GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
02-05-2012, 10:17 | #1 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Australia/Melbourne
Member: 1610809 Status: Offline Sonork: 100.1616347 Thanks Meter: 23 | Need send frame code resset to n1265 help me please thanks |
The Following 2 Users Say Thank You to GTunlocker For This Useful Post: |
02-06-2012, 17:43 | #2 (permalink) |
Member: 1610809 Status: Offline Sonork: 100.1616347 Thanks Meter: 23 | function SendFrameUFS(frame: string; readLen:Cardinal; ReadTimeout: integer) : string; var i,BufferLEN:integer; begin while Pos(' ', FRAME) > 0 do Delete(FRAME,Pos(' ', FRAME),1); J2:=0; for i := 0 to length(Frame) do if i mod 2 = 1 then begin command[j2]:='$' + Frame[i] + Frame[i + 1]; FT_out_Buffer[j2] := strtoint(command[j2]); J2:=(J2+1); end; ReadWrite(J2, ReadLen, ReadTimeOut); end; procedure RH103_LOADER; begin ////EXEMPLE FROM ARMPRG_RH96.0.02.hex RH_103_LOADER_1:='020000040100F9'+ '1000000094109FE590209FE58C309FE588409FE508'+ '1000100084509FE580609FE57C709FE578809FE538'+ '1000200074909FE570B09FE56CC09FE568D09FE538'+ '1000300064E09FE500000FE1801080E301F021E122'+ '10004000D7F021E354D09FE5DBF021E350D09FE5CA'+ '10005000D2F021E34CD09FE5D3F021E348D09FE5D7'; /////NEXT FROM ARMPRG_RH96.0.02.hex RH_103_LOADER_2:='1000600048009FE5010010E344E09F15 44E09F0530'+ '1000700010FF2FE1784700003C009FE5010010E3EE'+ '1000800038E09F1538E09F0510FF2FE1784700000A'+ '1000900030009FE510FF2FE1DEEEDEEEEFBEADDEBD'+ '1000A00064CD000164CE000164CC000164C4000191'+ '1000B0005D0800017500000178000001D9380001D9'+ '1000C0008D000001900000012D3800010047084715'+ '1000D00010471847204728473047384710B4042AAC'+ '1000E0000ED3031C0B439B070AD108C810C9A342B7'+ '1000F00002D1043A042AF8D2A34201D004380439C8'+ '10010000002A02D1002010BC7047D30701D501326C'; end; function boot_RH103 : boolean; var i, iPos, Tmp, J : integer; ack : string; buffer, dump : string; begin STOP:=false; form1.memo1.Clear; form1.memo1.lines.add('Press * + 5 and Power Button NOW...'); ////Start//// result:=false; form1.progresbar.Max:=1000; form1.progresbar.min:=0; form1.progresbar.Position:=1; for i:=0 to 1000 do begin if UFS='UFS' then end; how to make the bootloader? help me please |
02-06-2012, 17:48 | #3 (permalink) |
Member: 1610809 Status: Offline Sonork: 100.1616347 Thanks Meter: 23 | ARMPRG_RH96.0.02.hex RH96.0.02 tyARMPRG_RH96.0.02.hex Db R02N008 May 11 2006 15:28:16 o :020000040100F9 :1000000094109FE590209FE58C309FE588409FE508 :1000100084509FE580609FE57C709FE578809FE538 :1000200074909FE570B09FE56CC09FE568D09FE538 :1000300064E09FE500000FE1801080E301F021E122 :10004000D7F021E354D09FE5DBF021E350D09FE5CA :10005000D2F021E34CD09FE5D3F021E348D09FE5D7 :1000600048009FE5010010E344E09F1544E09F0530 :1000700010FF2FE1784700003C009FE5010010E3EE :1000800038E09F1538E09F0510FF2FE1784700000A :1000900030009FE510FF2FE1DEEEDEEEEFBEADDEBD :1000A00064CD000164CE000164CC000164C4000191 :1000B0005D0800017500000178000001D9380001D9 :1000C0008D000001900000012D3800010047084715 :1000D00010471847204728473047384710B4042AAC :1000E0000ED3031C0B439B070AD108C810C9A342B7 :1000F00002D1043A042AF8D2A34201D004380439C8 :10010000002A02D1002010BC7047D30701D501326C :1001100005E003780C7801310130A34207D1037860 :100120000C7801310130A34201D1023AF1D1181B00 :10013000E9E7000078470000030052E37300009AEB |
02-24-2012, 19:01 | #4 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: YEMEN
Member: 712521 Status: Offline Thanks Meter: 25 | Quote:
i have the rest command with com portjust replace it with hex in ufs var str:string; c :integer; begin z.Clear; form1.ComPort1.Port:= sCombobox2.Text; comport1.Open; comport1.BaudRate:=br115200; z.Lines.Add('Used Com Port ['+sCombobox2.Text+']') ; z.lines.add('Searching For Conneted Phone..'); sleep(500); sc('7E 00 78 F0 7E'); Application.ProcessMessages; Application.ProcessMessages; SLEEP(200); ComPort1.ReadStr(str, c) ; Application.ProcessMessages; IF str<>('') THEN BEGIN z.lines.add('GREAT PHONE FOUND!!'); SLEEP(500); z.lines.add('==============================='); z.lines.add('Resetting User Code..'); z.lines.add('==============================='); SLEEP(200); sc('29 01 00 31 40 7E'); Application.ProcessMessages; sleep(200); comport1.ReadStr(str,c) ; Application.ProcessMessages; sleep(200); sc('27 52 00 30 30 30 30 00 00 00 00 00 00 00 00 00'+ '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00'+ '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00'+ '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00'+ '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00'+ '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00'+ '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 5A 51 7E'); sleep(200); Application.ProcessMessages; comport1.ReadStr(str,c) ; sleep(200); Application.ProcessMessages; sc('27 52 00 30 30 30 30 00 00 00 00 00 00 00 00 00'+ '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 5A 51 7E'); Application.ProcessMessages; sleep(200); comport1.ReadStr(str,c) ; Application.ProcessMessages; sleep(200); sc('27 51 00 00 00 00 00 00 00 00 00 00 00 00 00 00'+ '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00' + '00 00 00 05 CD 7E'); Application.ProcessMessages; sleep(200); comport1.ReadStr(str,c) ; sleep(200); sc('29 02 00 59 6A 7E'); Application.ProcessMessages; sleep(200); comport1.ReadStr(str,c) ; Application.ProcessMessages; z.lines.add('User Code Rested to [0000]'); z.lines.add('Great Resetting Complated..'); z.lines.add('==============================='); z.lines.add('Restarting Phone............'); z.lines.add('Done'); z.lines.add('==============================='); end; end; try and post YELLow command`s is the rest command for all qualcomm based mobile`s it will rest user code to 0000 | |
The Following 2 Users Say Thank You to mobayz For This Useful Post: |
02-25-2012, 08:35 | #12 (permalink) |
No Life Poster Join Date: Mar 2006 Location: .: India :. Heaven on Earth
Member: 238812 Status: Offline Sonork: 100.1602669 Thanks Meter: 1,443 | If its only about resetting code for a phone, then is OK. But if you want to learn how it is done (bcoz posted in Reverse Engineering Section), then you can do it in Universal Method. Change Phone mode to Offline-D ( 0x29 0x01 0x00) Read Info if you need ( 0x00 ) Write NV Item 0x52 with 0000 (Four zeros) with NV Write Command (0x27) Write NV Item 0x51 with 0 (Single Zero) with NV Write Command (0x27) Restart Phone ( 0x29 0x01 0x00 ) But it is only if you want to learn HOW STUFF WORKS. Thanks to all who posted in this thread. Br, Shadab Ahmad |
The Following 3 Users Say Thank You to [Shadab_M] For This Useful Post: |
03-09-2012, 16:28 | #13 (permalink) | |
Member: 1610809 Status: Offline Sonork: 100.1616347 Thanks Meter: 23 | Quote:
Ofline-D (0x29 0x01 0x00) result 29 01 00 31 40 7E Restart (0x29 0x02 0x00) result 29 02 00 59 6A 7E but 0x52 and 0x51 with 0x27 NVitem send ComandHEX results are not same as mobayz | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
