GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
10-07-2002, 01:30 | #2 (permalink) |
Freak Poster Join Date: Oct 2001 Location: [internet]
Member: 6877 Status: Offline Thanks Meter: 0 | Maybe you will look into chip-set internal ROM?It boots main firmware (if red-button not pressed of course,othervice it loads bootstrap via serial interface) |
10-14-2002, 02:45 | #11 (permalink) | |
Member: 6877 Status: Offline Thanks Meter: 0 | Quote:
(E.g.look how UniSiemens works and then command to S45 bootcode from UniSiemens to read from 010000h address). iROM at 010000h or at 000000h depending on configuration.Usually it can be founf at 010000h... | |
10-23-2002, 11:59 | #12 (permalink) | |
Insane Poster Join Date: Nov 2001 Location: Czech
Member: 7649 Status: Offline Thanks Meter: 1 | Quote:
I think that BW2K02 is Acid Denim double kick pleat skirt ... see here My apology to all for this reply, but isn't it good? This link is better. Last edited by GasBag; 10-23-2002 at 12:06. | |
C35 menu entry points | [ZZToP] | x1x to x45/x50 | 1 | 02-22-2004 16:37 |
Not all Entry-Points... | ProHvost | x1x to x45/x50 | 8 | 02-07-2004 07:16 |
S/ME45i entry point | digitalbrothers | x1x to x45/x50 | 1 | 01-27-2004 07:06 |
Siemens Entry Point (for Menu Items) | rizapn | GSM Programming & Reverse Engineering | 5 | 04-16-2003 20:45 |
Does anyone know program entry point of SL45? | SL45_6688i | x1x to x45/x50 | 1 | 01-22-2003 21:57 |
