Go Back   GSM-Forum > Other Gsm/Mobile Related Forums > GSM Programming & Reverse Engineering
GSM Programming & Reverse Engineering Here you can post all Kind of GSM Programming and Reverse Engineering tools and Secrets.
Old 11-21-2014, 17:34   #1 (permalink)
Member: 1633328
Thanks Meter: 37
reverse engineering to find emmc problems
hello gurus. I've been reading this section and I'd like to know if there is any way to use the reverse engineering to find problems on cell phones when there is baseband unknown after imei repair. it should be one way to know if after the imei repair the box caused damaged to the emmc or baseband ic or if is it just there are some partition corrupted.
if that is possible could someone post here how to do it. thanks in advance.
Tukara
Old 11-23-2014, 11:40   #2 (permalink)
..::SuB::..'s Avatar
Member: 833760
Sonork: 100.1597150
Thanks Meter: 114
what do you want to reversing? it is already clarified by others.
Old 11-23-2014, 14:55   #3 (permalink)
Member: 1633328
Thanks Meter: 37
Thanks for reply. Well I think I read all post here and I haven't find anything about how yo find problems reversing but let me try to explain what I want. Sometimes samsung phones get the baseband damaged when we are trying to repair the Imei with boxes. Sometimes the wifi or bluetooth get damaged too. I'd like to know how can I know what 's exactly happening with the phone and how to solve it if it possible. I think if i know how to apply the reverse engineering to a damaged phone i can determine if the phone has hardware or software problem.
Sent from my iPhone using Tapatalk
Old 11-23-2014, 22:58   #4 (permalink)
Member: 2298115
some kind of exe made thru delphi vb and it contains manual guide's?
Old 11-26-2014, 12:47   #5 (permalink)
Member: 1418143
Thanks Meter: 353
according what I read here imei isn't related to emmc issue ..
but by BAseband Ic ( CPu & nand ) .. Im I wrong big bro's ?
Old 11-26-2014, 14:28   #6 (permalink)
Member: 1633328
Thanks Meter: 37
Well i read that too. But some jtag box support told me that i have faulty eMMC so I really dont know what to do now. That why I'm asking here to get answers or at least links to read, read, read.
Old 11-26-2014, 15:20   #7 (permalink)
Member: 1418143
Thanks Meter: 353
yur phone model ?
Old 11-28-2014, 16:32   #8 (permalink)
Member: 1633328
Thanks Meter: 37
Samsung sgh-t999, sgh-i747, m919, i337. I've seen this problem on samsung phones S version and note version.
Old 11-29-2014, 14:53   #9 (permalink)
Member: 1906979
Sonork: 100.1681049
Thanks Meter: 162
if modem(bb chip) is working then you can see imei on screen, emmc is damage or working does mot matter.i have repair lot of phones in this case by hardware.i face much type of problams. so we cant sure that problam is in emmc.
Old 11-29-2014, 15:43   #10 (permalink)
duncan99's Avatar
Member: 1322701
Thanks Meter: 127
Bro i have many many problems like that.
which after efs reset,modem write e.t.c. the baseband still remains like that.
i have i9300,N7100,i9500,i9505 e.t.c that has that kind of problem.i know its hardware which can caused by baseband ic, but my problem is that i dont know how to fix it.
Please help me bro cause i have been looking for someone that will help me out in this problems for so long.
where is the baseband ic located on this devices?
can it be caused when the baseband ic loses voltage?
do i rehot,reball or replace when i encounter such problems?
if i dont have the schematic of the phone e.g i747. what is the characteristics that i will use to know a baseband i.c by just looking at it?
Thanks in advance
Old 11-30-2014, 12:29   #11 (permalink)
Member: 1633328
Thanks Meter: 37
Hello thanks for reply bro. I'm in the same boat as duncan99. As I know there is not baseband chip in some samsung model because of the processor, modem, memory combination. The reason why I started this threat is to try find the way to test the damaged ic (in some case the processor) before to try to reball it or replace it. You have some info about it or you how to fix it please post it here. Thanks in advance.
Old 12-11-2014, 02:12   #12 (permalink)
Member: 1633328
Thanks Meter: 37
Hello nobody here could help me please?
Old 12-11-2014, 06:47   #13 (permalink)
Moderator
Member: 73
Thanks Meter: 537
Realy I not want dissapoint yoy but "Reverse Engineering" is not piece of cheese. How you expect help? Better is to try contact with supplyer of your equipment to discuss how kill emmc and possible way to repair.
__________________
You'll die as you lived in a flash of the blade,
in a corner forgotten by no one
You lived for the touch for the feel of the steel
One man, and his honor.
Old 12-12-2014, 03:43   #14 (permalink)
Member: 1633328
Thanks Meter: 37
Hello thanks for reply. They wont say anything. I think if some people learned reverse engineering why i cant?. 2 years ago i didnt know anything about repair, unlock, flash cell phones. I just want to go deepest in repairs and think Reverse Engineering is the best way. I hope some master here could help me on it.
Old 12-12-2014, 03:58   #15 (permalink)
Member: 2076039
Thanks Meter: 648
No one is going to hold your hand through this. I was fortunate to have dest give me a pointer or two, but he left me to my own devices. I didn't ask repetitive questions, I did a lot of my own research and in the end I learned no one is going to hand feed you. The information is out there. If you're begging for it, then your effort is being wasted. 99% of your time should be spent researching. 1% of the time should be other tasks (including asking direct questions). So for every 99 pdf documents (github code, .jar code, .apk code, dissecting libraries, going through ARM code, etc.) you've read over relevant material...You get one question. This isn't college. You're hacking into proprietary software where the bugs and patches aren't readily available publically. There is no book or professor; you have to learn by yourself and teach yourself (i guess it's similar to online schooling? Lol).
The Following 2 Users Say Thank You to ecs87 For This Useful Post:
Page generated in 0.21809 seconds with 8 queries
