Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 10-03-2012, 00:29   #1 (permalink)
josedavido's Avatar
Member: 140822
Sonork: 100.1594493
Thanks Meter: 1,010
Project: Repair Blackberry Error 507 without Flashing
As we know, Blackberry phones may have some software problems, like "Error 507" and we must to flash it, and lose all our important information like Contacts and SMS.
Error 507 means: the dependency of a .cod can't be satisfied doe to a .cod file missed or corrupted.
I think is possible to make a "one click" solution to fix this problem.
1- Read all the event log
2- analyze the list and find the corrupted or missed .cod files
3- write or replace the curren .cod files
4- phone fixed
we can use the Javaloader and next command:
-u eventlog > eventlog.txt
and generate a notepad with all the phone info to analyze it.
but i don't have a phone in error 507 on heands.
if you help me to get this eventlog and analyze it i promisse to post the solution or source code here.
Br,
Josedavido
The Following User Says Thank You to josedavido For This Useful Post:
Old 10-03-2012, 01:32   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
if want make simple ,
just delete some "important" .cod from your phone , and violaa,.....
you already have "error 507" phone
BR,
Old 10-03-2012, 01:36   #3 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
It would be more effective on a "natural" 507 phone.
Max_B
Old 10-03-2012, 04:28   #4 (permalink)
Member: 704971
Thanks Meter: 4
what exactly u want to read from the phone. i receive atleast one phone every day in that problem.
Old 10-03-2012, 04:32   #5 (permalink)
Member: 527046
Thanks Meter: 97
he needs one phone with 507 jvm error for testing puposes. he will guide you to repair it without flashing.
if you have one in hand for test, just contact him
Old 10-12-2012, 19:33   #6 (permalink)
Member: 1687105
use free tool like bbsak to backup cods then delete the ones on the phone. Is your problem fixed? Can you still access the phone via USB on my computer?
Old 10-15-2012, 05:37   #7 (permalink)
Member: 1544019
Thanks Meter: 31
Please look at my problem: http://forum.gsmhosting.com/vbb/f489...tacts-1546811/. I think its the perfect case for this!!
Old 10-16-2012, 18:56   #8 (permalink)
josedavido's Avatar
Member: 140822
Sonork: 100.1594493
Thanks Meter: 1,010
First Steps on Investigation
Blackberry 8520
Error 200
Starting Proces...
RuntimeException
ApplicationRegistry.waitFor(0x1a6b4639ddd8fb4b)tim eout
net_rim_cldc-6(4A452B22)
ApplicationRegistry
<private>
0x5D8F
ApplicationRegistry
getOrWaitFor
0x589F
net_rim_cldc-14(4A452B22)
ApplicationControlImpl
<clinit>
0x3B73
ApplicationControl
assertIPCAllowed
0x2CA
Application
addGlobalEventListener
0xA8A
net_rim_cldc-16(4A452B22)
DeviceOptions
<init>
0x1F17
DeviceOptions
DeviceOptionsMain
0x1F2E
net_rim_services_impl(4A452B83)
ServiceStartup
<private>
0x3D73
ServiceStartup
main
0x3D20
guid:0x9C3CD62E3320B498time:TueFeb2819:02:152006se verity:1type:3app:JavaExceptiondata:
RuntimeException
ApplicationRegistry
<private>
0x5D8F
ApplicationRegistry
getOrWaitFor
0x589F
<clinit>
0x3B73
ApplicationControl
isWiFiAllowed
0x890
ApplicationControl
isWiFiAllowed
0x87A
ApplicationControl
assertWiFiPermitted
0x8E6
Application
addRadioListener
0x8D2
Application
addRadioListener
0x889
net_rim_cldc_io_rim_impl(4A453466)
WlanNetworkInterfaceManager
<init>
0xA274
init
0xA1F1
DefaultWlanNetworkInterfaceManager
<init>
0x310
init
0x2E5
DefaultNetworkInterfaceManager
<init>
0x203
init
0x1D1
Registration
NetworkMain
0x81A4
ServiceStartup
main
0x99B6
guid:0x9C3CD62E3320B498time:TueFeb2819:02:162006se verity:1type:3app:JavaExceptiondata:
RuntimeException
ApplicationRegistry
<private>
0x5D8F
ApplicationRegistry
getOrWaitFor
0x589F
<clinit>
0x3B73
ApplicationControl
assertIPCAllowed
0x2CA
Application
0xA8A
net_rim_crypto_1-1(4A453489)
CertificateFactory
<clinit>
0x1BE5
net_rim_crypto_1-2(4A453489)
WTLSCertificateInitialization
initialize
0x9D0D
Initializer
<private>
0x4EFB
Initializer
libMain
0x4E2A
guid:0x72BC2218B0A6112Dtime:TueFeb2819:02:232006se verity:0type:2app:net.rim.deviceagentdata:LSta1
guid:0x9C3CD62E3320B498time:TueFeb2819:04:252006se verity:1type:3app:JavaExceptiondata:
RuntimeException
ApplicationRegistry.waitFor(0x6ebc3d82c4655357)tim eout
ApplicationRegistry
<private>
0x5D8F
ApplicationRegistry
waitFor
0x5C46
ApplicationRegistry
waitFor
0x5BB1
net_rim_cldc-5(4A452B22)
LowMemoryManager
<private>
0x5596
LowMemoryManager
addLowMemoryFailedListener
0x55AF
net_rim_os-8(4A4533CF)
SerialSyncDaemon
<init>
0x8555
SerialSyncDaemon
initialize
0x8504
Registration
SynchronizationMain
0x6A30
net_rim_os-2(4A4533CF)
ServiceStartup
libMain
0xA730
RuntimeException
ApplicationRegistry
<private>
0x5D8F
ApplicationRegistry
waitFor
0x5C46
ApplicationRegistry
waitFor
0x5BB1
LowMemoryManager
<private>
0x5596
LowMemoryManager
poll
0x55F7
ApplicationManagerImpl
<private>
0x445C
<private>
0x4176
<private>
0x450F
<init>
0x4F15
net_rim_app_manager(4A452B66)
ApplicationManagerApp
main
0x2F
guid:0x72BC2218B0A6112Dtime:TueFeb2820:05:572006se verity:0type:2app:net.rim.deviceagentdata:LSta1
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:03:522006se verity:0type:2app:Systemdata:VM:0gc=0idle=0native= NONE
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:03:522006se verity:0type:2app:Systemdata:SystemStartup
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:03:522006se verity:0type:2app:Systemdata:VM:FSNHv=1
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:VM:CVER=4.6.1.272
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:WordToGo(27)nosig from0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:WordToGoResource( 48)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:WordToGoResource_ _en(51)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SlideshowToGo(54) nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SlideshowToGoReso urce(72)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SlideshowToGoReso urce__en(75)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMMocsToGoCommon(78 )nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMMocsToGoCommonRes ource(114)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMMocsToGoCommonRes ource__en(117)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SheetToGo(120)nos igfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SheetToGoResource (135)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SheetToGoResource __en(138)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:WordToGoResource_ _fr(141)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SlideshowToGoReso urce__fr(144)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMMocsToGoCommonRes ource__fr(147)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SheetToGoResource __fr(150)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:WordToGoResource_ _it(153)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SlideshowToGoReso urce__it(156)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SheetToGoResource __it(159)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMMocsToGoCommonRes ource__it(162)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:WordToGoResource_ _de(165)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SlideshowToGoReso urce__de(168)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SheetToGoResource __de(171)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMMocsToGoCommonRes ource__de(174)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:WordToGoResource_ _es(177)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SlideshowToGoReso urce__es(180)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SheetToGoResource __es(183)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMMocsToGoCommonRes ource__es(186)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:Sudoku_v42_320x24 0(200)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:SecurIDLib(617)no sigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:tsv_bubble_gum_ai r_free_320x240_4(1331)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:012006se verity:0type:2app:Systemdata:CMM:AvkoLabs_LostPand a_320_240_4(1452)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:022006se verity:0type:2app:Systemdata:CMM:net_rim_speech_da ta_en_US(3575)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:022006se verity:0type:2app:Systemdata:CMM:ZombieAttack(8414 )nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:022006se verity:0type:2app:Systemdata:CMM:cup_bombermanFree _320x240_4(8620)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:022006se verity:0type:2app:Systemdata:CMMperette$2dhifi(8 665)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:022006se verity:0type:2app:Systemdata:CMM:BloodySniper(8958 )nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:022006se verity:0type:2app:Systemdata:CMM:NinjaShooter_1_2_ 1_320x240_free_NT(9038)nosigfrom0x33
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:122006se verity:0type:2app:Systemdata:VM:PSIDv=232659
guid:0x97C9F5F641D25E5Ftime:TueFeb2822:04:232006se verity:0type:2app:Systemdata:safemode:0
guid:0x9C3CD62E3320B498time:TueFeb2822:06:362006se verity:1type:3app:JavaExceptiondata:
RuntimeException
ApplicationRegistry
<private>
0x5D8F
ApplicationRegistry
getOrWaitFor
0x589F
<clinit>
0x3B73
ApplicationControl
assertIPCAllowed
0x2CA
Application
0xA8A
DeviceOptions
<init>
0x1F17
DeviceOptions
DeviceOptionsMain
0x1F2E
ServiceStartup
<private>
0x3D73
ServiceStartup
main
0x3D20
guid:0x9C3CD62E3320B498time:TueFeb2822:06:372006se verity:1type:3app:JavaExceptiondata:
guid:0x97C9F5F641D25E5Ftime:TueFeb2823:18:092006se verity:0type:2app:Systemdata:VM:+BORK
guid:0x97C9F5F641D25E5Ftime:TueFeb2823:18:092006se verity:0type:2app:Systemdata:AppError200
guid:0x97C9F5F641D25E5Ftime:TueFeb2823:18:092006se verity:0type:2app:Systemdata:ApplicationManagerthr ewApplicationRegistry.waitFor(0x6ebc3d82c4655357)t imeout
RIM Wireless Handheld Java Loader
Copyright 2001-2010 Research In Motion Limited
Connecting to device...
Connected
Disconnected
Done---------------------------------
This is the most important part:
RuntimeException
This is the corrupted file:
net_rim_cldc.cod
Old 10-16-2012, 19:08   #9 (permalink)
Member: 1544019
Thanks Meter: 31
I have here a 9300. Please let me know what to do
Old 10-16-2012, 20:12   #10 (permalink)
Member: 678070
Thanks Meter: 28
read an event log clearly witch is error , and then install a corrupted .cod
Old 10-16-2012, 21:45   #11 (permalink)
Member: 1544019
Thanks Meter: 31
I adjunt my log. Too large for put it here!
Old 10-16-2012, 21:48   #12 (permalink)
Member: 1544019
Thanks Meter: 31
I need to read the phonebook in this phone. I see phonebook app is damaged. Where to get the cod, and how to upload it?
Old 10-17-2012, 22:14   #13 (permalink)
josedavido's Avatar
Member: 140822
Sonork: 100.1594493
Thanks Meter: 1,010
This is the important part in you log.
ClassCastException
No detail message
net_rim_bb_addressbook_app
AddressBookCollection
<init>
0x294A
getInstance
0x29F4
net_rim_bb_addressbook_app-1
BlackBerryAddressBook
<init>
0x3039
getAddressBook
0x2F7E
AddressBookApp
main
This is the corrupted APP
so, you must install this app again, this is the full app file list:
net_rim_bb_addressbook.cod
net_rim_bb_addressbook_app.cod
net_rim_bb_addressbook_gal.cod
net_rim_bb_addressbook_groupaddress.cod
net_rim_bb_addressbook_models.cod
net_rim_bb_addressbook_simapp.cod
net_rim_bb_addressbook_usimapp.cod
net_rim_bb_addressbook_vcard.cod
Install the current flash on you PC and you can find ithe files here:
C:\Program Files\Common Files\Research In Motion\Shared\Loader Files\9300\Java
Br,
Josedavido
Old 10-20-2012, 21:16   #14 (permalink)
Member: 1544019
Thanks Meter: 31
Thank u, I uploaded the files, and restarted the phone, but still giving errors. And, I try to see the contact , and phone doesnt let me do it...
Br,
Josedavido
Old 10-27-2012, 18:54   #15 (permalink)
Member: 1712596
Thanks Meter: 25
first step
1.- open bbsak
2.-connect phone
3.-select misc.
4.- read Event log
5. save event log
6.-select Modify CODs
7.-read System
8.-save read. (backup apps)
now. open file eventlof.txt
1.-ctrl+b
2.- "ERROR"
first
guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:35:17 2012 severity:1 type:3 app:Java Exception data:
NullPointerException
No detail message
net_rim_bb_qm_yahoo-9 (ONE ERROR)
PackageManager
registerOnceOnInstall
0x10B8
net_rim_bb_qm_yahoo-7 (ONE ERROR)
ProxyEntry
registerOnceOnSystemStart
0xBBF1
net_rim_bb_qm_yahoo-11 (ONE ERROR)
YahooEntry
0x25B0
ProxyEntry
registerEntry
0xC556
YahooEntry
main
0x2668
TWO
Error
No detail message
net_rim_pdap (ONE ERROR)
ContactListImpl
<init>
0x47B8
PIMImpl
openPIMList
0xBBFB
net_rim_bb_facebook_lib (ONE ERROR)
LinkedContactUtilities
<clinit>
0x80F8
net_rim_bb_facebook-6 (ONE ERROR)
PackageManager
0x4E66
net_rim_bb_facebook (ONE ERROR)
FacebookApplication
<private>
0x148C
FacebookApplication
main
0x1AFA
THREE
guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:35:27 2012 severity:1 type:3 app:Java Exception data:
Error
No detail message
ContactListImpl
<init>
0x47B8
PIMImpl
openPIMList
0xBBFB
net_rim_bb_facebook-11 (ONE ERROR)
AddressBookUtilities
<clinit>
0xCF5
FacebookApplication
<private>
0x1536
FacebookApplication
main
0x1AFA
FOUR
guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:35:28 2012 severity:1 type:3 app:Java Exception data:
Error
No detail message
ContactListImpl
<init>
0x47B8
PIMImpl
openPIMList
0xBBFB
net_rim_bbapi_menuitem (ONE ERROR)
SdkProxyVerb
<clinit>
0xA87
ApplicationMenuItemRepository
addMenuItem
0x2FC
addMenuItem
0xDC
ShareAddressBookViaBluetooth-1
BgApp
<init>
0x20F
UiApp
main
FIVE
guid:0x9C3CD62E3320B498 time: Thu Oct 04 09:36:23 2012 severity:1 type:3 app:Java Exception data:
Error
No detail message
ContactListImpl
<init>
0x47B8
PIMImpl
openPIMList
0xBBFB
<clinit>
0x80F8
PackageManager
0x4E66
FacebookApplication
<private>
0x148C
FacebookApplication
main
0x1AFA
0x2B89
YOUR PHONE HAVE MULTI ERRORS
1.- SELECT IN BBSAK MODIFY CODS, SELECTION (net_rim_pdap.COD "REMOVE") (net_rim_bb_facebook_lib.COD"REMOVE")
(net_rim_bb_facebook .COD "REMOVE") (net_rim_bbapi_menuitem .COD "REMOVE")
(net_rim_bb_qm_yahoo "remove")
after remove this files.cod, re-install files.cod removed
if not soluction.
the best solution is
1.- cfp.exe /u /v3 wipe -f (erase file system) ( in the lcd screen "error 5.. reload s.o") install s.o for desktop, erase vendor, execute loader.exe and run
thanks
Page generated in 0.24862 seconds with 9 queries
