GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets. |
09-22-2015, 14:01 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Qualcomm qcn(dual imei repair) issues NV Backup - Download - 4shared Last edited by zishhaider; 09-22-2015 at 14:07. |
09-23-2015, 01:45 | #3 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | there are two imei number secured by hex unicode in your qcn... and the both are start with 083a.... open qcn with hxd hex editor.... cntrl f and untick find text...search for 083a find original imei and change...do not save file now than press again ctrl f..... and search for 083a again hex editor will find the second hexed imei in your qcn... edit it too than save |
The Following User Says Thank You to loniryan For This Useful Post: |
09-25-2015, 10:34 | #6 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Loniryan.. I am unable to find it.. you can download my uploaded qcn nd can check your self.. 550 is first imei.. second one is not visible... |
09-25-2015, 12:29 | #8 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | enable usb modem mode and backup your qcn again...as u can see ur device msmmodem chip not shown...DEADD is write on qnc..and dont forget....full qcn size must be 250kb-348kb...not 80kb |
09-25-2015, 14:50 | #9 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | I was talking about 0000 qcn.. not dead one.. plus i have already enabled diag .. and i can see qualcomm port.. If you mean anyother modem.. kindly tell me what command should I use in terminal..and thanks man for your guidelines.. |
09-25-2015, 15:59 | #10 (permalink) |
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | Some of qualcomm sets unable to edit or repair second imei with qpst..and some of devices are free to repair...look at the qcn and follow my steps to find 2.nd imei.. for example i have changed second imei of casper via a1236 vith this method br |
