GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
01-11-2013, 17:44 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Inside Vb.Net Age: 41
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | Programming with RIMRADIOCOMLib.dll Visual Basic I already have source for read basic information using USB connection without any DLL. I already can read: Pin, Imei, Mep, Vsm, Sfi, App, Prd. But i did found this another source on internet with Rimradiocomlib.dll on VB 2010 Code: Imports RIMRADIOCOMLib Public Class Form1 Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click Dim conectar As RIMRADIOCOMLib.IConnect = New RIMRadioObj conectar.Execute("USB", 5, 19000) If ConnectionState.Open Then TextBox1.Text = "conectado" Else TextBox1.Text = "Telefono no conectado" End If End Sub Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click Dim readimei As IReadIMEI = New RIMRadioObj Dim str As String = "" readimei.Execute(str) TextBox1.Text = str End Sub Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click Dim desconectar As IDisconnect = New RIMRadioObj desconectar.Execute() end sub End Class Maybe we can find something interesting on RIM Dll files Br, Josedavido |
The Following 3 Users Say Thank You to josedavido For This Useful Post: |
01-17-2013, 10:02 | #2 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | @Josedavido I think that RIM dlls use .NET... So you can try it with .NET Reflector Good Luck on your SW. B.R. |
The Following 2 Users Say Thank You to Advance-Box For This Useful Post: |
02-06-2013, 05:05 | #3 (permalink) |
Freak Poster Join Date: Jul 2006 Location: inside out
Member: 303799 Status: Offline Sonork: inside outside Thanks Meter: 59 | @X-Shadow do you have the cracked .net reflector? as I don't like filling up forms to register. Regards; |
The Following User Says Thank You to bluezak For This Useful Post: |
02-06-2013, 07:56 | #4 (permalink) | |
Moderator Join Date: May 1999 Location: Blagoevgrad, Bulgaria Age: 52
Member: 73 Status: Offline Thanks Meter: 537 | Quote:
RIM APPLICATIONS is .NET written. Specialy Rimradiocomm.dll is Visual C based. But what is problem to use from any .NET and non .NET language. this is DCOM object can be used from all. Just import Type library from dll. Regards: Victor | |
The Following 2 Users Say Thank You to Victor For This Useful Post: |
02-27-2013, 23:34 | #5 (permalink) |
Junior Member Join Date: Feb 2011
Member: 1522367 Status: Offline Thanks Meter: 16 | I get this error: "GSM Radio not connected. Cannot access ID. Cannot read IMEI." Visual Basic .NET 2012 CODE: Code: Imports RIMRADIOCOMLib Public Class Form1 Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click Dim conectar As IConnection = New RIMRadioObj Dim Imei As IReadIMEI = New RIMRadioObj Dim StrImei As String = "" conectar.Connect("USB", 300, 19200, "") Imei.Execute(StrImei) MsgBox(StrImei) End Sub "GSM Radio not connected. Cannot access ID. Cannot read IMEI." RIMRADIOCOMLib need RTAS for get imei??? |
The Following User Says Thank You to my_sistemas For This Useful Post: |
