Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 04-26-2017, 01:15   #1 (permalink)
Member: 2674769
Thanks Meter: 17
LG laf KILOMETER COMMAND encryption
this lg laf download command that is encrypt
the encrypt depends on KILOCENT COMMAND RESPONSE example
kilocent command
4b 49 4c 4f 43 45 4e 54 00 00 00 00 00 00 00 00 KILOCENT........
00 00 00 00 00 00 00 00 e3 7b 00 00 b4 b6 b3 b0 ........م{..´¶³°
phone answer
4b 49 4c 4f 43 45 4e 54 fe 1c d6 03 00 00 00 00 KILOCENT‏.ض.....
00 00 00 00 00 00 00 00 90 8e 00 00 b4 b6 b3 b0 ........گژ..´¶³°
after that comes the kilometer comand
4b 49 4c 4f 4d 45 54 52 00 00 00 00 04 00 00 00 KILOMETR........
00 00 00 00 10 00 00 00 d2 c2 00 00 b4 b6 b3 b0 ........زآ..´¶³°
00 24 b5 59 6f d1 db a3 af c6 00 37 03 df a4 78 .$µYoرغ£¯ئ.7.ك¤x
00 24 b5 59 6f d1 db a3 af c6 00 37 03 df a4 78}
the above hex line was calculate thru {
fe 1c d6 03 } that we get in
kilocent respons
any body no how to calcualte it
Old 04-26-2017, 09:30   #2 (permalink)
Member: 2674769
Thanks Meter: 17
Who interested
Bros
Old 04-26-2017, 10:37   #3 (permalink)
.:hack3r2k:.'s Avatar
Member: 15022
Sonork: 100.53452
Thanks Meter: 61,568
Get ida and disassemble laf daemon ;-) All is inside =)
Old 04-26-2017, 23:14   #4 (permalink)
Member: 2674769
Thanks Meter: 17
in python
from Crypto.Cipher import AES
def key_transform(old_key):
new_key = ''
for x in range(32,0,-1):
new_key += chr(ord(old_key[x-1]) - (x % 0x0C))
return new_key
def key_xoring(key2_t, kilo_challenge):
key2_t_xor = ''
i = 0
while i <= 28:
key2_t_xor += chr(ord(key2_t[i]) ^ ord(kilo_challenge[3]))
key2_t_xor += chr(ord(key2_t[i+1]) ^ ord(kilo_challenge[2]))
key2_t_xor += chr(ord(key2_t[i+2]) ^ ord(kilo_challenge[1]))
key2_t_xor += chr(ord(key2_t[i+3]) ^ ord(kilo_challenge[0]))
i = i + 4
return key2_t_xor
def do_aes_encrypt(key2_t_xor):
plaintext = b''
for k in range(0,16):
plaintext += chr(k)
obj = AES.new(key2_t_xor, AES.MODE_ECB)
return obj.encrypt(plaintext)
def do_challenge_response(comm):
request_kilo = make_request(b'KILO', args=[b'CENT', b'\0\0\0\0', b'\0\0\0\0', b'\0\0\0\0'])
kilo_header, kilo_response = comm.call(request_kilo)
kilo_challenge = kilo_header[8:12]
chalstring = ":".join("{:02x}".format(ord(k)) for k in kilo_challenge)
_logger.debug("Challenge: %s" %chalstring)
key2 = 'qndiakxxuiemdklseqid~a~niq,zjuxl' # if this doesnt work try 'lgowvqnltpvtgogwswqn~n~mtjjjqxro'
kilo_response = do_aes_encrypt(key_xoring(key_transform(key2), kilo_challenge))
respstring = ":".join("{:02x}".format(ord(m)) for m in kilo_response)
_logger.debug("Response: %s" %respstring)
request_kilo_metr = make_request(b'KILO', args=[b'METR', b'\0\0\0\0', b'\x02\0\0\0', b'\0\0\0\0'], body=bytes(kilo_response))
metr_header, metr_response = comm.call(request_kilo_metr)
it use AES MODE_ECB crypt
can we use it in delphi
Old 05-22-2017, 16:27   #5 (permalink)
Member: 2674769
Thanks Meter: 17
can any one help
this is the key := qndiakxxuiemdklseqid~a~niq,zjuxl
for AES encryption ECB MODE
Old 05-22-2017, 16:38   #6 (permalink)
Member: 2674769
Thanks Meter: 17
lets translate the python code to delphi
function key_transform (old_key:string): string;
var
x :integer;
begin
result:='';
for x := 32 downto 0 do
result:= result + chr(ord(old_key[x-1])-( x mod $0C)) ;
end;
Old 05-22-2017, 16:49   #7 (permalink)
Member: 2674769
Thanks Meter: 17
function key_xoring ( key2_t :string ; kilo_challenge :string) : string ;
var
i :integer;
begin
result := '';
i:=0 ;
while i <= 28 do begin
result := result + chr(ord(key2_t[i]) xor ord (kilo_challenge[3])) ;
result := result + chr(ord(key2_t[i+1]) xor ord(kilo_challenge[2]));
result := result + chr(ord(key2_t[i+2]) xor ord(kilo_challenge[1])) ;
result := result + chr(ord(key2_t[i+3]) xor ord (kilo_challenge[0])) ;
i := i + 4 ;
end;
that`s give me error on yellow line
[DCC Error] Unit1.pas(8339): E2157 Element 0 inaccessible - use 'Length' or 'SetLength'
Old 05-22-2017, 17:05   #8 (permalink)
Member: 2674769
Thanks Meter: 17
if somebody fix proplem for above function
we will need aes encriptin for the output of it
Page generated in 0.15610 seconds with 8 queries
