Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 05-22-2012, 21:12   #1 (permalink)
Member: 984268
Iphone Warranty,Lock Status and Carrier info [DELPHI]
Hi i was bored and checking this thread: how to get iphone waranty & lock state from apple? and decided to make a fast parser and release the code here Credits go to angel25dz
Uses
  WinInet, StrUtils;
function GetUrlContent(const Url: string): string;
var
  NetHandle: HINTERNET;
  UrlHandle: HINTERNET;
  Buffer: array[0..1024] of Char;
  BytesRead: dWord;
begin
  Result := '';
  NetHandle := InternetOpen('Delphi 5.x', INTERNET_OPEN_TYPE_PRECONFIG, nil, nil, 0);
  if Assigned(NetHandle) then
  begin
    UrlHandle := InternetOpenUrl(NetHandle, PChar(Url), nil, 0, INTERNET_FLAG_RELOAD, 0);
    if Assigned(UrlHandle) then
      { UrlHandle valid? Proceed with download }
    begin
      FillChar(Buffer, SizeOf(Buffer), 0);
      repeat
        Result := Result + Buffer;
        InternetReadFile(UrlHandle, @Buffer, SizeOf(Buffer), BytesRead);
      until BytesRead = 0;
      InternetCloseHandle(UrlHandle);
    end
    else
      { UrlHandle is not valid. Raise an exception. }
      raise Exception.CreateFmt('Cannot open URL %s', [Url]);
    InternetCloseHandle(NetHandle);
  end
  else
    { NetHandle is not valid. Raise an exception }
    raise Exception.Create('Unable to initialize Wininet');
end;
procedure Add(D,I:String);
var
  L:TListItem;
begin
  L := Mainform.Listview.Items.Add;
  L.Caption := D;
  L.SubItems.Add(I);
end;
function Split(ToSplit,Start,Stop:String):String;
var
  tmp : String ;
begin
  tmp := Copy(ToSplit,Pos(Start, ToSplit) + Length(Start), Length(ToSplit) - Pos(Start, ToSplit) + Length(Start));
  result := Copy(tmp, 0, Pos(Stop, tmp) - 1);
end;
function ToBoolStr(Str:String):String;
begin
  If Str = 'Y' then result := 'True' else Result := 'False';
end;
procedure TMainform.GetBtnClick(Sender: TObject);
var
  Str:String;
begin
  Str := GetUrlContent('https://selfsolve.apple.com/warrantyChecker.do?sn='+SerialEdit.Text);
  If AnsiContainsStr(Str,'"ERROR_CODE"') then begin
    SkinMessage.MessageDlg('Sorry, but this serial number is not valid. Please check your information and try again.',mtError, mbOKCancel,0);
    exit;
  end else begin
    Listview.Clear;
    Add('Product Iphone',ToBoolStr(Split(Str,'IS_IPHONE":"','"')));
    Add('Has Coverage',ToBoolStr(Split(Str,'PH_HAS_COVERAGE":"','"')));
    Add('Waranty Type',Split(Str,'wc.iphone.hardware.li.short":"','"'));
    Add('Activated',ToBoolStr(Split(Str,'ACTIVATION_STATUS":"','"')));
    Add('Days Remain in Coverage',Split(Str,'DAYS_REM_IN_COV":"','"'));
    Add('Coverage End Data',Split(Str,'COV_END_DATE":"','"'));
    Add('Coverage Value',Split(Str,'HW_COVERAGE_VALUE":"','"'));
    Add('P-Description',Split(Str,'PART_DESCR":"','"'));
    Add('Product Description',Split(Str,'PROD_DESCR":"','"'));
    Add('Purchase Country',Split(Str,'PURCH_COUNTRY":"','"'));
    Add('Carrier',Split(Str,'CARRIER":"','"'));
  end;
end;
Download Bin Here :
http://dl.dropbox.com/u/73988760/MPIphone.exe
Pic :
The Following 11 Users Say Thank You to mustipusti For This Useful Post:
Old 05-22-2012, 21:24   #2 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
good work but not completely information gives
BR,
Old 05-22-2012, 21:35   #3 (permalink)
Member: 984268
BR,
you can add more information by adding such line...
Add('Info',Split(Str,'',''));
Its just a fast sample
Old 05-23-2012, 01:45   #4 (permalink)
abdeslam728's Avatar
Member: 653776
Sonork: 100.1584146
Good work, How to add lock status?
Old 05-23-2012, 05:53   #5 (permalink)
Member: 177036
UploadMB.com
MY VERSION JUST FOR FUN
The Following 4 Users Say Thank You to darmiles For This Useful Post:
Old 05-23-2012, 14:54   #6 (permalink)
BEHBOODI's Avatar
Member: 1222839
Sonork: 100.1603618
good work i add new inf and work fine
Old 05-26-2012, 11:10   #7 (permalink)
Member: 984268
Originally Posted by darmiles View Post
UploadMB.com
Nice. I was to lazy to add more lines lol.
Also.. You can call ToBoolStr(); For the "N" or "Y" Result values.
The Following 2 Users Say Thank You to mustipusti For This Useful Post:
Old 05-26-2012, 18:56   #8 (permalink)
Member: 1733998
Sonork: 100.1627259
THANK you very much !
this tools it's very good !
Old 05-27-2012, 09:07   #9 (permalink)
Member: 1695724
Sonork: 100.1606763
@Darmiles
sir Thumbs Up talaga ako sainyo
hoping matuto din ako ng delphi program
The Following User Says Thank You to m460tH!C For This Useful Post:
Old 06-03-2012, 15:26   #10 (permalink)
Member: 1767418
hello, is possible view uid from this??
Thanks...
Old 06-17-2012, 05:27   #11 (permalink)
.:Mr.Brain:.'s Avatar
Member: 1082040
Sonork: 100.1583839
hi
what is the value to get lock status
thx in advance
Old 07-02-2012, 10:10   #12 (permalink)
Member: 1201970
can you share the full source in delphi.. thanks
Old 07-03-2012, 10:03   #13 (permalink)
platforms's Avatar
Member: 83090
Sonork: 1626857
Full source is in first post.
Old 07-03-2012, 23:49   #14 (permalink)
Member: 1780242
thank you brother it help me a lot
Help: Forgot my 6110 user lock code!! GByte9 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 5 05-10-2012 14:14
my 8810 is phone locked ,can somebody please help duyphuc Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 16 02-01-2012 05:18
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
SP Lock 1&4 dw Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 11 06-26-1999 06:22
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.37755 seconds with 12 queries
