Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 01-11-2013, 17:44   #1 (permalink)
josedavido's Avatar
Member: 140822
Sonork: 100.1594493
Thanks Meter: 1,010
Programming with RIMRADIOCOMLib.dll Visual Basic
Hello friends.
I already have source for read basic information using USB connection without any DLL.
I already can read: Pin, Imei, Mep, Vsm, Sfi, App, Prd.
But i did found this another source on internet with Rimradiocomlib.dll on VB 2010
Imports RIMRADIOCOMLib
Public Class Form1
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim conectar As RIMRADIOCOMLib.IConnect = New RIMRadioObj
conectar.Execute("USB", 5, 19000)
If ConnectionState.Open Then
TextBox1.Text = "conectado"
Else
TextBox1.Text = "Telefono no conectado"
End If
End Sub
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
Dim readimei As IReadIMEI = New RIMRadioObj
Dim str As String = ""
readimei.Execute(str)
TextBox1.Text = str
End Sub
Private Sub Button3_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
Dim desconectar As IDisconnect = New RIMRadioObj
desconectar.Execute()
end sub
End Class
It is just for read the imei, so, i am interested to know if somwbody have the other commands for read Mep, Prd, and more important info using this dll.
Maybe we can find something interesting on RIM Dll files
Br,
Josedavido
The Following 3 Users Say Thank You to josedavido For This Useful Post:
Old 01-17-2013, 10:02   #2 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@Josedavido
I think that RIM dlls use .NET... So you can try it with
.NET Reflector
Good Luck on your SW.
B.R.
The Following 2 Users Say Thank You to Advance-Box For This Useful Post:
Old 02-06-2013, 05:05   #3 (permalink)
Member: 303799
Sonork: inside outside
Thanks Meter: 59
@X-Shadow
do you have the cracked .net reflector? as I don't like filling up forms to register.
Regards;
The Following User Says Thank You to bluezak For This Useful Post:
Old 02-06-2013, 07:56   #4 (permalink)
Moderator
Member: 73
Thanks Meter: 537
Originally Posted by Advance-Box View Post
@Josedavido
.NET Reflector
B.R.
You are wrong.
RIM APPLICATIONS is .NET written. Specialy Rimradiocomm.dll is Visual C based. But what is problem to use from any .NET and non .NET language. this is DCOM object can be used from all. Just import Type library from dll.
Regards: Victor
The Following 2 Users Say Thank You to Victor For This Useful Post:
Old 02-27-2013, 23:34   #5 (permalink)
Member: 1522367
Thanks Meter: 16
I get this error:
"GSM Radio not connected. Cannot access ID. Cannot read IMEI."
Visual Basic .NET 2012
CODE:
Public Class Form1
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Dim conectar As IConnection = New RIMRadioObj
        Dim Imei As IReadIMEI = New RIMRadioObj
        Dim StrImei As String = ""
        conectar.Connect("USB", 300, 19200, "")
        Imei.Execute(StrImei)
        MsgBox(StrImei)
    End Sub
Connection its ok but in Imei.Execute(StrImei) line i get this error
RIMRADIOCOMLib need RTAS for get imei???
The Following User Says Thank You to my_sistemas For This Useful Post:
Old 03-03-2013, 16:21   #6 (permalink)
Member: 1712596
Thanks Meter: 25
do you have a software with base on bbcfpcom.dll or cfpcom.dll??? not shell comand cfp.exe hehehe
Old 04-14-2013, 13:01   #7 (permalink)
Member: 1385851
help me for use RIMRADIOCOMLib.dl on vb 2008
Old 08-26-2015, 09:26   #8 (permalink)
Member: 2402192
help me sourcode button connet/disconnet to blackberry
Page generated in 0.17600 seconds with 8 queries
