NOKIA SERVICE - Webservice Hi, I tried to use these webservices, but no success! https://www.caresuite.nokia.com/care...CareSuite?WSDL https://www.dsut.online.nokia.com/oti/CareSuite?WSDL https://www.dsut-qa.online.nokia.com/oti/CareSuite?WSDL I got this error below: http://www.ligteltelecom.com.br/NOKI...VICE_ERROR.JPG Can Anyone help me? |
use the WSDL importer wizard from your delphi IDE then yuse HTTPRIO as your web services client then you can specify from there your WSDLLocation param for your to read something about Creating a Web Service Client with Delphi tool you can refer to and use SOAP Client and Debugger good luck :) try to use C# it will be much more easier to work with the Soap services.. |
I tried for WSDL IMPORT same But got this error. |
You forget about SSL. ;) By default delphi not support SSL, use INDY or other libraries. |
My C# code below: My function getsID (it will take the value of JSESSIONID) Code: public string getsID() Code: private void button1_Click(object sender, EventArgs e) |
anyone help me? I want get product list of the server. |
