GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
07-30-2013, 13:41 | #61 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | now the only unit u need to add is the sha1 unit.. i always use the one from W.Erhardt. Code: unit SL3_NCK; interface uses Windows, SysUtils, SHA1_BB; function SL3_CALC_NCK(TARGET_HASH, MASTER_SP_CODE : string; var nck1, nck2, nck3, nck4, nck5, nck6, nck7 : string) : string; implementation function StrToHex(s: string): string; var i: Integer; begin Result:=''; If length(s)>0 then for i:=1 to length(s) do result:=result+IntToHex(Ord(s[i]),2); end; function HexToStr(s: string): string; var i: Integer; begin Result:=''; i:=1; while i<Length(s) do begin Result:=Result+Chr(StrToIntDef('$'+Copy(s,i,2),0)); Inc(i,2); end; end; function HexToInt(HexNum: string): LongInt; begin Result:=StrToInt('$' + HexNum) ; end; function My_SHA1(input : string) : string; var i, VAL : integer; ctx : TSHA1Context; digest : TSHA1Digest; begin result:=''; SHA1Init(ctx); for i:=1 to length(input) do if i mod 2 = 1 then begin VAL:=hextoint(input[i] + input[i+1]); SHA1Update(ctx, @VAL, 1); end; Sha1Final(ctx,digest); for i:=0 to sizeof(digest)-1 do result := result + strtohex(Chr(Ord(digest[i]))); end; function SimlFeistel(sh, precode:string) : string; var i,prenck : integer; nck,nck2: string; begin for i:=1 to length(precode) do if i mod 2 = 1 then begin nck:=sh[i]+sh[i+1]; nck2:=precode[i]+precode[i+1]; prenck:=( (hextoint(nck)+hextoint(nck2)) mod 10); result:=result+'0'+inttostr(prenck); end; function SL3_CALC_NCK(TARGET_HASH, MASTER_SP_CODE : string; var nck1, nck2, nck3, nck4, nck5, nck6, nck7 : string) : string; var Data, precode, levelhash : string; sh, precode7, precode8, final : string; i, j, magic : integer; begin MASTER_SP_CODE:='000000'+Copy(MASTER_SP_CODE, 1, 24); for i:=1 to 7 do begin levelhash:=My_SHA1('0'+inttostr(i)+TARGET_HASH); precode8:=Copy(MASTER_SP_CODE, 0,16); precode7:=Copy(MASTER_SP_CODE, 17,30); for magic:=0 to 1 do begin sh:=My_SHA1('0'+inttostr(magic)+Copy(levelhash, 0,32)+precode8); precode:=''; Precode:=SimlFeistel(sh, precode7); precode7:=precode; sh:=My_SHA1('0'+inttostr(magic)+Copy(levelhash, 0,32)+precode); precode:=''; Precode:=SimlFeistel(sh, precode8); precode8:=precode; end; data:=''; final:=precode8+precode7; for j:=1 to length(final) do if j mod 2 = 1 then data:=data+inttostr(hextoint(final[j]+final[j+1])); //ADDLine('#pw+'+data+'+'+inttostr(i)+'#'); if i=1 then nck1:=(data); if i=2 then nck2:=(data); if i=3 then nck3:=(data); if i=4 then nck4:=(data); if i=5 then nck5:=(data); if i=6 then nck6:=(data); if i=7 then nck7:=(data); end; end; end. @..::SuB::.. i hope now you are happy? cause you was the one how always asked for it any every sl3 tread here. i posted the php version, cause it was intendet for ppl with sl3 bruteforce service websites... so they can automatically calculate the unlock codes directly online... Last edited by oOXTCOo; 07-30-2013 at 13:48. |
The Following 2 Users Say Thank You to oOXTCOo For This Useful Post: |
07-30-2013, 14:12 | #63 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | here is Sha1_bb.pas ............................................ |
The Following 4 Users Say Thank You to oOXTCOo For This Useful Post: |
07-30-2013, 15:13 | #64 (permalink) |
No Life Poster Join Date: Aug 2008 Location: The Matrix :) Age: 36
Member: 833760 Status: Offline Sonork: 100.1597150 Thanks Meter: 114 | Thank you im finally got it and im happy I've built a job manager for myself it is loading jobs for oclhashcat from MySQL database, i will post the source soon just need some correction BTW im using Lazarus, im wondering how can i port the functions |
07-30-2013, 15:54 | #65 (permalink) |
No Life Poster Join Date: Oct 2010
Member: 1422878 Status: Offline Thanks Meter: 164 | Hi oOXTCOo I made some corrections in your code, for use it mor easy. Code: unit SL3_NCK; interface uses Windows, SysUtils, SHA1; function GetTokenCount(Cadena,Separador:string):integer; function GetToken(sCadena, sSeparador: String; iToken: Integer): String; function SL3_CALC_NCK(TARGET_HASH, MASTER_SP_CODE : string):string; implementation function StrToHex(s: string): string; var i: Integer; begin Result:=''; If length(s)>0 then for i:=1 to length(s) do result:=result+IntToHex(Ord(s[i]),2); end; function HexToStr(s: string): string; var i: Integer; begin Result:=''; i:=1; while i<Length(s) do begin Result:=Result+Chr(StrToIntDef('$'+Copy(s,i,2),0)); Inc(i,2); end; end; function HexToInt(HexNum: string): LongInt; begin Result:=StrToInt('$' + HexNum) ; end; function My_SHA1(input : string) : string; var i, VAL : integer; ctx : TSHA1Context; digest : TSHA1Digest; begin result:=''; SHA1Init(ctx); for i:=1 to length(input) do if i mod 2 = 1 then begin VAL:=hextoint(input[i] + input[i+1]); SHA1Update(ctx, @VAL, 1); end; Sha1Final(ctx,digest); for i:=0 to sizeof(digest)-1 do result := result + strtohex(Chr(Ord(digest[i]))); end; function GetTokenCount(Cadena,Separador:string):integer; var Posicion:integer; begin Posicion := Pos(Separador,Cadena); Result := 1; if Cadena <> '' then begin if Posicion <> 0 then while Posicion <> 0 do begin Delete(Cadena,1,Posicion); Posicion := Pos(Separador,Cadena); Inc (Result); end; end else Result := 0; end; function GetToken(sCadena, sSeparador: String; iToken: Integer): String; var iPosicion: Integer; begin while iToken > 1 do begin Delete(sCadena, 1, Pos(sSeparador,sCadena) + Length(sSeparador) - 1); Dec(iToken); end; iPosicion := Pos(sSeparador, sCadena); if iPosicion = 0 then Result:= sCadena else Result:= Copy(sCadena, 1, iPosicion - 1); end; function SimlFeistel(sh, precode:string) : string; var i,prenck : integer; nck,nck2: string; begin for i:=1 to length(precode) do if i mod 2 = 1 then begin nck:=sh[i]+sh[i+1]; nck2:=precode[i]+precode[i+1]; prenck:=( (hextoint(nck)+hextoint(nck2)) mod 10); result:=result+'0'+inttostr(prenck); end; end; function SL3_CALC_NCK(TARGET_HASH, MASTER_SP_CODE : string):string; var Data, precode, levelhash : string; sh, precode7, precode8, final : string; i, j, magic : integer; TCod :String; begin MASTER_SP_CODE:='000000'+Copy(MASTER_SP_CODE, 1, 24); for i:=1 to 7 do begin levelhash:=My_SHA1('0'+inttostr(i)+TARGET_HASH); precode8:=Copy(MASTER_SP_CODE, 0,16); precode7:=Copy(MASTER_SP_CODE, 17,30); for magic:=0 to 1 do begin sh:=My_SHA1('0'+inttostr(magic)+Copy(levelhash, 0,32)+precode8); precode:=''; Precode:=SimlFeistel(sh, precode7); precode7:=precode; sh:=My_SHA1('0'+inttostr(magic)+Copy(levelhash, 0,32)+precode); precode:=''; Precode:=SimlFeistel(sh, precode8); precode8:=precode; end; data:=''; final:=precode8+precode7; for j:=1 to length(final) do if j mod 2 = 1 then data:=data+inttostr(hextoint(final[j]+final[j+1])); //ADDLine('#pw+'+data+'+'+inttostr(i)+'#'); data := '#pw+' + data + '+' + inttostr(i)+'#'; if (i = 1) then Result := (data) else Result := Result+','+(data); end; end; end. Code: procedure TFNokiaSL3Hash2NCK.btnCalcClick(Sender: TObject); var TCods :String; n:byte; begin Self.Cursor := crHourGlass; MLogs.Lines.Clear; MLogs.Lines.Add('TARGET_HASH : '); MLogs.Lines.Add(' '+ LabeledEdit1.Text); MLogs.Lines.Add('MASTER_SP_CODE: '); MLogs.Lines.Add(' '+ LabeledEdit2.Text); MLogs.Lines.Add(' '); TCods := SL3_CALC_NCK (LabeledEdit1.Text, LabeledEdit2.Text); for n := 1 to GetTokenCount(TCods,',') do begin MLogs.Lines.Add(GetToken(TCods,',',n)) ; end; Self.Cursor := crDefault; end; Big thanks oOXTCOo BR Helpinterchange |
07-30-2013, 16:20 | #66 (permalink) |
Member: 1422878 Status: Offline Thanks Meter: 164 | Modifications to unit SHA1 it needs the unit tools.pas for using function LRot32(X: dword; c: integer): dword; assembler; Code: function LRot32(X: dword; c: integer): dword; register; assembler; asm mov ecx, edx rol eax, cl end; Code: function LRot32(a, b: longword): longword; begin result:= (a shl b) or (a shr (32 - b)); end; and add the type DWord Code: type {$IFDEF VER120} dword= longword; {$ELSE} dword= longint; {$ENDIF} unit j2k_Sha1 Source code ------------------------------------ Code: { *************************************************** * A binary compatible SHA1 implementation * * written by Dave Barton ([email protected]) * *************************************************** * 160bit hash size * *************************************************** } unit j2k_Sha1; interface uses Sysutils; type {$IFDEF VER120} dword= longword; {$ELSE} dword= longint; {$ENDIF} TSHA1Digest= array[0..19] of byte; TSHA1Context= record Hash: array[0..4] of DWord; Hi, Lo: integer; Buffer: array[0..63] of byte; Index: integer; end; function SHA1SelfTest: boolean; procedure SHA1Init(var Context: TSHA1Context); procedure SHA1Update(var Context: TSHA1Context; Buffer: pointer; Len: integer); procedure SHA1Final(var Context: TSHA1Context; var Digest: TSHA1Digest); //****************************************************************************** implementation {$R-} function LRot32(a, b: longword): longword; begin result:= (a shl b) or (a shr (32 - b)); end; function SHA1SelfTest: boolean; const s: string= 'abc'; OutDigest: TSHA1Digest= ($a9,$99,$3e,$36,$47,$06,$81,$6a,$ba,$3e,$25,$71,$78,$50,$c2,$6c,$9c,$d0,$d8,$9d); var Context: TSHA1Context; Digest: TSHA1Digest; begin SHA1Init(Context); SHA1Update(Context,@s[1],length(s)); SHA1Final(Context,Digest); if CompareMem(@Digest,@OutDigest,Sizeof(Digest)) then Result:= true else Result:= false; end; //****************************************************************************** function F1(x, y, z: DWord): DWord; begin Result:= z xor (x and (y xor z)); end; function F2(x, y, z: DWord): DWord; begin Result:= x xor y xor z; end; function F3(x, y, z: DWord): DWord; begin Result:= (x and y) or (z and (x or y)); end; //****************************************************************************** function RB(A: DWord): DWord; begin Result:= (A shr 24) or ((A shr 8) and $FF00) or ((A shl 8) and $FF0000) or (A shl 24); end; procedure SHA1Compress(var Data: TSHA1Context); var A, B, C, D, E, T: DWord; W: array[0..79] of DWord; i: integer; begin Move(Data.Buffer,W,Sizeof(Data.Buffer)); for i:= 0 to 15 do W[i]:= RB(W[i]); for i:= 16 to 79 do W[i]:= LRot32(W[i-3] xor W[i-8] xor W[i-14] xor W[i-16],1); A:= Data.Hash[0]; B:= Data.Hash[1]; C:= Data.Hash[2]; D:= Data.Hash[3]; E:= Data.Hash[4]; for i:= 0 to 19 do begin T:= LRot32(A,5) + F1(B,C,D) + E + W[i] + $5A827999; E:= D; D:= C; C:= LRot32(B,30); B:= A; A:= T; end; for i:= 20 to 39 do begin T:= LRot32(A,5) + F2(B,C,D) + E + W[i] + $6ED9EBA1; E:= D; D:= C; C:= LRot32(B,30); B:= A; A:= T; end; for i:= 40 to 59 do begin T:= LRot32(A,5) + F3(B,C,D) + E + W[i] + $8F1BBCDC; E:= D; D:= C; C:= LRot32(B,30); B:= A; A:= T; end; for i:= 60 to 79 do begin T:= LRot32(A,5) + F2(B,C,D) + E + W[i] + $CA62C1D6; E:= D; D:= C; C:= LRot32(B,30); B:= A; A:= T; end; Data.Hash[0]:= Data.Hash[0] + A; Data.Hash[1]:= Data.Hash[1] + B; Data.Hash[2]:= Data.Hash[2] + C; Data.Hash[3]:= Data.Hash[3] + D; Data.Hash[4]:= Data.Hash[4] + E; FillChar(W,Sizeof(W),0); FillChar(Data.Buffer,Sizeof(Data.Buffer),0); end; //****************************************************************************** procedure SHA1Init(var Context: TSHA1Context); begin Context.Hi:= 0; Context.Lo:= 0; Context.Index:= 0; FillChar(Context.Buffer,Sizeof(Context.Buffer),0); Context.Hash[0]:= $67452301; Context.Hash[1]:= $EFCDAB89; Context.Hash[2]:= $98BADCFE; Context.Hash[3]:= $10325476; Context.Hash[4]:= $C3D2E1F0; end; //****************************************************************************** procedure SHA1UpdateLen(var Context: TSHA1Context; Len: integer); var i, k: integer; begin for k:= 0 to 7 do begin i:= Context.Lo; Inc(Context.Lo,Len); if Context.Lo< i then Inc(Context.Hi); end; end; //****************************************************************************** procedure SHA1Update(var Context: TSHA1Context; Buffer: pointer; Len: integer); type PByte= ^Byte; begin SHA1UpdateLen(Context,Len); while Len> 0 do begin Context.Buffer[Context.Index]:= PByte(Buffer)^; Inc(PByte(Buffer)); Inc(Context.Index); Dec(Len); if Context.Index= 64 then begin Context.Index:= 0; SHA1Compress(Context); end; end; end; //****************************************************************************** procedure SHA1Final(var Context: TSHA1Context; var Digest: TSHA1Digest); type PDWord= ^DWord; begin Context.Buffer[Context.Index]:= $80; if Context.Index>= 56 then SHA1Compress(Context); PDWord(@Context.Buffer[56])^:= RB(Context.Hi); PDWord(@Context.Buffer[60])^:= RB(Context.Lo); SHA1Compress(Context); Context.Hash[0]:= RB(Context.Hash[0]); Context.Hash[1]:= RB(Context.Hash[1]); Context.Hash[2]:= RB(Context.Hash[2]); Context.Hash[3]:= RB(Context.Hash[3]); Context.Hash[4]:= RB(Context.Hash[4]); Move(Context.Hash,Digest,Sizeof(Digest)); FillChar(Context,Sizeof(Context),0); end; end. Helpinterchange |
07-30-2013, 16:43 | #67 (permalink) |
Member: 833760 Status: Offline Sonork: 100.1597150 Thanks Meter: 114 | Im used this sha1.pas Code: { This file is part of the Free Pascal packages. Copyright (c) 2009 by the Free Pascal development team Implements a SHA-1 digest algorithm (RFC 3174) See the file COPYING.FPC, included in this distribution, for details about the copyright. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. **********************************************************************} unit sha1; {$mode objfpc}{$h+} interface type TSHA1Digest = array[0..19] of byte; TSHA1Context = record State: array[0..4] of cardinal; Buffer: array[0..63] of byte; BufCnt: PtrUInt; { in current block, i.e. in range of 0..63 } Length: QWord; { total count of bytes processed } end; { core } procedure SHA1Init(var ctx: TSHA1Context); procedure SHA1Update(var ctx: TSHA1Context; const Buf; BufLen: PtrUInt); procedure SHA1Final(var ctx: TSHA1Context; var Digest: TSHA1Digest); { auxiliary } function SHA1String(const S: string): TSHA1Digest; function SHA1Buffer(const Buf; BufLen: PtrUInt): TSHA1Digest; function SHA1File(const Filename: string; const Bufsize: PtrUInt = 1024): TSHA1Digest; { helpers } function SHA1Print(const Digest: TSHA1Digest): string; function SHA1Match(const Digest1, Digest2: TSHA1Digest): boolean; implementation // inverts the bytes of (Count div 4) cardinals from source to target. procedure Invert(Source, Dest: Pointer; Count: PtrUInt); var S: PByte; T: PCardinal; I: PtrUInt; begin S := Source; T := Dest; for I := 1 to (Count div 4) do begin T^ := S[3] or (S[2] shl 8) or (S[1] shl 16) or (S[0] shl 24); Inc(S, 4); Inc(T); end; end; procedure SHA1Init(var ctx: TSHA1Context); begin FillChar(ctx, sizeof(TSHA1Context), 0); ctx.State[0] := $67452301; ctx.State[1] := $efcdab89; ctx.State[2] := $98badcfe; ctx.State[3] := $10325476; ctx.State[4] := $c3d2e1f0; end; const K20 = $5A827999; K40 = $6ED9EBA1; K60 = $8F1BBCDC; K80 = $CA62C1D6; procedure SHA1Transform(var ctx: TSHA1Context; Buf: Pointer); var A, B, C, D, E, T: cardinal; Data: array[0..15] of cardinal; i: integer; begin A := ctx.State[0]; B := ctx.State[1]; C := ctx.State[2]; D := ctx.State[3]; E := ctx.State[4]; Invert(Buf, @Data, 64); {$push} {$r-,q-} i := 0; repeat T := (B and C) or (not B and D) + K20 + E; E := D; D := C; C := RorDWord(B, 2); B := A; A := T + roldword(A, 5) + Data[i and 15]; Data[i and 15] := roldword(Data[i and 15] xor Data[(i + 2) and 15] xor Data[(i + 8) and 15] xor Data[(i + 13) and 15], 1); Inc(i); until i > 19; repeat T := (B xor C xor D) + K40 + E; E := D; D := C; C := rordword(B, 2); B := A; A := T + roldword(A, 5) + Data[i and 15]; Data[i and 15] := roldword(Data[i and 15] xor Data[(i + 2) and 15] xor Data[(i + 8) and 15] xor Data[(i + 13) and 15], 1); Inc(i); until i > 39; repeat T := (B and C) or (B and D) or (C and D) + K60 + E; E := D; D := C; C := rordword(B, 2); B := A; A := T + roldword(A, 5) + Data[i and 15]; Data[i and 15] := roldword(Data[i and 15] xor Data[(i + 2) and 15] xor Data[(i + 8) and 15] xor Data[(i + 13) and 15], 1); Inc(i); until i > 59; repeat T := (B xor C xor D) + K80 + E; E := D; D := C; C := rordword(B, 2); B := A; A := T + roldword(A, 5) + Data[i and 15]; Data[i and 15] := roldword(Data[i and 15] xor Data[(i + 2) and 15] xor Data[(i + 8) and 15] xor Data[(i + 13) and 15], 1); Inc(i); until i > 79; Inc(ctx.State[0], A); Inc(ctx.State[1], B); Inc(ctx.State[2], C); Inc(ctx.State[3], D); Inc(ctx.State[4], E); {$pop} Inc(ctx.Length, 64); end; procedure SHA1Update(var ctx: TSHA1Context; const Buf; BufLen: PtrUInt); var Src: PByte; Num: PtrUInt; begin if BufLen = 0 then Exit; Src := @Buf; Num := 0; // 1. Transform existing data in buffer if ctx.BufCnt > 0 then begin // 1.1 Try to fill buffer up to block size Num := 64 - ctx.BufCnt; if Num > BufLen then Num := BufLen; Move(Src^, ctx.Buffer[ctx.BufCnt], Num); Inc(ctx.BufCnt, Num); Inc(Src, Num); // 1.2 If buffer is filled, transform it if ctx.BufCnt = 64 then begin SHA1Transform(ctx, @ctx.Buffer); ctx.BufCnt := 0; end; end; // 2. Transform input data in 64-byte blocks Num := BufLen - Num; while Num >= 64 do begin SHA1Transform(ctx, Src); Inc(Src, 64); Dec(Num, 64); end; // 3. If there's less than 64 bytes left, add it to buffer if Num > 0 then begin ctx.BufCnt := Num; Move(Src^, ctx.Buffer, Num); end; end; const PADDING: array[0..63] of byte = ($80, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 ); procedure SHA1Final(var ctx: TSHA1Context; var Digest: TSHA1Digest); var Length: QWord; Pads: cardinal; begin // 1. Compute length of the whole stream in bits Length := 8 * (ctx.Length + ctx.BufCnt); // 2. Append padding bits if ctx.BufCnt >= 56 then Pads := 120 - ctx.BufCnt else Pads := 56 - ctx.BufCnt; SHA1Update(ctx, PADDING, Pads); // 3. Append length of the stream (8 bytes) Length := NtoBE(Length); SHA1Update(ctx, Length, 8); // 4. Invert state to digest Invert(@ctx.State, @Digest, 20); FillChar(ctx, sizeof(TSHA1Context), 0); end; function SHA1String(const S: string): TSHA1Digest; var Context: TSHA1Context; begin SHA1Init(Context); SHA1Update(Context, PChar(S)^, length(S)); SHA1Final(Context, Result); end; function SHA1Buffer(const Buf; BufLen: PtrUInt): TSHA1Digest; var Context: TSHA1Context; begin SHA1Init(Context); SHA1Update(Context, buf, buflen); SHA1Final(Context, Result); end; function SHA1File(const Filename: string; const Bufsize: PtrUInt): TSHA1Digest; var F: file; Buf: PChar; Context: TSHA1Context; Count: cardinal; ofm: longint; begin SHA1Init(Context); Assign(F, Filename); {$i-} ofm := FileMode; FileMode := 0; Reset(F, 1); {$i+} if IOResult = 0 then begin GetMem(Buf, BufSize); repeat BlockRead(F, Buf^, Bufsize, Count); if Count > 0 then SHA1Update(Context, Buf^, Count); until Count < BufSize; FreeMem(Buf, BufSize); Close(F); end; SHA1Final(Context, Result); FileMode := ofm; end; const HexTbl: array[0..15] of char = '0123456789abcdef'; // lowercase function SHA1Print(const Digest: TSHA1Digest): string; var I: integer; P: PChar; begin SetLength(Result, 40); P := Pointer(Result); for I := 0 to 19 do begin P[0] := HexTbl[(Digest[i] shr 4) and 15]; P[1] := HexTbl[Digest[i] and 15]; Inc(P, 2); end; end; function SHA1Match(const Digest1, Digest2: TSHA1Digest): boolean; var A: array[0..4] of cardinal absolute Digest1; B: array[0..4] of cardinal absolute Digest2; begin Result := (A[0] = B[0]) and (A[1] = B[1]) and (A[2] = B[2]) and (A[3] = B[3]) and (A[4] = B[4]); end; end. Code: SHA1Update(ctx, @VAL, 1); Code: SHA1Update(ctx, VAL, 1); sl3_nck.pas(51,27) Error: Can't assign values to an address Now works fine, i will testing more but its calculated the same codes as ooxtcoo's php script, so i hope its ok. http://ooxtcoo.dyndns.org/sl3code.ph...00030705050302 хостинг картинок EDIT: OK OK OK code level numbers wrong on screenshot, ive corrected already |
07-30-2013, 19:41 | #68 (permalink) |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 537 | @oOXTCOo Sysutils.pas is verry verry fat unit. Lot of code. Hex to bin and bin to hex conversions can replace with BINTOHEX and HEXTOBIN from Classes.pas this will speedup code and will reduce dramaticaly. (if copy/paste from classses to your unit as local funcs will reduce classes include) Also why need to use StrtoInt from Sysutils.pas better use function VAL from system. In fact StrtoInt use VAL... With this small modifications i think not need fat sysutils.pas Regards: Victor |
07-30-2013, 20:20 | #70 (permalink) | |
Product Manager Join Date: May 2008 Location: Ukraine Age: 45
Member: 772096 Status: Offline Sonork: 100.69222 Thanks Meter: 8,277 | Quote:
Function hex2chr(data: string) : string; begin // 'AABBCCDD'-> #$AA#$BB#$CC#$DD SetLength(result,length(data) div 2); HexToBin(@data[1],@result[1],length(data)); end; Function chr2hex(data: string) : string; begin // #$AA#$BB#$CC#$DD -> 'AABBCCDD' SetLength(result,length(data)*2); BinToHex(@data[1],@result[1],length(data)); end; | |
The Following User Says Thank You to TestBox2 For This Useful Post: |
07-30-2013, 20:39 | #71 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | we dont programm a microcontroller.. so who cares about size? when i reversed it, i just whanted it to get it working... in my project sysutis are havy used.. so it dont make any difference in size if i already included it in another unit. my project have so mutch units now, i thinks about 30 units or so Last edited by oOXTCOo; 07-30-2013 at 20:46. |
07-30-2013, 20:56 | #72 (permalink) | |
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
i included nck1, nck2, nck3 ...... variables in function, so you can directly access it outside of the function in your main unit... you just need to declare same variable names and you have the results from the calculation in nck1, nck2, nck3... you dont need that extra mutch of code... i think its more easy way... | |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
07-30-2013, 21:02 | #73 (permalink) | |
Member: 73 Status: Offline Thanks Meter: 537 | Quote:
This is aditional protection to soft. When are unpacked hacker will go deep in .... call ebp+XXXX .... etc | |
The Following User Says Thank You to Victor For This Useful Post: |
07-30-2013, 21:20 | #74 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | i had it now 2 years in jau standalone, only protected by themida macros. (but i dont know if maybe someone got it or not, but for shure, there was more easy targets to get it from) the code is already more then 2 years old, but in future projects, i will use your advices. |
07-30-2013, 21:54 | #75 (permalink) |
Member: 1422878 Status: Offline Thanks Meter: 164 | Others Changes Code: unit SL3_NCK; interface uses Windows, SysUtils, j2k_Sha1; function GetTokenCount(Cadena,Separador:string):integer; function GetToken(sCadena, sSeparador: String; iToken: Integer): String; function SL3_CALC_NCK(TARGET_HASH, MASTER_SP_CODE : string):string; implementation function HexToStr(s: string): string; var i: Integer; begin Result:=''; i:=1; while i< S.Length do begin Result:=Result+ Chr(StrToIntDef('$'+Copy(s,i,2),0) ); Inc(i,2); end; end; function HexToInt(HexNum: string): LongInt; begin Result:= Integer.Parse('$' + HexNum); end; function My_SHA1(input : string) : string; var i, VAL : integer; ctx : TSHA1Context; digest : TSHA1Digest; begin result:=''; SHA1Init(ctx); for i:=1 to input.Length do if i mod 2 = 1 then begin VAL:= HexToInt(input[i] + input[i+1]); SHA1Update(ctx, @VAL, 1); end; Sha1Final(ctx,digest); for i:=0 to sizeof(digest)-1 do result := result + Ord(digest[i]).ToHexString; end; function GetTokenCount(Cadena,Separador:string):integer; var Posicion:integer; begin Posicion := Pos(Separador,Cadena); Result := 1; if Cadena <> '' then begin if Posicion <> 0 then while Posicion <> 0 do begin Delete(Cadena,1,Posicion); Posicion := Pos(Separador,Cadena); Inc (Result); end; end else Result := 0; end; function GetToken(sCadena, sSeparador: String; iToken: Integer): String; var iPosicion: Integer; begin while iToken > 1 do begin Delete(sCadena, 1, Pos(sSeparador,sCadena) + Length(sSeparador) - 1); Dec(iToken); end; iPosicion := Pos(sSeparador, sCadena); if iPosicion = 0 then Result:= sCadena else Result:= Copy(sCadena, 1, iPosicion - 1); end; function SimlFeistel(sh, precode:string) : string; var i,prenck : integer; nck,nck2: string; begin for i:=1 to precode.Length do if i mod 2 = 1 then begin nck:=sh[i]+sh[i+1]; nck2:=precode[i]+precode[i+1]; prenck:= ( (HexToInt(nck)+ HexToInt(nck2)) mod 10); result:=result+'0'+ prenck.ToString; end; end; function SL3_CALC_NCK(TARGET_HASH, MASTER_SP_CODE : string):string; var Data, precode, levelhash : string; sh, precode7, precode8, final : string; i, j, magic : integer; TCod :String; begin MASTER_SP_CODE:='000000'+Copy(MASTER_SP_CODE, 1, 24); for i:=1 to 7 do begin levelhash:=My_SHA1('0'+ i.ToString +TARGET_HASH); precode8:=Copy(MASTER_SP_CODE, 0,16); precode7:=Copy(MASTER_SP_CODE, 17,30); for magic:=0 to 1 do begin sh:=My_SHA1('0'+ magic.ToString + Copy(levelhash, 0,32) + precode8); precode:=''; Precode:=SimlFeistel(sh, precode7); precode7:=precode; sh:=My_SHA1('0'+ magic.ToString +Copy(levelhash, 0,32)+precode); precode:=''; Precode:=SimlFeistel(sh, precode8); precode8:=precode; end; data:=''; final:=precode8+precode7; for j:=1 to final.Length do if j mod 2 = 1 then data:=data+ (hextoint(final[j]+final[j+1])).ToString ; //ADDLine('#pw+'+data+'+'+inttostr(i)+'#'); data := '#pw+' + data + '+' + i.ToString +'#'; if (i = 1) then Result := (data) else Result := Result+','+(data); end; end; end. Last edited by helpinterchange; 07-30-2013 at 22:03. Reason: Changes in code |
The Following User Says Thank You to helpinterchange For This Useful Post: |
