GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
02-23-2015, 15:56 | #1 (permalink) |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 537 | HTC Codes!!! Why factory codes are different from real unlock codes. Example: HTC Desire 310 imei: 351912064140446 factory code: 20164128 real unlock code: 75897934
__________________ You'll die as you lived in a flash of the blade, in a corner forgotten by no one You lived for the touch for the feel of the steel One man, and his honor. Last edited by Victor; 02-23-2015 at 16:59. |
02-25-2015, 06:06 | #3 (permalink) | |
Member: 73 Status: Offline Thanks Meter: 537 | Quote:
Here is the question: - Operator change code? (no logic in this) - Or Phone come from factory with code and PREPARED LOCK. - Or phone have automatic mechanism to self change code as HTC ONE S. Regards: Victor
__________________ You'll die as you lived in a flash of the blade, in a corner forgotten by no one You lived for the touch for the feel of the steel One man, and his honor. | |
03-04-2015, 17:47 | #5 (permalink) | |
Insane Poster Join Date: Jan 2013
Member: 1876160 Status: Offline Thanks Meter: 30 | Quote:
A branded phone will have your carrier’s logo during boot (usually), and it will also usually have apps which are installed by the carrier and cannot be removed. Then I think Operator changed this code. | |
03-07-2015, 16:32 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Dec 2013 Location: XK Age: 26
Member: 2089356 Status: Offline Sonork: Threema: 3N5W6VV9 Thanks Meter: 520 | Also victor, I have same question like you, some of htc codes always fail, and replay i get is operator changed codes ! and i also talked directly to my sources inside operator ! they are to bassic on encoding ! they don't change anything, and also i wonder ! how some get complete htc database ! how they taken ! i am glad victor for opening this thread, i am sure we will get an answer. ! |
03-08-2015, 01:38 | #9 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | this code writen on ''htc p51'' partition.. near imei area..i can acces it via jtag...it has written by htc ''manufecter'' during first flash in hex format...alsohtc is sharing sim locks and factory codes with operators which buy this models from (High Tech Computers)HTC. simlock code is NCK CODE |
03-09-2015, 17:57 | #11 (permalink) |
Member: 73 Status: Offline Thanks Meter: 537 | Not 100% but is similar. Factory codes are as default codes on all levels. And lock is with customized code.
03-09-2015, 23:34 | #12 (permalink) | |
No Life Poster Join Date: Apr 2004
Member: 61389 Status: Offline Thanks Meter: 193 | Quote:
The p51 business is just a small part. The nck-imei-cid are simple plain text. No crc, no any kind protection The simlock area sometimes encoded with AES128 like the desireX Or the desire300 sometimes not like the desire500 and desireC. I belive it's a simple bug. And lot more bugs (I'v seen some interesing things in IDA ) If you have root acces you don't need jtag. In this case you able to dump all partitions. | |
The Following User Says Thank You to jodge For This Useful Post: |
03-10-2015, 00:21 | #14 (permalink) |
Member: 73 Status: Offline Thanks Meter: 537 | ... Another pair! Code: GBKey 1.72 Model selected : HTC Desire 310 Power off the phone and insert USB cable now... Detected : PreLoader USB VCOM Port (COM13) Waiting response... Detected : Gadget CDC VCOM Driver (COM29) Connecting... Reading info... IMEI : 351912063566211 Connecting... Connected to server Ok Checking GBKey... GBKey Ok Model : HTC Desire 310 IMEI : 351912063566211 NW Lock : OPEN Code : 30096139 <<<<<------------ CUSTOMIZED CODE NS Lock : OPEN Code : 09844488 <<<<<------------ FACTORY CODE SP Lock : OPEN Code : 09844488 CP Lock : OPEN SIM Lock : OPEN Writing info... Unlocked Ok
03-10-2015, 08:53 | #15 (permalink) |
Member: 61389 Status: Offline Thanks Meter: 193 | yepp as a said the MTK platform totally different here is a qc platform desire500 p51 screenshot https://www.dropbox.com/s/ukda4qs442gvmqu/hexa.PNG?dl=0 there is just the provider and the nck nothing more @loniryan Code: adb shell su dd if=/dev/block/mmcblk0p7 of=/sdcard/htc.bin |
