Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 11-01-2017, 14:23   #1 (permalink)
Member: 1025079
Thanks Meter: 311
LG Factory Reset Command
Hello,
Does anyone knows what is he command to factory reset on lg devices in download mode?
thanks in advance.
Old 11-15-2017, 14:24   #2 (permalink)
Crazy Poster
Member: 2324361
Thanks Meter: 13
Originally Posted by cwcast View Post
Hello,
thanks in advance.
if you have adb drivers installed ,try this.
open command window from adb and fastboot tools folder
fastboot erase userdata
if you're struggling to goto recovery mode. get the stock recovery or custom recovery(only rooted/bootloader unlock devcies)
goto download mode / fastboot mode :
place your recovery image to adb folder and type the below.
fastboot boot recovery.img
use zipped flash files to install your desired OS from SD card.
Old 11-15-2017, 14:40   #3 (permalink)
Member: 1025079
Thanks Meter: 311
Thanks for replied, I need to do this with out adb or fastboot.
I want to get it done by sending command through serial or modem port.
Old 11-15-2017, 17:00   #4 (permalink)
namyelus's Avatar
Member: 2709688
Thanks Meter: 2,186
Factory Reset -> AT%FRST
Reboot Device -> AT%PMRST / AT%RESTART
The Following 5 Users Say Thank You to namyelus For This Useful Post:
Old 11-16-2017, 01:03   #5 (permalink)
Member: 1025079
Thanks Meter: 311
I will try that tomorrow.
Old 11-19-2017, 15:29   #6 (permalink)
bilalzaink's Avatar
Member: 774744
Thanks Meter: 774
In LG Download mode No Command For Factory Reset
Flash Userdata Manually For Reset The Phone
Old 11-19-2017, 16:35   #7 (permalink)
Member: 1025079
Thanks Meter: 311
How, I do that? Anyway you can point me?
Old 11-20-2017, 01:02   #8 (permalink)
Member: 2618995
Thanks Meter: 5
Just write zeros to the entire userdata partition
Old 12-02-2017, 14:42   #9 (permalink)
Member: 2764515
Thanks Meter: 2
Thx
Page generated in 0.17061 seconds with 8 queries
