Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-07-2017, 10:09   #1 (permalink)
TaiChi gossip's Avatar
Member: 2418095
Thanks Meter: 124
How to modify the Odin skip: This is ENG binary Please Use USER binary
Can modify the Odin to skip this validation???
Old 04-21-2019, 14:05   #2 (permalink)
alorpothe's Avatar
Member: 2235775
Thanks Meter: 276
Just flash boot recovery sytem cach 100% will be Done
Old 04-22-2019, 07:59   #3 (permalink)
.:D:.'s Avatar
Member: 2561651
Sonork: 100.*******
Thanks Meter: 259
or is this possible we can flash modify rom on locked boot loaders?
Old 04-22-2019, 08:13   #4 (permalink)
CRM
Member: 1176826
Sonork: 100.1604160
Thanks Meter: 54
Extract Firmware with 7zip,and and select partition you want to flash,and make .tar file using 7zip,then flash using odin...
Old 01-27-2020, 11:41   #5 (permalink)
gencom's Avatar
Member: 1918391
Thanks Meter: 65
what is meaning why eng boot cant flash
Old 01-29-2020, 13:44   #6 (permalink)
hitesh2000's Avatar
Member: 365730
Thanks Meter: 84
i assume you want odin to skip some piece of code if i am right first of all you need to identify secutity used in odin download re packer detector and detect the packing used then second unpack the exe thired use olly debuger to modify your .exe
The Following User Says Thank You to hitesh2000 For This Useful Post:
Page generated in 0.20509 seconds with 7 queries
