GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
10-22-2014, 02:39 | #31 (permalink) | |
Freak Poster Join Date: Sep 2012 Location: Albuquerque NM
Member: 1808628 Status: Offline Thanks Meter: 26 | Quote:
Ok, Im doing that you told me, but when im trying to insert certs, I am getting: +IMEISIGN:2, OK but cert still fail, If i run AT+IMEISIGN get N/A Do you think my certs are not good? | |
10-22-2014, 03:14 | #32 (permalink) |
No Life Poster Join Date: Jun 2004 Location: USA Age: 39
Member: 67927 Status: Offline Thanks Meter: 108 | I think you are running the commands incorrectly. First you need to clear imei cert by: AT+IMEISIGN=1,2,0 then you need the certs, which are 5 different AT+IMEISIGN=2,1,[certs] then you need to close cert writing: AT+IMEISIGN=2,1,FF and finally you need phone to verify certs: AT+IMEISIGN=0,1,0 and each commands must respond with OK. |
The Following 5 Users Say Thank You to dest For This Useful Post: |
10-22-2014, 03:57 | #33 (permalink) | |
10-22-2014, 21:43 | #34 (permalink) | |
I noticed that i have to repeat the command twice to get it work. My last question is if we need 5 certs why some certs file have 3 certs only. Can we try just with 3 certs? | |
The Following 2 Users Say Thank You to xk3r For This Useful Post: |
10-30-2014, 22:03 | #36 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | It's really interesting. Hi dest, how can I find Certs. Quote:
10-31-2014, 01:25 | #37 (permalink) |
Freak Poster Join Date: Jan 2014
Member: 2103848 Status: Offline Thanks Meter: 35 | ^^^You can either buy trade or pull logs to get certs...but that's it..unless u are one of the very few people that have possession of Samsung private key used to calculate imei certification ...the reason why pulling from a Exynos processor and writing to a Qualcomm doesn't work is because Exynos has 3 imei certs and Qualcomm uses 5... |
The Following 3 Users Say Thank You to ihack43 For This Useful Post: |
11-01-2014, 07:07 | #38 (permalink) | |
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | Quote:
11-02-2014, 23:30 | #39 (permalink) |
Insane Poster Join Date: Oct 2009 Location: INN da STREETZ of LA
Member: 1138172 Status: Offline Thanks Meter: 5 | g900f Noticed g900f has 3 cert's??? 1,imei sign 2,pub key 3,pub key Is that correct??? if not can someone upload image of LOG. Thanks want to be on same page. |
11-06-2014, 01:11 | #40 (permalink) |
Junior Member Join Date: Mar 2006
Member: 242888 Status: Offline Thanks Meter: 0 | Urgent Hi there, this is my research experience with SM G900m: 1.- I was able to force another tool calculate ackseed for me on the fly. Using mitm atack. 2.- I was able to force same tool send any IMEI and Sing it for me. 3.- I was able to make baseband mistake calculating Imei check digit (15th), and preserve the IMEI CERT: PASS. 4.- Unfortunatelly Carriers on my country use the first 14 digits to validate phone on its network. Conclusion, Certs are the problem to repair to any imei. I thing we have the same tools right now for imei repair. We just need a way to dump the Certs of phones that are blacklisted on one country and use it outside. So we can interchage certs and create a database to avoid clonning the imeis in the same country. |
11-06-2014, 18:16 | #41 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,777 | Quote:
and when I opened it, I saw it's missing most of radio parts (baseband chip was there, but PFO's, switch, filters, antenna connector - missing on board) Are you saying that your test/demo units have mentioned radio parts ? if so, writing imei / certs will defintaly make them work ... b.r. Alex | |
11-18-2014, 20:48 | #42 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: NYC
Member: 416710 Status: Offline Thanks Meter: 391 | Quote:
