Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 09-28-2011, 20:41   #1 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
Python Base
Python Related Stuff and pythonic solutions to gsm related problems.
Old 09-28-2011, 21:24   #2 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
Thanks in Advance for code of Huawei Modem Calculator Code in Python.
Originally Posted by s400py View Post
import hashlib
def getCode(imei, salt):
        digest = hashlib.md5((imei+salt).lower()).digest()
        code = 0
        for i in range(0,4):
                code += (ord(digest[i])^ord(digest[4+i])^ord(digest[8+i])^ord(digest[12+i])) << (3-i)*8
        code &= 0x1ffffff
        code |= 0x2000000
        return code
imei = "123456789012347"
print getCode(imei, "5e8dd316726b0335")
print getCode(imei, "97B7BC6BE525AB44")
python
Old 09-29-2011, 05:53   #3 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
import hashlib
        code = 0
        code &= 0x1ffffff
        code |= 0x2000000
        return code
python
Old 09-12-2014, 21:58   #4 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
Zte unlockcode calculator writen in python by me
Check it out
http://forum.gsmhosting.com/vbb/7929227-post206.html
The Following User Says Thank You to mchizan For This Useful Post:
Old 09-15-2014, 22:36   #5 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
Python Flash File Sorter (nokia files)
Problem
I download many flashfiles from nokia fire server from links shared here.Mostly i would download more than 10 different flash files and each comprises of 3 parts hence having to sort about 30 files.
This is pretty clumsy so i made a dirty script so that it can help in classifying the files and place them in respective folders.
Solution
.........coming soon......
Old 09-17-2014, 22:33   #6 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
Originally Posted by mchizan View Post
Problem
Solution
Step one completed, we can now identify all flashfiles downloaded with partern rmxxx and RM-xxx .
It involved using regular expressions to match the pattern, and create folders of the specific files.
........... Ideas are welcomed............
Old 09-19-2014, 20:31   #7 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
Okay i tried to combine the two regex for rm565 and RM-475 so i am making twin scripts, !pretty amature! they run by asking for the download folder, they scan and create unique folders.
How do i place the files into the folders??
I am reading about it, and as usual, help is appreciated.
Old 09-21-2014, 12:26   #8 (permalink)
Fatmox's Avatar
Member: 111423
Sonork: 100.1618414
Thanks Meter: 22
hi
Mate python is not a compiler is a interpreter ... so a better way is to made a script to convert all UPCASE letters in LOWCASE and rename, this way you create a script only to prepare your files .....
The Following User Says Thank You to Fatmox For This Useful Post:
Old 09-21-2014, 12:30   #9 (permalink)
Fatmox's Avatar
Member: 111423
Sonork: 100.1618414
Thanks Meter: 22
I think this, that i m post will light you, this is not mine but will do, for you to understand how to do it ...
Another thing is search for python os.remove, os.copy, and so on ....
This will go through the source directory, create any directories that do not already exist in destination directory, and move files from source to the destination directory:
import os
import shutil
root_src_dir = 'Src Directory\\'
root_dst_dir = 'Dst Directory\\'
for src_dir, dirs, files in os.walk(root_src_dir):
dst_dir = src_dir.replace(root_src_dir, root_dst_dir)
if not os.path.exists(dst_dir):
os.mkdir(dst_dir)
for file_ in files:
src_file = os.path.join(src_dir, file_)
dst_file = os.path.join(dst_dir, file_)
if os.path.exists(dst_file):
os.remove(dst_file)
shutil.move(src_file, dst_dir)
Any pre-existing files will be removed first (via os.remove) before being replace by corresponding source file. Any files or directories that already exist in the destination but not in the source will remain untouched.
Old 09-23-2014, 07:50   #10 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
Thanks bro, I am going to implement it, in fact I should have realized it earlier lowercase could save me the pain for two scripts!
I am going to share out my script , and check the whole of it
Old 11-25-2014, 22:04   #11 (permalink)
mchizan's Avatar
Member: 505345
Thanks Meter: 11
okay,ill paste my code,then we see where we can fix it. Thanks, lowwercaps helped me get all files, i can make uniques folders like rm-xxx from the files in the maindirectory.
As i said,i cant place the files in the created directory.
i thought i could repeat the searching,identifying,then placing them
Upgrade info needed. Which phones still use the Nokia 5110/7110 base for my car kit muffking Off Topic Zone 0 03-17-2002 22:20
no flasher could read OT701 intel based flash majid Alcatel & TCL Old Models 12 03-14-2002 07:35
windows based NK PPM & MCU uploader and repairer reo Main Sales Section 2 11-09-2001 19:54
NEW windows based ppm&mcu PROGRAM !!! reo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 13 11-09-2001 19:51
PLSS CAN SMB SHARE WITH ME DATA BASE OF SIEMENS X35 unlocking codes.... igor_m x1x to x45/x50 4 10-11-2000 19:22
Page generated in 0.21868 seconds with 9 queries
