GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
07-08-2006, 00:42 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Germany Age: 54
Member: 11273 Status: Offline Thanks Meter: 14 | opposit of "TNT Enforcer" best regards |
07-08-2006, 06:35 | #2 (permalink) |
No Life Poster Join Date: Jan 2005 Location: NEW DELHI, INDIA Age: 50
Member: 111665 Status: Offline Sonork: 104250 Thanks Meter: 180 | If such programme exists then it will disable all Buttons ! But I think u want to Disable only selected Buttons ! If this is so ! U need to Edit the programe ! so that u can select which buttons shall b enabled and which one should b disabled ! if U want to disable IMEI CHANGING option in any software I think u can get help its already done ! I am not a programmer ! but if u can explain more then Hope I can help u ! |
07-08-2006, 12:57 | #4 (permalink) |
No Life Poster Join Date: Dec 2004 Location: 0x001FD00
Member: 98572 Status: Offline Thanks Meter: 36 | Resource Editor may have some limitations, if the program self disable the button on the fly( when the program run), so it's better to patch the program instead. just look for WinApi EnableMenuITem (USER32.DLL) call, if you use SoftIce just bpx EnableMenuItem. the start tracing or back trace from there. Good Luck... |
11-29-2008, 13:19 | #5 (permalink) |
Junior Member Join Date: Nov 2008
Member: 912512 Status: Offline Thanks Meter: 0 | hy hy can u tell me how i can enable a disabled menu? i have a software demo.. its save . export option are disabled. is it possible to make enabled? i cant get TNT enforcer which works on xp.. i tried with resource hacer but cant do that.. any procedure tell me? thanks very much |
11-29-2008, 13:55 | #6 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Quote:
anyway use attached software it will go to task bar. click on it once it show you ON. and your ready to enable any disable button. if software is not protected from it. PS: welcome to gsmhosting | |
The Following 2 Users Say Thank You to stanner_austin For This Useful Post: |
11-30-2008, 07:52 | #7 (permalink) |
Member: 912512 Status: Offline Thanks Meter: 0 | thanks for the tool.. but not working with my software.. if u have time to check.. please http://fdsfiles.com/releases/ms1301/...demo-setup.exe thanks again |
11-30-2008, 10:11 | #8 (permalink) | |
its demo software and menu item .. sorry but i can't help you in cracking anything this is gsm / cdma forum.. you should buy that tool or check warez site for it. | |
12-01-2008, 11:33 | #9 (permalink) | |
No Life Poster Join Date: Jan 2003
Member: 20069 Status: Offline Thanks Meter: 131 | Quote:
@amitks_in, is right. for the purpose u r lookin for, u've to edit the program's source code. if u don't have any coding exp. just ask @amitks_in or one of the best programmers of the forum @due. Br | |
12-01-2008, 13:04 | #10 (permalink) | |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | Quote:
In these days, software authors usually remove routines for save, print, copy as well as just grey the box out. So even an Enforcer won't help you. As it seems you have no previous experience in this area, its better if you search for a pre-cracked version, full version with serial number, or (heaven forbid), buy the software.. Br | |
The Opposite Of Sex (???????)(Box packing, DVD5) (USA) (US Version) (Region 1) | IPMART | ipmart WebShop | 0 | 10-23-2009 07:50 |
n73 display show opposite direction and blinking why ?????????? | tiju kkm | Nokia Hardware & Hardware Repair | 5 | 04-08-2009 17:23 |
1110 after flash opposite screen | israrbjr | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 06-11-2008 07:46 |
opposit of "TNT Enforcer" | ab1009 | Off Topic Zone | 1 | 07-09-2006 14:01 |
