GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
09-28-2011, 21:24 | #2 (permalink) | |
Freak Poster Join Date: May 2007 Location: somewhere in space
Member: 505345 Status: Offline Thanks Meter: 11 | Thanks in Advance for code of Huawei Modem Calculator Code in Python. Quote:
09-29-2011, 05:53 | #3 (permalink) | |
09-12-2014, 21:58 | #4 (permalink) |
Member: 505345 Status: Offline Thanks Meter: 11 | Zte unlockcode calculator writen in python by me Check it out http://forum.gsmhosting.com/vbb/7929227-post206.html |
The Following User Says Thank You to mchizan For This Useful Post: |
09-15-2014, 22:36 | #5 (permalink) |
Member: 505345 Status: Offline Thanks Meter: 11 | Python Flash File Sorter (nokia files) Problem I download many flashfiles from nokia fire server from links shared here.Mostly i would download more than 10 different flash files and each comprises of 3 parts hence having to sort about 30 files. This is pretty clumsy so i made a dirty script so that it can help in classifying the files and place them in respective folders. Solution .........coming soon...... |
09-17-2014, 22:33 | #6 (permalink) | |
Member: 505345 Status: Offline Thanks Meter: 11 | Quote:
It involved using regular expressions to match the pattern, and create folders of the specific files. ........... Ideas are welcomed............ | |
09-19-2014, 20:31 | #7 (permalink) |
Member: 505345 Status: Offline Thanks Meter: 11 | Okay i tried to combine the two regex for rm565 and RM-475 so i am making twin scripts, !pretty amature! they run by asking for the download folder, they scan and create unique folders. How do i place the files into the folders?? I am reading about it, and as usual, help is appreciated. |
09-21-2014, 12:26 | #8 (permalink) | |
Freak Poster Join Date: Jan 2005
Member: 111423 Status: Offline Sonork: 100.1618414 Thanks Meter: 22 | Quote:
Mate python is not a compiler is a interpreter ... so a better way is to made a script to convert all UPCASE letters in LOWCASE and rename, this way you create a script only to prepare your files ..... | |
The Following User Says Thank You to Fatmox For This Useful Post: |
09-21-2014, 12:30 | #9 (permalink) | ||
I think this, that i m post will light you, this is not mine but will do, for you to understand how to do it ... Another thing is search for python os.remove, os.copy, and so on .... Quote:
09-23-2014, 07:50 | #10 (permalink) |
Member: 505345 Status: Offline Thanks Meter: 11 | Thanks bro, I am going to implement it, in fact I should have realized it earlier lowercase could save me the pain for two scripts! I am going to share out my script , and check the whole of it |
11-25-2014, 22:04 | #11 (permalink) | |
okay,ill paste my code,then we see where we can fix it. Thanks, lowwercaps helped me get all files, i can make uniques folders like rm-xxx from the files in the maindirectory. As i said,i cant place the files in the created directory. i thought i could repeat the searching,identifying,then placing them | |
Upgrade info needed. Which phones still use the Nokia 5110/7110 base for my car kit | muffking | Off Topic Zone | 0 | 03-17-2002 22:20 |
no flasher could read OT701 intel based flash | majid | Alcatel & TCL Old Models | 12 | 03-14-2002 07:35 |
windows based NK PPM & MCU uploader and repairer | reo | Main Sales Section | 2 | 11-09-2001 19:54 |
NEW windows based ppm&mcu PROGRAM !!! | reo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 11-09-2001 19:51 |
PLSS CAN SMB SHARE WITH ME DATA BASE OF SIEMENS X35 unlocking codes.... | igor_m | x1x to x45/x50 | 4 | 10-11-2000 19:22 |
