GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
04-14-2019, 11:21 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Spc reset new qualcomm First, the device must be in DIAG mode, the device DIAG port will be recognized in device manager Second: You should have any program that sends DM commands via COM serial as directly as DFS version 13.9.19 .You can download it from the following link Third: Open the DFS program and connect to the specified port and then try to enter the SPC code six zeroes you will find that the phone is not responding. Now copy the code in the bottom and paste in the CMD box in the dfs tool and click CMD icon you will see a Request and Response words in a light blue color on the dfs log window Code: Code: 4B0B24005D0200000E00550006003030303030300B3E7E The operation completed successfully Setup DFS 13.9.29.0 Code: https://mega.nz/#!ftYgFYrJ!R7LomSVN0u5JT7Bikqgrq3yLA33wrDTFrBarfa8yFH4 Last edited by zishhaider; 04-14-2019 at 11:25. Reason: correction |
04-15-2019, 08:46 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello If anyone willing to know who is really made this solution or who to give credits for such solution, its GCPro Team www.gcprokey.com FTM_method It will not work on any samsung or 2018 motorola. |
04-16-2019, 16:47 | #3 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | In most cases we need to enter SPC to activate DIAG mode, so it's slightly useless... Just for example, I have got an old ZTE N9500 and Motorola XT1049 . These phones ask for SPC when I type ##3424# on dialer |
04-18-2019, 10:09 | #4 (permalink) | |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Quote:
Code: https://forum.xda-developers.com/hardware-hacking/hardware/perfect-to-change-spc-to-zeros-majority-t3850474 | |
04-18-2019, 10:11 | #5 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | It works on local brands with Qualcomm inside like infinix etc which don't accept default spc, I saw it in nck and umt they are probably using it. Because they do read and restore qcn flawlessly on new models. |
