GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
07-03-2014, 14:14 | #16 (permalink) |
Banned Join Date: Nov 2013 Location: Chicago, IL
Member: 2076039 Status: Offline Thanks Meter: 648 | Also...how do you plan on writing the IMEI? If you have difficulty resetting the EFS without a box, you'll find it a hundred times more difficult writing the IMEI to the device without a box. |
07-03-2014, 23:24 | #17 (permalink) | |
Junior Member Join Date: Jun 2012
Member: 1769516 Status: Offline Thanks Meter: 0 | Quote:
Any idea to connect my phone to another carrier without reseting to orginal imei??? | |
07-04-2014, 04:27 | #18 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | Write a service imei that isn't blacklisted...? You're gonna need either Octopus box or SPT box for this. Unless you're gonna follow the rabbit hole on AT commands and make your own UART cable. |
07-04-2014, 11:39 | #19 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: USA Age: 39
Member: 67927 Status: Offline Thanks Meter: 108 | Quote:
Reading pit file via download mode is never blocked, in fact it is necessary to flash anything to the phone. Everytime you flash anything using odin or any other software, that software must first read the PIT in order to correctly flash those certain partitions into the MMC. | |
07-05-2014, 16:23 | #20 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | I've tried writing backups of modemst1 and modemst2. It never rebuilds the entire EFS for me unless I restore all 3. And Heimdall is unable to read the PIT of some Kit Kat devices such as the N900T and N900A. I was able to utilize Heimdall during 4.3. As soon as 4.4.2 official dropped, bam no more PIT reading by Heimdall. Odin however still works (thankfully) but I haven't quite found out how to inject FSG via Odin. I think I was successful once but the Modem blocked the file from being written to the partition. |
07-07-2014, 08:10 | #21 (permalink) |
Freak Poster Join Date: Feb 2007 Location: /system/bin Age: 31
Member: 446169 Status: Offline Sonork: 100.1601454 Thanks Meter: 30 | So can we read write akey or spc in samsung cdma android phones with this 'At' commands ( with rj45 cable )..? If yes can u share those at-command sorry for hurry ...... |
07-07-2014, 18:55 | #22 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | No, we're strictly talking about GSM phones. I used some AT commands commonly used on GSM phones, but on the Sprint S5 as a test since I didn't have any GSM phones handy. This is to read the AKSEED used to calculate the one to send back, and to read the MSL on the modem (NOT QC COM PORT!!!!) to calculate and send back too. The details are in the majority of dest's posts on the first page of this thread. |
09-30-2014, 22:40 | #24 (permalink) |
Junior Member Join Date: Oct 2006
Member: 372813 Status: Offline Thanks Meter: 1 | This portion of code calculates the akseedno, making the debug line by line, is clearly seen when making value (AKSEEDNO=1,0) and calculated, then returns the calculated value ... Someone understands better than me? For example, IN AKSEEDNO=1,0 (25021-245-2747) and calculates the AKSEEDNO=0,("6020-96-134") Code: 007C3FC0 /> 55 PUSH EBP (BREACKPOINT) 007C3FC1 |. 8BEC MOV EBP,ESP 007C3FC3 |. 81EC E0000000 SUB ESP,0E0 007C3FC9 |. 53 PUSH EBX 007C3FCA |. 56 PUSH ESI 007C3FCB |. 57 PUSH EDI 007C3FCC |. 51 PUSH ECX 007C3FCD |. 8DBD 20FFFFFF LEA EDI,DWORD PTR SS:[EBP-E0] 007C3FD3 |. B9 38000000 MOV ECX,38 007C3FD8 |. B8 CCCCCCCC MOV EAX,CCCCCCCC 007C3FDD |. F3:AB REP STOS DWORD PTR ES:[EDI] 007C3FDF |. 59 POP ECX 007C3FE0 |. 894D FC MOV DWORD PTR SS:[EBP-4],ECX 007C3FE3 |. C745 EC 000000>MOV DWORD PTR SS:[EBP-14],0 007C3FEA |. 8B45 EC MOV EAX,DWORD PTR SS:[EBP-14] 007C3FED |. 8945 F0 MOV DWORD PTR SS:[EBP-10],EAX 007C3FF0 |. 8B4D F0 MOV ECX,DWORD PTR SS:[EBP-10] 007C3FF3 |. 894D F4 MOV DWORD PTR SS:[EBP-C],ECX 007C3FF6 |. 8B55 F4 MOV EDX,DWORD PTR SS:[EBP-C] 007C3FF9 |. 8955 F8 MOV DWORD PTR SS:[EBP-8],EDX 007C3FFC |. 6A 00 PUSH 0 007C3FFE |. 6A 2D PUSH 2D 007C4000 |. 8B45 08 MOV EAX,DWORD PTR SS:[EBP+8] 007C4003 |. 50 PUSH EAX 007C4004 |. 8B4D FC MOV ECX,DWORD PTR SS:[EBP-4] 007C4007 |. E8 39EFC3FF CALL UMTS_IME.00402F45 007C400C |. 8945 F8 MOV DWORD PTR SS:[EBP-8],EAX 007C400F |. 8B4D F8 MOV ECX,DWORD PTR SS:[EBP-8] 007C4012 |. 51 PUSH ECX 007C4013 |. 6A 00 PUSH 0 007C4015 |. 6A 00 PUSH 0 007C4017 |. 8B55 08 MOV EDX,DWORD PTR SS:[EBP+8] 007C401A |. 52 PUSH EDX 007C401B |. 8D85 68FFFFFF LEA EAX,DWORD PTR SS:[EBP-98] 007C4021 |. 50 PUSH EAX 007C4022 |. 8B4D FC MOV ECX,DWORD PTR SS:[EBP-4] 007C4025 |. E8 5433C4FF CALL UMTS_IME.0040737E 007C402A |. 8B4D F8 MOV ECX,DWORD PTR SS:[EBP-8] 007C402D |. C6840D 68FFFFF>MOV BYTE PTR SS:[EBP+ECX-98],0 007C4035 |. 8D95 68FFFFFF LEA EDX,DWORD PTR SS:[EBP-98] 007C403B |. 52 PUSH EDX ; /Arg1 007C403C |. E8 DF390D00 CALL UMTS_IME.00897A20 ; \UMTS_IME.00897A20 007C4041 |. 83C4 04 ADD ESP,4 007C4044 |. DD5D E4 FSTP QWORD PTR SS:[EBP-1C] 007C4047 |. 8B45 F8 MOV EAX,DWORD PTR SS:[EBP-8] 007C404A |. 83C0 01 ADD EAX,1 007C404D |. 8945 F4 MOV DWORD PTR SS:[EBP-C],EAX 007C4050 |. C685 68FFFFFF >MOV BYTE PTR SS:[EBP-98],0 007C4057 |. 8B4D F4 MOV ECX,DWORD PTR SS:[EBP-C] 007C405A |. 51 PUSH ECX 007C405B |. 6A 2D PUSH 2D 007C405D |. 8B55 08 MOV EDX,DWORD PTR SS:[EBP+8] 007C4060 |. 52 PUSH EDX 007C4061 |. 8B4D FC MOV ECX,DWORD PTR SS:[EBP-4] 007C4064 |. E8 DCEEC3FF CALL UMTS_IME.00402F45 007C4069 |. 8945 F8 MOV DWORD PTR SS:[EBP-8],EAX 007C406C |. 8B45 F8 MOV EAX,DWORD PTR SS:[EBP-8] 007C406F |. 2B45 F4 SUB EAX,DWORD PTR SS:[EBP-C] 007C4072 |. 50 PUSH EAX 007C4073 |. 8B4D F4 MOV ECX,DWORD PTR SS:[EBP-C] 007C4076 |. 51 PUSH ECX 007C4077 |. 6A 00 PUSH 0 007C4079 |. 8B55 08 MOV EDX,DWORD PTR SS:[EBP+8] 007C407C |. 52 PUSH EDX 007C407D |. 8D85 68FFFFFF LEA EAX,DWORD PTR SS:[EBP-98] 007C4083 |. 50 PUSH EAX 007C4084 |. 8B4D FC MOV ECX,DWORD PTR SS:[EBP-4] 007C4087 |. E8 F232C4FF CALL UMTS_IME.0040737E 007C408C |. 8B4D F8 MOV ECX,DWORD PTR SS:[EBP-8] 007C408F |. 2B4D F4 SUB ECX,DWORD PTR SS:[EBP-C] 007C4092 |. C6840D 68FFFFF>MOV BYTE PTR SS:[EBP+ECX-98],0 007C409A |. 8D95 68FFFFFF LEA EDX,DWORD PTR SS:[EBP-98] 007C40A0 |. 52 PUSH EDX ; /Arg1 007C40A1 |. E8 7A390D00 CALL UMTS_IME.00897A20 ; \UMTS_IME.00897A20 007C40A6 |. 83C4 04 ADD ESP,4 007C40A9 |. DD5D DC FSTP QWORD PTR SS:[EBP-24] 007C40AC |. 8B45 F8 MOV EAX,DWORD PTR SS:[EBP-8] 007C40AF |. 83C0 01 ADD EAX,1 007C40B2 |. 8945 F4 MOV DWORD PTR SS:[EBP-C],EAX 007C40B5 |. C685 68FFFFFF >MOV BYTE PTR SS:[EBP-98],0 007C40BC |. 8B4D 08 MOV ECX,DWORD PTR SS:[EBP+8] 007C40BF |. 51 PUSH ECX 007C40C0 |. E8 FBF70C00 CALL UMTS_IME.008938C0 007C40C5 |. 83C4 04 ADD ESP,4 007C40C8 |. 2B45 F8 SUB EAX,DWORD PTR SS:[EBP-8] 007C40CB |. 50 PUSH EAX 007C40CC |. 8B55 F4 MOV EDX,DWORD PTR SS:[EBP-C] 007C40CF |. 52 PUSH EDX 007C40D0 |. 6A 00 PUSH 0 (BREACKPOINT) 007C40D2 |. 8B45 08 MOV EAX,DWORD PTR SS:[EBP+8] 007C40D5 |. 50 PUSH EAX 007C40D6 |. 8D8D 68FFFFFF LEA ECX,DWORD PTR SS:[EBP-98] 007C40DC |. 51 PUSH ECX 007C40DD |. 8B4D FC MOV ECX,DWORD PTR SS:[EBP-4] 007C40E0 |. E8 9932C4FF CALL UMTS_IME.0040737E 007C40E5 |. 8B55 08 MOV EDX,DWORD PTR SS:[EBP+8] 007C40E8 |. 52 PUSH EDX 007C40E9 |. E8 D2F70C00 CALL UMTS_IME.008938C0 007C40EE |. 83C4 04 ADD ESP,4 007C40F1 |. 2B45 F8 SUB EAX,DWORD PTR SS:[EBP-8] 007C40F4 |. C68405 68FFFFF>MOV BYTE PTR SS:[EBP+EAX-98],0 007C40FC |. 8D85 68FFFFFF LEA EAX,DWORD PTR SS:[EBP-98] 007C4102 |. 50 PUSH EAX ; /Arg1 007C4103 |. E8 18390D00 CALL UMTS_IME.00897A20 ; \UMTS_IME.00897A20 007C4108 |. 83C4 04 ADD ESP,4 007C410B |. DD5D D4 FSTP QWORD PTR SS:[EBP-2C] 007C410E |. 8B4D E8 MOV ECX,DWORD PTR SS:[EBP-18] 007C4111 |. 51 PUSH ECX 007C4112 |. 8B55 E4 MOV EDX,DWORD PTR SS:[EBP-1C] 007C4115 |. 52 PUSH EDX 007C4116 |. 8B45 D8 MOV EAX,DWORD PTR SS:[EBP-28] 007C4119 |. 50 PUSH EAX 007C411A |. 8B4D D4 MOV ECX,DWORD PTR SS:[EBP-2C] 007C411D |. 51 PUSH ECX 007C411E |. 8B55 E0 MOV EDX,DWORD PTR SS:[EBP-20] 007C4121 |. 52 PUSH EDX 007C4122 |. 8B45 DC MOV EAX,DWORD PTR SS:[EBP-24] 007C4125 |. 50 PUSH EAX 007C4126 |. 8B4D FC MOV ECX,DWORD PTR SS:[EBP-4] 007C4129 |. E8 FD0CC4FF CALL UMTS_IME.00404E2B 007C412E |. DD5D CC FSTP QWORD PTR SS:[EBP-34] 007C4131 |. 8B4D E8 MOV ECX,DWORD PTR SS:[EBP-18] 007C4134 |. 51 PUSH ECX 007C4135 |. 8B55 E4 MOV EDX,DWORD PTR SS:[EBP-1C] 007C4138 |. 52 PUSH EDX 007C4139 |. E8 E62F0D00 CALL UMTS_IME.00897124 007C413E |. DD1C24 FSTP QWORD PTR SS:[ESP] 007C4141 |. DD45 E4 FLD QWORD PTR SS:[EBP-1C] 007C4144 |. DC0D 28BDCF00 FMUL QWORD PTR DS:[CFBD28] 007C414A |. 83EC 08 SUB ESP,8 007C414D |. DD1C24 FSTP QWORD PTR SS:[ESP] 007C4150 |. E8 7B2F0D00 CALL UMTS_IME.008970D0 007C4155 |. 83C4 08 ADD ESP,8 007C4158 |. DD1C24 FSTP QWORD PTR SS:[ESP] 007C415B |. 8B4D FC MOV ECX,DWORD PTR SS:[EBP-4] 007C415E |. E8 0002C4FF CALL UMTS_IME.00404363 007C4163 |. 8945 F0 MOV DWORD PTR SS:[EBP-10],EAX 007C4166 |. DD45 DC FLD QWORD PTR SS:[EBP-24] 007C4169 |. DC4D E4 FMUL QWORD PTR SS:[EBP-1C] 007C416C |. DC75 E4 FDIV QWORD PTR SS:[EBP-1C] 007C416F |. DD9D 60FFFFFF FSTP QWORD PTR SS:[EBP-A0] 007C4175 |. 8B45 E0 MOV EAX,DWORD PTR SS:[EBP-20] 007C4178 |. 50 PUSH EAX 007C4179 |. 8B4D DC MOV ECX,DWORD PTR SS:[EBP-24] 007C417C |. 51 PUSH ECX 007C417D |. E8 A22F0D00 CALL UMTS_IME.00897124 007C4182 |. 83C4 08 ADD ESP,8 007C4185 |. DCBD 60FFFFFF FDIVR QWORD PTR SS:[EBP-A0] 007C418B |. 83EC 08 SUB ESP,8 007C418E |. DD1C24 FSTP QWORD PTR SS:[ESP] 007C4191 |. 8B4D FC MOV ECX,DWORD PTR SS:[EBP-4] 007C4194 |. E8 CA01C4FF CALL UMTS_IME.00404363 007C4199 |. 8945 EC MOV DWORD PTR SS:[EBP-14],EAX 007C419C |. 8B55 EC MOV EDX,DWORD PTR SS:[EBP-14] 007C419F |. 83C2 59 ADD EDX,59 007C41A2 |. 52 PUSH EDX ; /Arg8 007C41A3 |. 6A 2D PUSH 2D ; |Arg7 = 0000002D 007C41A5 |. 8B45 F0 MOV EAX,DWORD PTR SS:[EBP-10] ; | 007C41A8 |. 83C0 59 ADD EAX,59 ; | 007C41AB |. 50 PUSH EAX ; |Arg6 007C41AC |. 6A 2D PUSH 2D ; |Arg5 = 0000002D 007C41AE |. DD45 CC FLD QWORD PTR SS:[EBP-34] ; | 007C41B1 |. DC05 9839D500 FADD QWORD PTR DS:[D53998] ; | 007C41B7 |. 83EC 08 SUB ESP,8 ; | 007C41BA |. DD1C24 FSTP QWORD PTR SS:[ESP] ; |Arg3 (8-byte) 007C41BD |. 68 8439D500 PUSH UMTS_IME.00D53984 ; |Arg2 = 00D53984 ASCII "%.0f%c%ld%c%ld" 007C41C2 |. 8D8D 68FFFFFF LEA ECX,DWORD PTR SS:[EBP-98] ; | 007C41C8 |. 51 PUSH ECX ; |Arg1 007C41C9 |. E8 32E70C00 CALL UMTS_IME.00892900 ; \UMTS_IME.00892900 007C41CE |. 83C4 20 ADD ESP,20 007C41D1 |. 8D95 68FFFFFF LEA EDX,DWORD PTR SS:[EBP-98] 007C41D7 |. 52 PUSH EDX 007C41D8 |. 8B45 0C MOV EAX,DWORD PTR SS:[EBP+C] 007C41DB |. 50 PUSH EAX 007C41DC |. E8 DFEE0C00 CALL UMTS_IME.008930C0 007C41E1 |. 83C4 08 ADD ESP,8 007C41E4 |. 5F POP EDI 007C41E5 |. 5E POP ESI 007C41E6 |. 5B POP EBX 007C41E7 |. 81C4 E0000000 ADD ESP,0E0 007C41ED |. 3BEC CMP EBP,ESP 007C41EF |. E8 CCE60C00 CALL UMTS_IME.008928C0 007C41F4 |. 8BE5 MOV ESP,EBP 007C41F6 |. 5D POP EBP 007C41F7 \. C2 0800 RETN 8 |
10-01-2014, 08:06 | #25 (permalink) | |
No Life Poster Join Date: Oct 2006
Member: 365730 Status: Offline Thanks Meter: 84 | Quote:
like to know what is reason of network loss in some models after imei repair,and what is done for network repair. | |
10-01-2014, 14:35 | #26 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | The network loss is probably because everyone is using the same damn super IMEIs in one location. Solution? Find a method to sign the IMEI after its written so you don't have to use a Super IMEI. |
10-07-2014, 17:39 | #27 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,778 | Quote:
although, it's not cheap ... but at least is possible now. p.s. It's not any 3rd-party method, because there is no way to sign IMEI, other than Sammy does, so it's original factory solution. p.s.2 - check attachment b.r. Alex Last edited by Brka; 10-07-2014 at 17:46. | |
10-21-2014, 04:37 | #29 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Albuquerque NM
Member: 1808628 Status: Offline Thanks Meter: 26 | I can communicate by putty and UART box, but when i tried to write IMEI always get MSL auth error. Can someone help me to bypass MSL and AKSEENDO, I already catch like 7 certs with Dase ul and wants to write to test units. |
10-21-2014, 21:32 | #30 (permalink) |
Member: 2076039 Status: Offline Thanks Meter: 648 | The MSL can be found in the Daseul log ONLY IF you've reset the default EFS (otherwise it'll give you the MSL for that exact phone you're working on, which won't help for future phones you service). The AKSEEDNO I doubt anyone can really help you out with. I assume most if not all of the box companies have some kind of algo calculator built inside of them where it calculates the AKSEEDNO, but I haven't seen any public documentation on any tools or methods to calculate it. One work-around is to use a box (I'd prefer to use the SPT box in this case) to send the calculated AKSEEDNO. You perform the IMEI repair operation with the box, and untick reset/restart phone. You need the phone to still be ON after the IMEI repair. After repairing with the box the cert will fail. It's at this point you use the terminal to repair the CERT. You won't get MSL auth error or AKSEEDNO error because the box has already sent it. IF you restart the phone between the IMEI repair and the CERT repair it'll forget the box sent the MSL and AKSEEDNO and you'll be back at step 1. |
The Following 5 Users Say Thank You to ecs87 For This Useful Post: |
