Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 10-06-2010, 13:05   #46 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
Originally Posted by thushdt View Post
Where can i find security code for DCT4 models.. is it some where in pm file??
Hi,
In many DCT4 phones, its stored in PM 35,0
Old 10-09-2010, 13:03   #47 (permalink)
Member: 643472
Sonork: 100.96901
At last found - BCM phone's life timer ;)
Hi,
Nokia has changed life timer read, reset, edit field from PM in Broadcomm phones.
In broadcomm phones life timer is stored in PM '374,0' if you want reset - use below PM to reset it to 00:00:00 - write as PM file!
[374]
0=00000000
Well, at the moment not all tool supports this or i could be wrong! BUT after this post, I'm sure all tool will be able to read, reset, edit BCM phones life timer.
File Type: zip BCM life timer reset.zip (157 Bytes, 806 views)
The Following 27 Users Say Thank You to ..::Angel::.. For This Useful Post:
Old 10-10-2010, 04:46   #48 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
not only in 374 field
and it done ma-a-a-any time ago http://forum.gsmhosting.com/vbb/6409867-post147.html
The Following User Says Thank You to Dzirt For This Useful Post:
Old 10-10-2010, 12:02   #49 (permalink)
Member: 643472
Sonork: 100.96901
Yes that's why i did not write 'world first' ;o) as i wrote not all tools supports this.
Btw - when life timer can be reset with '374' field then what's the use of searching this in other fields ? if its realy exists.
Old 10-10-2010, 12:44   #50 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
..::Angel::..
one field upper
here also some stuff data inside
Old 10-11-2010, 12:59   #51 (permalink)
Member: 643472
Sonork: 100.96901
..::Angel::..
one field upper
Yeps
Last call, last received calls and total call timer are stored there [373,0]
However, total call timer also stored in [374,0]
Old 10-15-2010, 15:02   #52 (permalink)
Registered User
Member: 559397
Thanks Meter: 53
pm to address all the messages ................... ? where .............
consumers sometimes pay dearly for his message bold ............
other one's tool
Old 10-15-2010, 16:48   #53 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello, if you look something for User Data Extraction - try seen on BEST from Infinity Team.
Old 10-18-2010, 21:24   #54 (permalink)
GsmUniversal's Avatar
Member: 649528
Sonork: 100.1590443
Thanks Meter: 6,958
thats really the info helps us alot thanks dear ali bro
The Following User Says Thank You to GsmUniversal For This Useful Post:
Old 10-19-2010, 00:09   #55 (permalink)
Gsm Benghazi's Avatar
Member: 412609
Sonork: 100.1586824
Thanks Meter: 148
Mr. Ali
I have stupid question , but really I don't know the answer .
what are Broadcomm phones. ?
thanks
Old 10-19-2010, 01:23   #56 (permalink)
Member: 111140
Thanks Meter: 75
@libyana_gsm
You can find answer there Nokia BB5 General information
Regards.
GsmOrient.
The Following User Says Thank You to GsmOrient For This Useful Post:
Old 10-22-2010, 13:47   #57 (permalink)
Registered User
Member: 559397
Thanks Meter: 53
@ to ALL : ..
someone will be killed due to message data lost, ...................... there can afford it?
Old 10-22-2010, 13:48   #58 (permalink)
Registered User
Member: 559397
Thanks Meter: 53
sory this post :
http://forum.gsmhosting.com/vbb/f299...-help-1122706/
Old 10-23-2010, 08:53   #59 (permalink)
Member: 1214273
Thanks Meter: 136
this is your fault. Always remind the rules for customer that you are not responible for private data and phone hardware when flashing or unlocking. Where do you have your mind ? Learn how use intelligent cponversation with customers, otherwise you can be killed everyday by everyone customer!
Old 10-27-2010, 17:02   #60 (permalink)
Registered User
Member: 559397
Thanks Meter: 53
@ online-nokia
if happen to me ................ or I'll kill him first ............
Page generated in 0.32413 seconds with 10 queries
