Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > Gsm Programming & Reverse Engineering
Gsm Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 06-01-2002, 07:16   #1 (permalink)
Member: 12494
How to write a soft for unlocking phone
Hi!
I'm a programmer and i'm trying to understand how a software for unlocking phones works, because i'm going to write a one. Unfortunately i can't find any documentation about communication protocol between phone and pc, what kind of processors are used in phone, how to disassemble phone's firmware. If anyone could help me i'd be glad.
Sorry for my bad grammatical errors.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on Facebook
Old 06-02-2002, 05:28   #2 (permalink)
Lead's Avatar
Member: 1841
Thumbs up Re: How to write a soft for unlocking phone
It is not as easy as you might think. There is no communication protocol documentation released by the mobile phone manufacturing companies. Everything you can find is based on reverse-engineering. When writing new unlocking software, one is interested mainly in the bootstrap protocol, rather that in the high level AT-commands, although there may be some exceptions. To find out the bootstrap protocol for a totally new phone, you may visit service center and ask them to allow you to sniff serial (in the better case) communication and hope it will not be crypted. For an older phone you may do it at home, by sniffing communication between your phone and some free or dongled unlocking program. In most cases you will find out that after you press the power button on the phone, the computer sends some kind of code into the phone. This is a program that runs inside the mobile phone, takes control over it and handles the whole communication with PC that follows. You may then analyze the code, modify it to be able to read the whole phone flash. This is the point when the hardest work takes place. You will spend many weeks analysing the phone firmware and if you are a lucky person, you will find a way to unlock the phone. However, the new phones, like Nokia 8310, 6310, 6510 and Ericsson R520m, T39m, T65s, T68m, T68i are well protected. Nokia now uses crypted boot code and Ericsson requires to pass through some flash authorization procedure to be able to send boot code to the phone.
Anyway, I did not want to discourage you. The processors used in the actual phones are:
  • ARM (Nokia, Motorola, Sagem, Trium,...)
  • Z80 (Ericsson,...)
  • AVR (Ericsson)
  • 80C166 (Siemens, Sagem,...)
  • Motorola, e.g. 68332 (Motorola)
This is a list of processors used in mobile phones I could remember of. To disassemble code, I recommend you to buy the Interactive Disassembler Pro Advanced from DataRescue company. It is really a good reverse-engineering tool and is worth buying it.
May the force be with you
Best regards,
Lead.
Old 06-02-2002, 11:30   #3 (permalink)
Super Moderator
Member: 3756
Very nice info.!
Thanks a lot Lead.
Bye.
Old 06-07-2002, 17:12   #4 (permalink)
mujie's Avatar
Member: 8304
LEAD is the MASTER
Old 01-07-2003, 20:12   #5 (permalink)
Member: 3041
Yes LEad is good )
Old 01-08-2003, 01:17   #6 (permalink)
kulibin's Avatar
Member: 16452
Where find manuals for ARM (Nokia, Motorola, Sagem, Trium,...)
Old 01-08-2003, 01:23   #7 (permalink)
Lead's Avatar
Member: 1841
Maybe this could help you:
http://www.arm.com/arm/documentation?OpenDocument
Old 01-08-2003, 09:13   #8 (permalink)
Wings's Avatar
Member: 255
Thank you lead for the info .
regards
Old 01-08-2003, 11:04   #9 (permalink)
Member: 18477
lead is lead
Old 01-08-2003, 14:41   #10 (permalink)
Member: 12371
One question to Lead:
Is firmwares for Nokia DCT4 phones are also crypted?
Old 01-08-2003, 14:49   #11 (permalink)
Lead's Avatar
Member: 1841
Yes, mostly.
Old 01-08-2003, 14:52   #12 (permalink)
Member: 12371
Well, where can I take not crypted firmware or maybe fulldump of new nokia phone?
Old 01-08-2003, 14:57   #13 (permalink)
Lead's Avatar
Member: 1841
The easiest way is to desolder the flash chip and read its content using some chip programmer.
Old 01-08-2003, 14:59   #14 (permalink)
Member: 12371
do someone have this dump?? I don't have enough hardware to desolder the chip...
Old 01-08-2003, 15:09   #15 (permalink)
Lead's Avatar
Member: 1841
I doubt anyone will give you the flash dump for free.
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.12120 seconds with 7 queries
