GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
04-08-2015, 18:58 | #32 (permalink) | |
Freak Poster Join Date: May 2009 Location: Poland
Member: 1031096 Status: Offline Thanks Meter: 77 | Quote:
Code: adb devices adb push mmcblk0p7.bin /data/local/tmp/mmcblk0p7.bin adb shell su -c "dd if=/data/local/tmp/mmcblk0p7.bin of=/dev/block/platform/msm_sdcc.3/mmcblk0p7" adb reboot pause | |
04-09-2015, 12:45 | #35 (permalink) | |
No Life Poster Join Date: Apr 2004
Member: 61389 Status: Offline Thanks Meter: 193 | Quote:
04-09-2015, 15:20 | #37 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Serbia Age: 40
Member: 49634 Status: Offline Sonork: 100.1671023 Thanks Meter: 71 | when you're s-off you can do anything. there are eng hboots for each phone that gives you full control thru fastboot cmd's. here in my country operators get's simfree phones from HTC and they lock them with random codes at authorised HTC service centres. of course, HTC MTK phones are totally different story, but i belive that's someone is gonna break their ''security'' really fast and they will go free for unlock, cid change, imei repair... |
The Following User Says Thank You to ViperGSM For This Useful Post: |
04-09-2015, 20:22 | #38 (permalink) | |
No Life Poster Join Date: Sep 2000 Location: Romania,Cluj Age: 49
Member: 2203 Status: Offline Thanks Meter: 52 | Quote:
04-09-2015, 23:37 | #39 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
I haven't played with any, but probably similar story for IMEI, CID is changeable thru keypad codes (AFAIK) MTK .... send me one, i'll give it a try ... b.r. Aleksandar
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
04-13-2015, 10:41 | #40 (permalink) |
Member: 61389 Status: Offline Thanks Meter: 193 | There is three ways to change imei on a QC based and S-OFF htc via cable 1: Code: fastboot oem writeimei 12345678912345 if the hboot doesn't contain the writeimei order change the hboot to engineering hboot: Diag - Download - 4shared 3: save the correct partition change the imei and write it back the older models HTC partition (mmcblk0p7) some new models the board_info (mmcblk0p2, mmcblk0p4...etc) the cid change similar Code: fastboot oem writecid 11111111 .. . The mtk based security is a bad joke The only challenge is a Tegra regards |
04-13-2015, 10:52 | #42 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Italy, Bahrain, India Age: 53
Member: 125037 Status: Offline Sonork: 100.1649338 Thanks Meter: 254 | I used to work for a manufacturer.... so apart from "normal" factory units... the manufacturer brands operator orders at the factory, before being dispatched. |
04-16-2015, 09:55 | #44 (permalink) | |
