Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 02-21-2018, 04:16   #1 (permalink)
Member: 1025079
Thanks Meter: 311
Kyocera reset commnad need
Hello,
does anyone knows wish command can be sent to factory reset Kyocera user data?
I can enable modem and usb serial port, but don't know wish command can be sent
Thanks in advance.
The Following User Says Thank You to cwcast For This Useful Post:
Old 02-26-2018, 03:35   #2 (permalink)
darmiles's Avatar
Member: 177036
Thanks Meter: 934
Originally Posted by cwcast View Post
Hello,
Thanks in advance.
if the modem connection is enable could you try the ATCOMMAND
br
The Following User Says Thank You to darmiles For This Useful Post:
Old 02-26-2018, 16:55   #3 (permalink)
Member: 1025079
Thanks Meter: 311
Yes, I can enable modem connection and serial port.
Old 03-12-2018, 05:25   #4 (permalink)
bojs's Avatar
Member: 162947
Thanks Meter: 1,145
need exact model of phone bro.
br,
bojs
The Following User Says Thank You to bojs For This Useful Post:
Old 03-13-2018, 17:25   #5 (permalink)
Member: 1025079
Thanks Meter: 311
I was think in general, but here is 2 of the model
E6790
E6820
Old 11-14-2018, 16:00   #6 (permalink)
Member: 2066831
Thanks Meter: 5
If the phone on the screen saver how to reset?
Model E6790
The Following User Says Thank You to Vanillaman For This Useful Post:
Old 11-14-2018, 17:26   #7 (permalink)
Member: 1025079
Thanks Meter: 311
Every Kyocera uses a Different command to reset, if your device has user lock, I can do most of them remotely only.
Old 11-14-2018, 20:02   #8 (permalink)
Member: 2066831
Thanks Meter: 5
When translating, an error, the desktop does not load, I can not turn on developer mode
Also I can not go into recovery and fastboot mode
Old 11-15-2018, 03:57   #9 (permalink)
Member: 1025079
Thanks Meter: 311
I can put in recovery mode remotely.
Old 11-15-2018, 20:36   #10 (permalink)
Member: 2066831
Thanks Meter: 5
You can explain how to do it yourself?
Old 12-14-2018, 21:40   #11 (permalink)
Member: 482218
Thanks Meter: 119
you sell method or only work remotely?
Old 12-27-2018, 08:04   #12 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 713
This section is for programming, not remote service.
Page generated in 0.17054 seconds with 8 queries
