GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
10-03-2012, 00:29 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Inside Vb.Net Age: 41
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | Project: Repair Blackberry Error 507 without Flashing Error 507 means: the dependency of a .cod can't be satisfied doe to a .cod file missed or corrupted. I think is possible to make a "one click" solution to fix this problem. 1- Read all the event log 2- analyze the list and find the corrupted or missed .cod files 3- write or replace the curren .cod files 4- phone fixed we can use the Javaloader and next command: Code: -u eventlog > eventlog.txt but i don't have a phone in error 507 on heands. if you help me to get this eventlog and analyze it i promisse to post the solution or source code here. Br, Josedavido |
The Following User Says Thank You to josedavido For This Useful Post: |
10-12-2012, 19:33 | #6 (permalink) |
Junior Member Join Date: Nov 2011 Location: Newquay Cornwall
Member: 1687105 Status: Offline Thanks Meter: 0 | use free tool like bbsak to backup cods then delete the ones on the phone. Is your problem fixed? Can you still access the phone via USB on my computer? |
10-15-2012, 05:37 | #7 (permalink) |
No Life Poster Join Date: Mar 2011
Member: 1544019 Status: Offline Thanks Meter: 31 | Please look at my problem: http://forum.gsmhosting.com/vbb/f489...tacts-1546811/. I think its the perfect case for this!! |
10-16-2012, 18:56 | #8 (permalink) | ||
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | First Steps on Investigation Blackberry 8520 Error 200 Quote:
This is the most important part: Quote:
This is the corrupted file: net_rim_cldc.cod | ||
10-17-2012, 22:14 | #13 (permalink) | |||||
Member: 140822 Status: Offline Sonork: 100.1594493 Thanks Meter: 1,010 | Quote:
Br, Josedavido | |||||
10-27-2012, 18:54 | #15 (permalink) |
Insane Poster Join Date: Jan 2012
Member: 1712596 Status: Offline Thanks Meter: 25 | first step 1.- open bbsak 2.-connect phone 3.-select misc. 4.- read Event log 5. save event log 6.-select Modify CODs 7.-read System 8.-save read. (backup apps) now. open file eventlof.txt 1.-ctrl+b 2.- "ERROR" first guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:35:17 2012 severity:1 type:3 app:Java Exception data: NullPointerException No detail message net_rim_bb_qm_yahoo-9 (ONE ERROR) PackageManager registerOnceOnInstall 0x10B8 net_rim_bb_qm_yahoo-7 (ONE ERROR) ProxyEntry registerOnceOnSystemStart 0xBBF1 net_rim_bb_qm_yahoo-11 (ONE ERROR) YahooEntry registerOnceOnSystemStart 0x25B0 net_rim_bb_qm_yahoo-7 (ONE ERROR) ProxyEntry registerEntry 0xC556 net_rim_bb_qm_yahoo-11 (ONE ERROR) YahooEntry main 0x2668 TWO guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:35:17 2012 severity:1 type:3 app:Java Exception data: Error No detail message net_rim_pdap (ONE ERROR) ContactListImpl <init> 0x47B8 net_rim_pdap (ONE ERROR) PIMImpl openPIMList 0xBBFB net_rim_bb_facebook_lib (ONE ERROR) LinkedContactUtilities <clinit> 0x80F8 net_rim_bb_facebook-6 (ONE ERROR) PackageManager registerOnceOnSystemStart 0x4E66 net_rim_bb_facebook (ONE ERROR) FacebookApplication <private> 0x148C net_rim_bb_facebook (ONE ERROR) FacebookApplication main 0x1AFA THREE guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:35:27 2012 severity:1 type:3 app:Java Exception data: Error No detail message net_rim_pdap (ONE ERROR) ContactListImpl <init> 0x47B8 net_rim_pdap (ONE ERROR) PIMImpl openPIMList 0xBBFB net_rim_bb_facebook-11 (ONE ERROR) AddressBookUtilities <clinit> 0xCF5 net_rim_bb_facebook (ONE ERROR) FacebookApplication <private> 0x1536 net_rim_bb_facebook (ONE ERROR) FacebookApplication main 0x1AFA FOUR guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:35:28 2012 severity:1 type:3 app:Java Exception data: Error No detail message net_rim_pdap (ONE ERROR) ContactListImpl <init> 0x47B8 net_rim_pdap (ONE ERROR) PIMImpl openPIMList 0xBBFB net_rim_bbapi_menuitem (ONE ERROR) SdkProxyVerb <clinit> 0xA87 net_rim_bbapi_menuitem (ONE ERROR) ApplicationMenuItemRepository addMenuItem 0x2FC net_rim_bbapi_menuitem (ONE ERROR) ApplicationMenuItemRepository addMenuItem 0xDC ShareAddressBookViaBluetooth-1 BgApp <init> 0x20F ShareAddressBookViaBluetooth-1 UiApp main FIVE guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:36:23 2012 severity:1 type:3 app:Java Exception data: Error No detail message net_rim_pdap (ONE ERROR) ContactListImpl <init> 0x47B8 net_rim_pdap (ONE ERROR) PIMImpl openPIMList 0xBBFB net_rim_bb_facebook_lib (ONE ERROR) LinkedContactUtilities <clinit> 0x80F8 net_rim_bb_facebook-6 (ONE ERROR) PackageManager registerOnceOnSystemStart 0x4E66 net_rim_bb_facebook (ONE ERROR) FacebookApplication <private> 0x148C net_rim_bb_facebook (ONE ERROR) FacebookApplication main 0x1AFA 0x2B89 YOUR PHONE HAVE MULTI ERRORS 1.- SELECT IN BBSAK MODIFY CODS, SELECTION (net_rim_pdap.COD "REMOVE") (net_rim_bb_facebook_lib.COD"REMOVE") (net_rim_bb_facebook .COD "REMOVE") (net_rim_bbapi_menuitem .COD "REMOVE") (net_rim_bb_qm_yahoo "remove") after remove this files.cod, re-install files.cod removed if not soluction. the best solution is 1.- cfp.exe /u /v3 wipe -f (erase file system) ( in the lcd screen "error 5.. reload s.o") install s.o for desktop, erase vendor, execute loader.exe and run thanks |
