 5a a5 11 00 eb 1f 3f 21 78 68 03 88 84 69 c0 a8 cd 00 00 00 00 00 b6 6b 5a a5 10 00 eb 1f 3f 20 70 39 02 88 84 69 c0 a8 cd 00 b6 6b 5a a5 10 00 eb 1f 3f 20 80 39 02 88 84 69 c0 a8 cd 00 b6 6b 5a a5 1d 00 8e 13 d9 47 b6 6b c0 a8 cd 00 01 10 00 00 09 01 00 04 00 41 00 04 00 13 01 00 01 00 00 00 b6 6b 5a a5 24 00 8f 13 49 6d b7 6b c0 a8 cd 00 01 17 00 80 09 01 02 04 00 41 00 0b 00 02 04 00 00 00 00 00 13 01 00 03 b6 6b 5a a5 19 00 8e 13 ca 76 be 6b c0 a8 cd 00 01 0c 00 00 03 01 00 13 00 4d 00 00 00 00 00 00 b6 6b 5a a5 3e 00 8f 13 02 9d be 6b c0 a8 cd 00 01 31 00 80 03 01 02 13 00 4d 00 25 00 02 04 00 00 00 00 00 10 02 00 00 00 11 02 00 00 00 14 03 00 00 00 00 27 04 00 00 00 00 00 2f 04 00 00 00 00 00 00 00 b6 6b 5a a5 19 00 8e 13 b4 87 c6 6b c0 a8 cd 00 01 0c 00 00 03 01 00 14 00 41 00 00 00 00 00 00 b6 6b 5a a5 28 00 8f 13 f9 3f c7 6b c0 a8 cd 00 01 1b 00 80 03 01 02 14 00 41 00 0f 00 02 04 00 00 00 00 00 10 01 00 01 11 01 00 01 b6 6b 5a a5 19 00 8e 13 db 29 c8 6b c0 a8 cd 00 01 0c 00 00 03 01 00 15 00 4d 00 00 00 00 00 00 b6 6b 5a a5 3e 00 8f 13 85 3f c8 6b c0 a8 cd 00 01 31 00 80 03 01 02 15 00 4d 00 25 00 02 04 00 00 00 00 00 10 02 00 00 00 11 02 00 00 00 14 03 00 00 00 00 27 04 00 00 00 00 00 2f 04 00 00 00 00 00 00 00 b6 6b 5a a5 19 00 8e 13 70 3e 03 6c c0 a8 cd 00 01 0c 00 00 03 01 00 16 00 4d 00 00 00 00 00 00 b6 6b 5a a5 3e 00 8f 13 d0 5c 03 6c c0 a8 cd 00 01 31 00 80 03 01 02 16 00 4d 00 25 00 02 04 00 00 00 00 00 10 02 00 00 00 11 02 00 00 00 14 03 00 00 00 00 27 04 00 00 00 00 00 2f 04 00 00 00 00 00 00 00 b6 6b 5a a5 19 00 8e 13 14 06 09 6c c0 a8 cd 00 01 0c 00 00 03 01 00 17 00 4d 00 00 00 00 00 00 b6 6b 5a a5 3e 00 8f 13 ba 39 09 6c c0 a8 cd 00 01 31 00 80 03 01 02 17 00 4d 00 25 00 02 04 00
Old 03-25-2019, 08:31   #4 (permalink)
Member: 2773088
Thanks Meter: 24
FLog_radio where am I and where is the cert???
Old 07-12-2019, 00:18   #5 (permalink)
Member: 1903107
Sonork: 12345
Thanks Meter: 2
Do you have ramdump too to read the cert
Old 07-12-2019, 09:33   #6 (permalink)
Member: 2773088
Thanks Meter: 24
i can get a ramdump from anyphone i have on hand its not a problem its just that i cant find the location of the cert in the dump i have looked everywhere but i just get bored after a couple of weeks then stop because i couldnt find any help at all
lol
and then i stay i a couple of days then try again no one is willing to help at all
Old 07-12-2019, 14:53   #7 (permalink)
Member: 1903107
Sonork: 12345
Thanks Meter: 2
IMEI GURUS TOOL USING THIS FILTER AFTER DOING RAMDUMP
Public Sub qcn_AppendConsoleText(ByVal textin As String)
Dim str As String = Regex.Replace(Regex.Replace(textin, "^\s+$[\r\n]*", "", RegexOptions.Multiline).Trim, ChrW(8), "", RegexOptions.Multiline).Trim
If (Not str.Contains("Microsoft") AndAlso Not str.Contains("AppData")) Then
If str.Contains("%") Then
If Form1.currentlog.Text.Contains("%") Then
Dim builder As New StringBuilder
Dim length As Integer = Form1.currentlog.Lines.Length
Dim i As Integer
For i = 0 To length - 1
If ((((Form1.currentlog.Lines(i) <> "") AndAlso (Form1.currentlog.Lines(i) <> Environment.NewLine)) AndAlso ((Form1.currentlog.Lines(i) <> " ") AndAlso (Not Form1.currentlog.Lines(i) Is Nothing))) AndAlso ((Form1.currentlog.Lines(i) <> ChrW(13) & ChrW(10)) AndAlso (Form1.currentlog.Lines(i) <> ChrW(10)))) Then
If Form1.currentlog.Lines(i).Contains("%") Then
builder.Append(str)
Else
builder.Append((Form1.currentlog.Lines(i) & ChrW(13) & ChrW(10)))
End If
End If
Next i
Dim str2 As String = Regex.Split(str, "%")(0)
Me.qcnprogress.Value = Convert.ToInt32(str2)
Form1.currentlog.Text = builder.ToString
ElseIf ((((str <> "") AndAlso (str <> Environment.NewLine)) AndAlso ((str <> " ") AndAlso (Not str Is Nothing))) AndAlso ((str <> ChrW(13) & ChrW(10)) AndAlso (str <> ChrW(10)))) Then
Form1.currentlog.AppendText((str & ChrW(13) & ChrW(10)))
End If
End If
End If
End Sub
Page generated in 0.19042 seconds with 8 queries
