Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 11-18-2014, 22:54   #46 (permalink)
Member: 2076039
Thanks Meter: 648
You're going to need to buy a CERT or: buy a G900H, read the cert and use that to write to your other phones. There are no other choices. I know...it's ****ty.
Old 11-19-2014, 07:55   #47 (permalink)
Member: 2076039
Thanks Meter: 648
Its not really a business of selling it rather than having a way out should one of your associates decide to go rogue and start insurance claims on that IMEI. At least you have enough money to buy another CERT/G900F. There's no use selling it if you can't cover your behind.
Old 11-25-2014, 22:36   #48 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
Okay Guys, going through the thread, its a crash program of what i am about to start hacking in, phones.
But my smart friends, i have heard of a guy who can change the imei of G900F using his bare hands, wifi maybe. is that possible,or a dupe?
Old 11-25-2014, 22:41   #49 (permalink)
Member: 2140825
Thanks Meter: 5
any body have idea of commands that need to be sent to efs wipe note 4 the partitions are larger than its previous models standard commands not working.
Old 11-25-2014, 22:46   #50 (permalink)
Member: 984046
Thanks Meter: 255
Your frends are too smart for us.
Please don't inform them about our existance.
Old 11-26-2014, 00:33   #51 (permalink)
Member: 2076039
Thanks Meter: 648
Lol Haltec. Are they going to steal us away from the community, lock us away in a room and force us to patch security holes?!
No one other than probably some Samsung devs can create a CERT from scratch.
How do you know that the old EFS wipe method doesnt work? I'm pretty sure you're experiencing what other users are. You don't just click wipe EFS...most of the time it requires a battery pull beforehand.
The Following User Says Thank You to ecs87 For This Useful Post:
Old 11-26-2014, 00:48   #52 (permalink)
Member: 2140825
Thanks Meter: 5
U may be right as i may be going at it wrong i did read somewhere about taping a tab on battery maybe it does a voltage bypass. I was usong adb wipe on n3 and s5 i usually don't use a box for the wipe. So are you inferring battery pull before start or... Thanks for reply
Old 12-08-2014, 06:16   #53 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
i was going to post a link?
Old 12-08-2014, 06:58   #54 (permalink)
Moderator
Member: 73
Thanks Meter: 537
Why need WIPE EFS?
Have another method:
1. Read CPU_ID
2. Read NV_DATA.BIN ... or similar area
3. Decrypt ... do something what you want
4. Crypt back and return to phone
__________________
You'll die as you lived in a flash of the blade,
in a corner forgotten by no one
You lived for the touch for the feel of the steel
One man, and his honor.
Old 12-08-2014, 15:06   #55 (permalink)
Member: 2076039
Thanks Meter: 648
Originally Posted by Victor View Post
Why need WIPE EFS?
1. Read CPU_ID
Hi Victor,
You might be a little outdated lol. Qualcomm phones don't seem to use nv_data.bin anymore. The NV data is scattered across three different partitions (maybe now 4 on the Note 4).
Old 12-08-2014, 15:36   #56 (permalink)
Moderator
Member: 73
Thanks Meter: 537
Originally Posted by ecs87 View Post
Hi Victor,
How you interpret following:
"NV_DATA.BIN ... or similar area"
- excact NV_DATA.BIN file
- "similar area" as same functionality
in broadcomm is not only one file.
imeiitem.bin, prodcode.dat etc.
Latest I reverse XMM6260 and is nv_data.bin
Regards: Victor
__________________
Old 12-08-2014, 18:00   #57 (permalink)
Member: 2076039
Thanks Meter: 648
The thing is, we can't decrypt the partitions holding the EFS data. If you even try pulling the EFS data partitions and loading them to another phone, it screws up the EFS and the baseband becomes unknown. This would be a backup from the SAME EXACT PHONE MODEL. You'd think it'd just screw up the EFS; no clue why it "corrupts" the baseband too. Probably because it's memory residing on the same processing chip (CP instead of AP).
Old 12-08-2014, 19:35   #58 (permalink)
Moderator
Member: 73
Thanks Meter: 537
Things are verry easy. Is named CPU ID. Crypto stuff is linked with cpuid as unique parameter. Ofcourse in wrong cpuid will fall all decryption and baseband recognition will fall.
In broadcomm cpuid is still hard coded in fware, infineon/intel xmms using scuid registers, Qualcomm old is hardcoded new is hardcoded data plus additional crypto.
__________________
Old 12-09-2014, 17:22   #59 (permalink)
Member: 2076039
Thanks Meter: 648
Easy? This is definitely currently over my head. I assume because I don't have any JTAG experience?
Old 12-09-2014, 17:39   #60 (permalink)
Moderator
Member: 73
Thanks Meter: 537
No not need jtag experience. After lot of disassembly *.so files from /lib/ folder will see how to read SCU_ID from XMMXXXX family cpus. Broadcomm still using hard coded HW_ID.
This is hard to read ID...
... other is standart cryptography.
__________________
Page generated in 0.19366 seconds with 9 queries
